Question about Amana Kitchen Ranges
Searching for control knobs for Amana Solid Element Cooktop CAKE30W2 or AKE30W2
  • Daniel Boulay Dec 16, 2008
    I found them on appliancehelp.com
I found, after 2 hours, that the knobs are available through Whirpool Parts Online !!
Part number: 307620W for the knob control and,
Part number: B5037602 for the cover control hole.
Posted on Dec 17, 2008
New knobs & pans
A good place to start is the local agent or manufacturer,
Apr 09, 2014 | Jenn-Air Removable Cooktop Grill - Part...
The left top element is not working, the control knob lights up but doesn't heat. Is it the element or the switch? Mod#JED8430BDB Ser#1414040011A Schott Ceran
It could be either. The only way to properly check is by dismantling the cooktop and checking the circuit with a volt meter or test lamps.
Feb 11, 2011 | Jenn-Air JED8430 Electric Cooktop
Why won't my amana smoothtop cooktop turn off. the know will not turn it off.
It's apparent the power relay - or the knob itself is faulty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | Amana ACT101E Electric Cooktop
I have an amana AKS30E gas cooktop and the ignitors are sparking approximately every 30-seconds on their own. I have checked all the knobs etc and each burner lights fine but with the gas off and ignitors...
I think it's more likely to be a wiring problem, either bad ground or loose connection on the controls of the spark module connector. Look carefully at the switches on the controls to see if they are asking for spark when they're supposed to be off.
Best Regards,
bruce
www.fixyourboard.com
Jun 19, 2010 | Amana AKS3040 Gas Cooktop
Short in knob
Replace the spark switch module on the bad burner.
Sep 29, 2009 | Amana AKS3040 Gas Cooktop
Water boiled over into control knobs for the cook top elements.
Just fixed this problem and repaired the corner of the Ceran cooktop.
Disclaimer: These cooktops run on 220V and will kill you if you don't know how to work with electricity. If you're unsure, get some help.
The boiling water slopped out of your pot, and went over to your controls (knobs) and went down the shaft and into a component call "Infinity Switch". The water caused the switch internally to weld one of the two internal sets of contact points into a permanent position. The fix is to replace the
"Infinity Switch" that the boiling water spilled into. The Infinity switch is the component that the control knob slides on to.
In my cooktop one of the infinity switches failed and appears to damage the adjacent switch. Mine actually caught on fire and damaged the wiring and the connector. Hopefully you are better off. Since they were in such close proximity I replaced them both. For $20 you might consider the same. I replaced both to be safe and they were $21.47 each.
My cooktop has 4 elements 2 small, 1 large and 1 combined (small and large) surface. A large element was definitely damaged and possibly a small element. I ordered both. I mention this in case a multi-element was damaged on your cooktop.
You will need to contact either Jenn-Air or someone. Since you can't see an exploded parts list online, you'll have to use the schematic. It is in a plastic sleeve and it stuck to the side of the ventilator housing underneath the cooktop.
When you wire the new part in, make sure you have the wiring correct or when you turn it back on you will burn up the new part.
I hope this helps.
Apr 02, 2009 | Jenn-Air JED8430 Electric Cooktop
Amana Electric Smoothtop Cooktop heat control knob.
1st remove the control knob by off position & pull it one by one then clean it by using vacium.tnx
Nov 16, 2008 | Amana Cooktops
Amana cooktop
Hello dishmama1, is this a sealed burner cooktop? If so then remove the cap and make sure all the holes are clean. Restricted burner holes can cause and issue with the flame. Also with it off make sure the area where it sits is clean and the cap sits flat. Hope this helps
Aug 09, 2008 | Amana AKS3040BSSCooktop
Kitchen Ranges Logo
130 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
