Question about Brother HL-5240 Laser Printer
Brother HL 5240 printer: Drum light flashing
What and where is the drum. Does it need replacing?
I don't have the instruction manual for this printer.
  • Brother Master
  • 990 Answers
You need to replace drum cartridge, when you buy one back ,look new one then you'll find out where is the drum.
Posted on Dec 16, 2008
  • Everett Lin Dec 17, 2008
    drum is a blue surface printing cylinder inside the cartridge,it need to replace whole cartridge.
How do I change the drum in my HL-5240
First check whether it is possible to buy a new drum for your model, if possible buy a new drum then remove the toner from your printer, separate the drum unit from the toner, if you check thoroughly the left and right sides of the drum unit how the drum has been fixed in to it you will be able to find the way remove drum from the unit, then replace the new drum and fix it. Don not tough the edge wiper blade, rotate the drum and check whether it rotating smoothly in both direction.
Mar 03, 2012 | Brother HL-5240 Laser Printer
Changed out drum and now need to reset the counter on HL-5240. How is this done?
Drum reset procedure on this model is quite simple. Just open front door, hold down the GO button until all lights are on, let go of button then close door. This will reset drum counter to 100%.
Thank You for using Fixya
Dec 23, 2010 | Brother HL-5240 Laser Printer
We have a Brother 5240. We inserted a new drum and toner and the drum light still blinks. Can you advise what the problem is. Thank you
Before you replace the drum you have to clear the error message. To do that you have to Make sure that the printer is turned on and the Drum LED is blinking. Press the front cover release button and then open the front cover. Press and hold down Go for about 4 seconds until all the LEDs light up. Once all four LEDs are lit, release Go.
Here's a link to the Brother website on how to replace the drum with images and instructions.
Dec 01, 2010 | Brother HL-5240 Laser Printer
How do you replace the drum properly on a Brother HL-5240
Out with the old and in with the new, you remove the toner and drum together, remove the toner from the old drum by pressing the blue lever on the side, install the toner in the new drum, and re install in the printer. With the front door open press the go button til all lights flash and then close the door, the new drum is reset.
Nov 20, 2009 | Brother HL-5240 Laser Printer
Brother Laser HL-5240 has a status light and toner light. Fuser was replaced but no help.
that error usually indicates that the toner has reached its end of life
or the drum is not properly installed.
i had one person who put the toner in but threw the drum cartridge away.
Jun 25, 2009 | Brother HL 5040 Laser Printer
The drum light came on (Brother HL 5240) and I replaced the drum with a new one and it still will not work... Any suggestions?
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Jan 20, 2009 | Brother HL-5240 Laser Printer
My Brother HL 5240 has Status toner, drum and paper lights on, I bought it on 4/30/08, new toner, plenty of paper, it showed on computer: printer is off line, but it was connected with computer. Really...
The drum light will flash on my brother HL-5240 Laser Printer when printing but it continues to print just fine. Does this mean the drum needs to be replaced?
Aug 07, 2008 | Office Equipment & Supplies
Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Jan 29, 2008 | Brother HL-5240 Laser Printer
Drum light blinks, drum and toner have been replaced
you need to update your machine after every time that you repleacing toner or drum
contact tech support of brother company or i can help you but it will cost you
Jan 02, 2008 | Brother HL-5240 Laser Printer
Brother HL-5240 Laser Printer Logo
1,009 people viewed this question
James Cagle
James Cagle
Jim Keysor
