Question about Jenn-Air JGR8775QD Gas Kitchen Range
Regulating gas on cooker
Gas cooker with 4 rings.  2 left hand gas rings do not regulate heat up or down.  when on it is on either full or low.  whereas 2 right hand gas rings can go hot, medium hot, medium, cooler etc.  Checked the knobs and they seem OK but a bit stiff.  What is the problem.  Just cleaned it an hour ago can this be the cause of the problem?  Has not been a problem before.  Only cleaned it with an all purpose cleaning spray?
Many thanks
  • 183 Answers
SOURCE: Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Posted on Jul 28, 2007
  • 1314 Answers
SOURCE: converting stovetop from natural gas to lp
there is a square nut on top of the regulator un screw it and underneath you will find a Cly flip that over should take care of it one side will say ( nat) the other will say( lp) you want lp up
Posted on Feb 26, 2008
  • 2692 Answers
SOURCE: cleaning Jenn-Air gas oven
owners manual:
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US
Posted on Dec 29, 2008
  • 5 Answers
SOURCE: Lover oven door did not unlock after cleaning cycle.
if it is cooled enough then try this
hold back and enter hold for three seconds , unlocking door will appear in display when control and door are unlocking
good luck
Posted on Mar 22, 2009
  • 222 Answers
SOURCE: recent install, using lp kit, in use it seems like
try to repalce the regulator.sometime the problem is not in unit? in regulator or if u have other regulator try to use then check it. if same thing again,call an expert tecnician to check the gas line & the unit.do not try to repair by it ur self ocz if hard & itr danger
Posted on Jul 04, 2009
Zanussi hob can't turn off full power on one ring
the regulator is faulty you will have to fit a new one fairly easy task let me know if you want more help
Apr 17, 2012 | Zanussi Ovens
New GMH80703AN two stage convertible.converted to LP. regulator on tank and a low pressure regulator next to furnace .I can hear and feel the furnace gas valve but no gas coming Thur to orifice
1.You could have a empty propane tank. 2 The regulator could be frozen. Has it rained or snowed recently? If so there is a vent on the regulator that could be plugged. I have had to thaw out 4 of these in the past week. Its simple unhook it and it bring it in the house and warm it with a heat gun or blow dryer for about 5 minutes.
Dec 18, 2010 | Goodman Heating & Cooling
I have a 2004 Tahoe which has misfire problems (P0300). I changed the plugs, wires, fuel filter and air filter but problem still exist. The 4 plugs on the passenger side continue to file out and become...
Removal & Installation of fuel Regulators on
4.8L, 5.3L & 6.0L Engine To Remove:
CAUTION
Three styles of fuel pressure regulators and fuel rails will be used in this model year. Each regulator has a different "footprint" that consequently changes the size of the receiving port in the fuel rail. The regulator retaining clips are specific to each rail-regulator design and cannot be interchanged.
  1. Remove the engine sight shield.
  2. Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure.
  3. Clean the fuel pressure regulator retainer and the surrounding area.
  4. Remove or disconnect the following:
    • Fuel pressure regulator vacuum line.
    • Fuel pressure regulator retainer.
    • Fuel pressure regulator.
  5. Remove the following parts from the fuel rail:
    • Backup ring (10)
    • Regulator Seal O-ring (11)
    • Regulator filter (12)
    • Regulator seal O-ring (13)
To Install:
  1. Make sure the NEW fuel pressure regulator retainer is the right one.
  2. The tabs (1) are used on the straight vacuum port retainer (2), and the E85-straight vacuum port retainer (3).
  3. The angle vacuum port retainer (4) has no tabs. chevy_aval15_02-04_fuelrail.gif
  4. Install the following parts onto the fuel pressure regulator (9).
    • Backup ring (10)
    • Regulator seal O-ring (11)
  5. Lubricate the fuel pressure regulator O-rings with clean oil.
  6. Install the fuel pressure regulator and retainer. CAUTION
    Whenever the fuel pressure regulator is removed from the fuel rail NEW O-rings and a NEW retaining clip should be used on reinstallation.
  7. Connect the vacuum line.
  8. Tighten the fuel filler cap.
  9. Use the following to inspect for leaks:
    • Turn ON the ignition, with the engine OFF, for 2 seconds.
    • Turn OFF the ignition for 10 seconds.
    • Turn ON the ignition, with the engine OFF.
    • Install the engine sight shield.
