Question about Lenovo ThinkPad® T60 PC Notebook
IBM T60 will not start up.
Was using T60 last night and it was working just fine. I shut the laptop down and then when I came back this morning to use the laptop it would not start up. There were no lights showing either. I plugged the computer in to it's power supply cord and still no luck. Do you know how to get this laptop up and running again? Or what the damage might be?
  • 202 Answers
Could be the ac adapter, battery dead, first check them. if you find nothing there then it could be internal problems. if you know someone who has a charged battery try using it in yours. also try removing the battery and only using the ac adapter only.
Posted on Jul 21, 2009
When logging off my laptop, and before going into shutdown, I closed the lid on my laptop. The window is now stuck showing the prepare to shutdown screen. The mouse pad still works but nothing I push will...
Try holding down the power button until the computer force shuts down. If that doesn't work, you may need to pull the battery. Don't worry about damaging files, everything should be fine. When Windows boots up again, you just need to select "Start Windows normally".
Aug 14, 2011 | IBM ThinkPad T60 Notebook
How do i reboot my thinkpad t60 ?
If this is a serious question, then the answer depends upon the version of Windows you are using.
Usually, you simply click on the Start Button in the lower left corner of your monitor/screen, then look for options to Shut Down, or Shut Down and Restart.
Failing to find those items you can always use CTRL+ALT+DEL and when the result of that comes up, look for Restart as an option.
Best thing you can do is to find the Help options and read what Microsoft has written about controlling Windows. Find their Tutorial and spend some time reading and following it.
-a.
Apr 08, 2010 | IBM Computers>Laptops Lenovo ThinkPad T60...
My laptop doesnt start. It's not working. I was just using it last night. I was working well. I shut it down properly as I should. This morning when I turn it on. It didnt work.
Hi there, try to remove the battery, clean the terminals, then place it back, chances are the battery was dislodge. test again. hope this helps.
Aug 06, 2009 | Computers & Internet
Power Button wont do anything
First check your num lock key on key bord if it is on off when you press num lick key then your dispaly is working fine means you need to change screen resolution.
For that when you power up the computer press F8 key then enter in enable vga mode.then go to display property and change screen resolution to 1024*768 or 800 *600.
Also when you power up the computer press F1 or F2 or 'del" key to enter in bios then load optimal defaults also check your harddisk is detected .Disable your satat option in bios .then save settings then check.
I f you not able to enter in bios then Refix your ram.If still face problem you need to reset bios .
For that you have to open laptop cover in back then pull cmos cell from mother bord for 5 minutes then refix it then check.
Jul 27, 2009 | IBM ThinkPad T60 Notebook
HP nx7300 no boot
I guess your battery needs to be flash.
Apr 10, 2009 | HP Compaq nx7300 Notebook
Ibm r50e laptop no black light
dear sir
if u have a booting problem then when u start yr laptop press F11 key and go thru instraction stape-by-stape then recover yr regisery to before near date then it's help u
Thanks
Please vote
jo_chinmay
Jan 01, 2009 | IBM ThinkPad R50e Notebook
Ibm t60 will not boot after ibm updates
The problem is sort of solved. I phoned the IBM Support centre; they said that the mother board was either broken or faulty. Fortunately the laptop is still under waranty and so an engineer will come and fix it. I must say the IBM suport centre was very efficient and quick.
There was no mention from them though that it was the bios update that may have caused the problem.
I'll update when the laptop is working.
Thanks.
Dec 21, 2008 | IBM ThinkPad T60 Notebook
Thinkpad t60 updated bios now willnot start
it seems that u have installed a faulty driver that was not for your notebook
what u can do is when u enter the post in your notebook than keep pressinf the f8 key and hope u come in the safemode when u there than make a system restore like a day or 2 back and than it will be fine , if that is not possible than try to press the f11 key for complete system restore if u have maked a system backup on dvd
if thats not possible than the only thing u can do is bring it back for a rma at ibm
Startup problems
check your keyboard connection (unplug and plug again). If not works try another of same type.
Dec 24, 2007 | HP Compaq Presario V2000 Notebook
Open Questions:
24X7 availability and assistance for your call toshiba laptops. Many Toshiba laptop users face issues in their laptop on a daily basis like issues in upgrading to the latest software, issues faced in opening the start menu, slowly processing pc or not optimally performing laptop, problem in signing in, facing audio and video issues etc. Toshiba support provides instant technical assistance by the help of their experienced technicians using advanced tools and techniques to troubleshoot all issues in minimum turnaround time. Toshiba support email is always available to help its customers at any time of the day and they even provide on-site support services. Toshiba technical support can be contacted through their toll-free helpline number +1888784-9316. They provide assistance over the phone, email or chat at affordable prices. In case you are facing issues in your Toshiba laptop you simply call our Toshiba laptop support , you can find out the cause of those issues by restarting your pc in the safe mode. Check for newer updates in your system. In case there are availability of updates then download them. If it doesn't resolve the issue then restart your device. Many issues are caused by outdated drivers, so in many cases updating the device drivers resolves the issue. If none of the above given steps helps in fixing the issue then create a new local administrator account as in many situations when we are not able to start a program, creating a new administrator account helps. If creating a new administrator account also doesn't help then reset your pc. Resetting your pc gives you the option of choosing which files you want to keep and which you want to remove before reinstalling windows. If you are facing any technical issues in your Toshiba device then you can contact Toshiba customer service tech support. In case your Toshiba laptop is not working properly after you recently installed an app, driver or update, you can try to resolve the issue by restoring from a system restore point. Restore points are created when an app, update or driver is installed. Using a restore point removes all the apps, drivers and updates after the restore point was made but it doesn't affects your personal files. For more clear and detailed knowledge and assistance regarding technical issues in your Toshiba laptops contact Toshiba customer support anytime.
Sep 21, 2018 | Toshiba Computers & Internet
See all Lenovo ThinkPad® T60 PC Notebook Questions
Lenovo ThinkPad® T60 PC Notebook Logo
227 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
