Hi Mark I have opened mine following a video guide on youtube, the grill can be removed easily with care and the screws are then on show it also shows you how to remove the bottom in a separate video with the same person, worth watching...
From 2006 to 2010, the Sonata's 3rd brake lamp requires the rear package deck be removed to access that bulb. 1. Remove the rear passenger seat bottom (remove two12mm bolts between the seat back and the seat bottom - tilt the seat back forward to locate these bolts). a. Press the two bottom front edge tabs to release the front of the seat bottom from the floor. b. Remove seat bottom & set aside w/two 12mm bolts c. Tilt both seat backs downward 2. Remove the left & right hand shoulder cushions (12 mm bolt at the bottom of each cushion) a. Remove seat belt from shoulder cushion guide at the top of the cushion b. Lift up and forward on shoulder cushions to remove them (if equipped with side airbags, disconnect wire harness connector). c. Set shoulder cushions aside w/two 12mm bolts 3. Using a small flathead screwdriver, pop out the 'SRS' button cover from the C pillar panels on the left & right hand side to access either the phillips head screws, 10mm bolts, or #30 Torque Screws a. Remove screws and set aside b. Using a standard flathead screwdriver, pop out the C pillar panels on both sides (clips hold these panels in place) c. Set these panels aside after removal w/screws/bolts 4. Trunk Access-way panels are held in place by phillips head screws (two at the bottom (left and right hand sides) and 4 to 5 at the top . a. Remove left and right hand panels and set aside w/screws. 5. Rear package deck held in place with two plastic clips (white, yellow or pink) a. lie on your back inside the trunk (trunk lid open to allow for more light). Looking through access hole find 3rd brake light wire harness connector & disconnect. b. locate package deck clips, one on the left and another on the right on the underside of the pckage deck c. Squeeze clips to push them out - package deck will come loose d. Remove package deck & remove 3rd brake lamp bulb socket (turn counter clockwise to remove). Replace bulb & reassemble in reverse order.
There is a button on the front of the unit that is just below the LCD readout that shows FM / iPod status. Press the button. If it does not open the unit, you may need to tap the back of the unit when doing this or else get something to gently pry open the unfolding section WHILE THE BUTTON IS PRESSED (otherwise you'll break the mechanism and won't be able to lock it again. It sounds like whatever you put in to create the connection may be jamming up your opening.
The unit comes with several adapters for different iPod models, you may want to try a different adapter; you shouldn't need to put anything else in it to maintain a connection. If you don't have those adapters anymore, you can probably get them off the altec lansing web site.
I had the same issue and read here that you may want to try unplugging your battery cable and plugging it back in. First, power down and unplug the im600. Then get a 00 Philips screwdriver and unscrew the two screws that are in the back of the unit (where the remote rests). Gently pull off the cover and you'll see a cylindrical battery with a connector coming from it. Unplug that connector, leave it unplugged about a minute or so, then plug it back in. I am trying this myself right now so I can't confirm that it works yet.
If you find that your battery is dead, and will not recharge, go to AltecLansing.com and contact their customer service. They will instruct you how to obtain a replacement battery.
buy a cilyndrical 3.7v battery,a bougth a onu with 3000mah.
and use the conectors from your old one,they are built-in circuit take it apart and reuse it
The new battery goes in the back of the Altec Lansing imt702. Remove the two screws on the lower back of the unit. The battery is connected via a clip connector. Simply press on the raised end of the clip, and pull off the other end of the connector. The battery is a Lithium-Ion 18650, 3.7V, at least 1800mAh. If you can get a battery with a higher-rated mAh, this will give you longer run times. It might be difficult to find a matching power connector on end of a new battery though. The unit will still run with the battery removed, but of course, will not power without the AC adapter connected to a wall outlet. If your unit has problems, continuously asking to Reset itself, or display+buttons flash (with volume increasing +1 for each blink), this indicates a charging problem. The battery needs to be replaced or removed immediately. You can reset the power manually by holding down the metal clip at the back of the unit for a minute, or just closing the leg/stand to see if this works. To reset unit's factory settings: hold down power & radio << channel buttons for 7 secs, press Power when asked to Reset?, Region=1 for US stations, & press Power again to set Region. Note that the battery is being drained even if the unit is off, so keep the AC connected; completely draining a well-used Li-Ion battery may shorten the rest of its battery life. Remove the battery from the unit if not in use for long periods.
Yes there is you have to unscrew all the screws in the back and sides.. open the cover and you should be able to access it
thank you please let me know if this helped
The battery is probably dead, as it's rated for 400 cycles.
When you have the dock's feet out, you can see 2 tiny screws on the back of the unit, unscrew them, remove the hatch and you'll have your battery exposed.
3.7V 1800mAh Li-Ion
YPMDesign is correct, but to get further into the im600 you have to peel off the cover that masks the LCD (it has Altec Lansing printed on it). Once done, it exposes 2 screws, and when removed you can pull open the whole thing, exposing the main circuitry. There is nothing that can be reseated though, as all appears soldered. There is one main board, which everything connects to, then the PCB at the bottom of the system, which has the power buttton and ipod dock connector etc. Unfortunately I have been unale to resolve my problem, where the Power buttton LED lights briefly if the battery is removed and reconnected, but getting nothing on the main display, and the power button is not responding at all when depressed. Mine is sadly bin bound..