8.1L Engine To Remove:
Fuel pressure regulator vacuum line gm_trk_sub15_fuel_press_reg_vac_line.gif
  1. Before servicing the vehicle refer to the precautions at the beginning of thjs section
  2. Remove the fuel injector sight shield as needed
  3. Relieve fuel system pressure (See: Fuel Pressure Relieving)
  4. Disconnect the fuel pressure regulator vacuum line (A) 8.1L Fuel pressure regulator retainers gm_trk_sub15_81l_fuel_press_reg_retainers.gif
  5. Clean any dirt from the fuel pressure regulator retainer and the surrounding area
  6. Remove the fuel pressure regulator retainer (I)
  7. Remove the fuel pressure regulator (H) from the fuel pressure regulator housing
To Install:
  1. Install or connect the following:
    • Backup ring (J) on the fuel pressure regulator (H)
    • New large O-Ring (K) on the fuel pressure regulator
    • Regulator filter (L) on the fuel pressure regulator
    • New small O-Ring (M) on the fuel pressure regulator
  2. Lubricate the fuel pressure regulator large O-Ring and the small O-Ring with clean engine oil
  3. Push the fuel pressure regulator onto the regulator housing on the fuel rail
  4. Install a new fuel pressure regulator retainer (I)
  5. Install or connect the following:
    • Negative battery cable
  6. Tighten the fuel filler cap
  7. Inspect for leaks using the following procedure:
    • Turn on the ignition with the engine off for two seconds
    • Turn off the ignition for 10 seconds
    • Inspect for fuel leaks
  8. Install the fuel injector sight shield
  9. Road test the vehicle to check performance
Sep 02, 2010 | Chevrolet Tahoe Cars & Trucks
My q grill is not heating properly. I have a full tank of propane and the grill is clean but the burner is not getting enough gas to heat past 200 degrees
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 30, 2010 | Weber Q Grill
When i take the intake plenum off, there is fuel sitting in the left hand side(fuel press regulator side) 1995 chevy blazer. the fuel injection got replaced last summer and i replaced the regulator a month...
Wow, that's interesting, I'm trying to think how you could be getting gas in the oil. I'm guessing the gas on top of the motor is coming from a leaking O-ring. You maybe have a nick or tear in one of the O-rings in that area. It might only leak at certain temperatures with things expanding and contracting. Try wiggling some of the lines and fuel pressure regulator to see if you can make the leak a little more obvious. As far as gas in the oil the only thing that I can think of is leaky injector and the gas running down past the piston rings. I guess it could leak down past the intake manifold into the lifter valley but, I find that hard to believe. Good luck with that one, have a Happy New Year!!!
Dec 31, 2009 | 1995 Chevrolet Blazer
2 of 4 ceramic rings do not respond to lowering the heat setting
You need 2 new temperature regulators fitting.
Quite a common problem..
Thanks
Plz rate solution
Dec 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
LPG probs
How close to the exhaust is the supply line as the lpg supply line should be cold until it gets into the regulator not warm.Is the supply line heat shielded as it enters the engine bay or getting a full dose of exhaust heat?Is it the vapor injection gas system or the old style.What regulator and system are you using?OMVL ?sprint gas or other cheaper variants?It really sounds like a fuel delivery issue as you are not getting the volume of gas required at higher speeds.Commodore engines have issues with thier water system having air bubbles that cause air locks in the regulators by the time youve jumped out of the car to check for freezing it appears to be fine.You may have restrictions in the lpgas filters/locks.The water hoses,2,should be hot so hot you cannot leave your hand on them and if not freezing of the reg once again becomes the issue.Also the water hoses must be fitted in such a way that the top hose is suction and the bottom hose forces water into the reg,this is done to assist in eliminating potential air lock problems.To sum up your symptoms are consistant with poor water ciculation.
Nov 03, 2008 | Pontiac Montana SV6 Cars & Trucks
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Low Gas Pressure on Smeg Range cooker
there should be a regulator on back of the stove where the gas line connects.you will see a plug that unscrews,remove this plug and run the unit.if this solves your problem clean the plug really good and put back on.
Dec 25, 2007 | Kitchen Ranges
Low gas Flame
check the vent plug on the regulator.
Dec 24, 2007 | Rangemaster 110 (Gas) Kitchen Range
Jenn-Air JGR8775QD Gas Kitchen Range Logo
49 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
