We are experiencing a problem with our Panasonic Model KX-F750 fax machine. After a rather massive paper jam the left side no longer prints. I cleaned the thermal head, but that did not help. Is it cost effective to replace the thermal head? We like the fact that this machine has a continuous roll paper supply because we receive faxes in various sizes.
    Sniper:
  • 87 Answers
If this is a film roll using fax.just change film roll with new one i am sure it will help.
Posted on Dec 16, 2008
Why is my fax machine jamming all the time
Dear
If paper jam always,check the thermal ribbon correctly installed (the ink coating face upward and should above the print head)
If document jam always, check the ADF roller (white roller clean it)
Thanks.
Feb 26, 2015 | Panasonic KX FP215 - Fax / copier - B/W -...
Panasonic kx-ft77 paper jammed and fax im memory
I have a problem with the fax machine in question is panasonic kx ft77 . When receiving a fax error expel warm up and stop receiving the document. Or does anyone know what the problem is and how to fix it ? Thanks in advance
Aug 16, 2013 | Panasonic KX-FHD331 Plain Paper Thermal...
I need a battery for a Panasonic KX F750
Panasonic KX-F750 Fax + Telephone + Digital Answering System and i need a battery and a manual
Jan 06, 2010 | Panasonic Lands Phones
My Panasonic Fax machine KX FHD331 is not receiving faxes ( it is on automatic) however, it is saying "memory full" and I cannot print what is in memory.
Make sure there is no additional error messages on the screen - they usually show in a sequence one after another - maybe paper not loaded correctly,or machine is jammed or out of thermal film.
Oct 03, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Paper jam in Panasonic KX-FHD331
from person who sending fax ' please eng. hany use it good
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
I have Panasonic KX-FL612 fax machine , the paper gets jammed and the fax is saved in memory . when i release the jammed paper I can not print the fax in memory . How can I print the fax in memory ?
when fax gives msg ,fax in memory,just remove jammed paper .put fresh papers in tray.if the msg is coming on screen that fax in memory just press START key.there is a green button labeled as fax start .u will receive all faxes in memory.MIAN AKHLAQ .do not forget to rate the solution.
May 13, 2009 | Panasonic Office Equipment & Supplies
Panasonic kx-fp155 not printing
problem is not clear.u change fax roll when it was finished.if fax was printing before ending roll .i think u have installed roll with wrong side .thermal roll only prints with one side which is coated .just see inside machine there will bi a paper for installing roll direction.if not just check thermal head .clean it check its supply.or just replace.it mian jee
Jan 13, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
Fax machine does not print on the right side of paper
Probably the thermal head is bad. It's a spring loaded bar inside of the fax machine. You might be able to shim it closer to the paper on the bad side.
Oct 20, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Paper jam and fax in memory
Just unplug the power cable in your machine and put it back again.The paper jam will clear but...also the fax memory will be clear at the same time.just tel the other line to re-send thier fax again.
Oct 04, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
112 people viewed this question
k24674
Marvin
Marvin
