Question about Samsung RB2155SH Bottom Freezer Refrigerator
Refrigerator lamp will not come on
The lamp in the refrigerator will not come on. Lamp works fine when installed in freezer, so bulb is good. I get 30v at lamp socket, switch on or off, doesn't matter which way the switch is. BTW this is actually a RB2055SL I have. I have read some of your fixes and I am sure this one will be elementary for you. Thanks
  • treefarmer89 Mar 03, 2009
    My fridge light stopped working, so I replaced with identical lamp and it still won't work. I contacted samsung free chat site and they suggested unplugging power and then repowering.That didn't help. They suggested removing bulb and reinstalling...that didn't help.
  • 944 Answers
If the voltage is there regardless of activating the door switch or not then the problem is almost certainly in the switch, Here is the link for the user manual for your machine if you need it; http://www.samsung.com/support/productsupport/download/Model_Select.aspx?type=Refrigerator&typecode=21&subtype=Low+Freezer&cmssubtypecode=2104&model=RB2055SL&filetype=UM See if you can figure out how to get access to the switch (unplug it first please)- sorry the pictures aren't good enough for me to see how -it may just pull out of where it is, or you may have to unscrew or unclick a panel or two. If there is damage to the switch, it would usually be obvious due to burn marks or distortion of the plastic, not necessarily on the bit you can see though - there may be a loose wire that is causing the problem, but usually the switch itself has committed suicide. I have not been able to find what the voltage should be in the bulb socket, each country has different arrangements, I am assuming that from the rating on the bulbs 30v is what you should be getting? - do you also have 30v at the freezer lamp socket? does the freezer bulb work in the fridge? (it may seem slightly dimmer - it should be half the wattage) this might indicate if there is a problem (possibly slight distortion from heat in the socket) that is preventing the bulb from connecting properly. Hope this helps, I bet on the switch. If you are struggling to access it, if you could post a couple of photos of the area concerned and the back/top/inside of the fridge then I hope we can help you. the switch may be repairable, but any fridge repair shop should be able to find one that will do the job, else contact samsung (page 14 in the manual) :)
Posted on Mar 22, 2007
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
Fridge light bulb
Not sure how the light socket only has 6V supply? The bulb for this fridge is a pretty standard 15 Watt/230V SES lamp. If you are sure the current lamp is OK I would suggest the door lamp switch has issues. Try pressing and releasing the door switch manually and check that it functions ok without getting stuck or any sluggish movement. This action in itself may fix the problem.
Jan 18, 2014 | Miele KFN8462S Bottom Freezer Refrigerator
Light blinks off and on when door is open
If you mean that the freezer cabinet light flashes check the lamp fitting and ensure the bulb is fully tightened, they have a habit of becoming loose with the expansion and contraction of the fitting/bulb as the freezer compartment cools with the door shut and the bulb warms when the door is open.
Jan 09, 2014 | LG LFD22860 Bottom Freezer French Door...
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
Refrigerator light no work i change light bulb and door swicht
was old lamp hard to unscrew from socket? maybe over tightening lamp has mashed center tab in lamp socket down
Mar 08, 2013 | KitchenAid Superba Architect KSCS25INSS...
Problem with fridge light on Hotpoint FFA70
Did you check the new lamp when you put it in? Did you keep the old lamp? It may well be the switch rather than the lamp itself. Check the lamp has continuity from the middle pin to the outer and the filament isn't broken
May 10, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
My Fridiaire refrigerator model GHSC39ETJB2 serial # 4A83300072 The refrigerator side (freezer side works normally) interior lights intermittantly (some times they work fine, next time, do not). Lights...
Hello James Roadkin,
Sounds like you have it properly surrounded...
but the PART 5309918806 does NOT go with your
refrigerator... GHSC39ETJB2...
(rather part number 241547901)
I have pulled up an appliance store...
They provide excellent support and VIDEO
guides for the adventurous DIY (do-it-yourselfer)
home appliance repair persons...
Looking good...
appliancepartspros:
http://www.appliancepartspros.com/frigidaire-switch-light-lamp-241547901-ap3562983.html
Check out their video...
and then their competition...
Repairclinic: (look at their testing video)
Door Switch 241547901
Partselect
Frigidaire 241547901 SWITCH LIGHT LAMP PartSelect
All the parts are essentially the same
(let the price/guarantee be your guide).
Hope this helps
Carnac the Magnificent
Aug 27, 2017 | Frigidaire Refrigerator Door Light Switch ...
How to change light bulb in ge refrigerator model gts18dbpalww
Unplug the refrigerator. For the refrigerator, unscrew the old bulb or bulbs and screw in a new appliance bulb of equal or lower wattage. For the freezer compartment, if a lamp is present, squeeze the top and bottom of the cover together then unscrew the bulb. Then screw in a new appliance bulb of the same wattage and replace the cover.
Note the appliance bulb is an incandescent bulb and may be hot.
The manual is available here: http://www.managemylife.com/mmh/owner_manuals/5791/GE-Top-Mount-Refrigerator-L0307014?brand_name_search=gts18dbpalww+ . The lamp replacement is given on page 13.
I hope this helps.
Feb 14, 2011 | GE Refrigerators
Interior bulb heating up
LG has had an issue with this and has re designed the lamp cover and the lamp holder itself. contact your nearest parts supplier with your model and re order this part and you will receive the new upgraded cover.
Oct 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Samsung RB2155SH Bottom Freezer Refrigerator Logo
1,112 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
