Question about Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump...
Jets wont work
Like there is no power to them
    Problem Solver:
  • 4 Answers
Is there a way for you to get acces under your tub. a door? if so check were the pump is and follow the power supply? there should be a switch or check your fuse pannel in your house?
Posted on Jan 13, 2009
My hot tub has an issue. Only half the display is working, there's no heat and the jets wont turn on. If I trip the curcit, I can get the hot tub jets for 10-30 seconds and that's it. HELp
Almost all hot tubs use 230 volt AC power which comes from the power company in two power wires plus one common common wire. You get common 115 volts between a common and either other wire. "Half way" working could well be an attempt to run on only one of the wires. There is also likely to be a ground fault circuit breaker in the wiring which makes sure current going out to the tub is all returned via the wires and not through someone's legs to ground. If you're comfortable with an AC voltmeter check some voltages but understand that 230 volts is way into the killing range. Two people present and well insulated probes are important.
Apr 15, 2016 | Pool & Spa
My snowmobile wont run over 20pmh and the electric accessories wont work right
There are 2 SEPARATE PROBLEMS and they are NOT related
Your Carburaters need to be cleaned (High Speed Jets) are blocked or not the right Jets for your Altitude. If you have a Security Issue (Ski Doo has this issue), it will cause it to not run over 20...
Jan 04, 2014 | Yamaha 2013 SRX 120
Aquaglass whirlpool tub
if timer and power ok, jets may be clogged. try running for 10-15 minutes after tub filled. It may unclog.
Oct 06, 2013 | Home
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
I have a 2001 suzuki RM125 and it wont kick start and the power band wont kick in,It will start write up if pushed but the power band will not kick in..Thanks Greg...N.O. L.A.
it may just be dirty carb jets or no fule from the tank getting to the carb if it runs better with the choke on its likly to be jets blocked up
Mar 18, 2010 | 2003 Suzuki RM 125
I have an FDF780 dishwasher that wont spray water
Sounds like wash pump is weak or siezed.
Sep 28, 2009 | Dishwashers
Burners ignite but wont light
Are you on Natural Gas or LP?
If on LP, you may need to change the jets on the burners on top. Most times, when oven and broiler work and top doesn't, and you have spark, your jets are wrong size. Look on back of unit for a cardboard attached to unit, should have jets stuck to cardboard, if notgo to store where you bought unit and buy jets.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Wont start keeps back firing working fine then went to take out next day and key turns it tries all that happens is it puffs out of exsort and wont go
2 possible problems:
a) Jets in carburettor are clogged. Clean out the carburettor and jets thourougly. Write down the settings of air and idle screws first to dismantle ( count the turns to full lock up the screws. DONT apply much force ).
DONT scratch jets with an iron wire or something like that, use only Carburettor cleaner!
b) Ignition timing is wrong. Here, 2 possibilities:
Sparkplug is dirty or worn, replace it.
Key in flyweel is broken. Remove the flywheel, check the key...
Hope this helps you in the right direction for your solution...
Aug 29, 2009 | Gilera Runner VX 125 Motorcycles
Bike wont run when choke is at half way setting
Sounds a lot like fouled fuel jets in your carb; you may have a little work to do.
If the jets do not allow sufficient fuel to pass, using the choke can 'cheat' the carburetor by restricting the flow of air and restoring the fuel-air ratio. You can't ignore this problem since the 'cheated' condition does not let the engine develop the power for which it was designed.
Apr 26, 2009 | 1988 Honda CBR 600 F Hurricane
Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump... Logo
114 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
