Question about Video Cameras
I have a jvc camcorder model: GR-SXM25OU When I turn it on the screen shows EO4 Unit in safeguard mode. Remove and reattch battery. I did this and still doesn't work. I even bought a new battery but it still gives the same message. What do I do to fix this so I can use the camcorder?
  • 883 Answers
SOURCE: e03 safeguard mode
look for a tiny pinhole and insert a pin while powered up to reset
Posted on May 27, 2007
magic seadog
  • 38 Answers
SOURCE: safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Posted on Aug 12, 2007
JDeRuvo
  • 48 Answers
SOURCE: JVC Camcorder Model # GR-D270U
On page 51 of your manual, it states that an error has occurred and recommends resetting it by removing your battery, waiting a few minutes to clear it, and then resuming. If that doesn't clear the issue, then it may need servicing.
J. DeRuvo
Digital Camcorder HQ
Posted on Dec 04, 2007
kala
  • 156 Answers
SOURCE: safeguard mode/remove battery & reattach
There should be a error code,what is that?
Posted on Feb 25, 2008
SOURCE: JVC Compact Camcorder modle number GR-AXM18U
I had this same issue and it was driving me crazy. If you do not turn the camcorder on and hold the eject button, when it is trying to eject tap right in the middle of the tape (next to the eject button)  I had to do this twice before it opened but it worked. It tends to tighten the tape up and reset that error code message it is receiving internally.
Posted on Jun 03, 2009
I have a GR-D850U in safeguard mode
I have a GR-D850U model JVC and its giving a message Unit in safeguard mode. How can I have this fixed ?
Jan 14, 2010 | JVC GR-D850 Mini DV Camcorder
Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Apr 28, 2009 | JVC Video Cameras
Safeguard Mode
What error message appears,it should say E0..
May 27, 2008 | JVC GR-D20EK Camcorder
Problem with jvc gr-sxm58
Do you happen to try with another tape? if so, it needs repair, mostlikely the capstan motor need to change and it needs hinger skill to do this, since you have to adjust it after replacing.
Apr 23, 2008 | JVC GR-SXM58 Camcorder
JVC GR-D250 Mini DV Digital... Problem
There is any error code displying on the lcd screen?
Feb 28, 2008 | JVC GR-D250 Mini DV Digital Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
Jvc GR-D250
There is any error code showing on the lcd screen?
Oct 25, 2007 | JVC GR-D250 Mini DV Digital Camcorder
EO4
Something is causing either the take up or supply reel in the camera not to rotate when the tape is inserted. A defective tape or hung reel brake can cause this issue. Try replacing the tape, if this does not resolve the problem you may need to seek professional service to have the reels checked. Good luck my friend, Joe Weibel customelectronics.org
Jan 25, 2007 | JVC GR-FXM270A VHS-C Analog Camcorder
Video Cameras Logo
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
