Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
I have a top-mount refrigerator that is leaking from the air vent
It is leaking water in a steady stream from the air circulation vent from the freezer to the frig. It does it when I think it goes in to defrost mode. There is no water in the evaporation pan under the frig however.
  • 5 more comments
  • alan746 Dec 28, 2008
    Dear "Guru", can you explain where the drain hole is located from beneath? We're having the same problem, with water dripping from the top freezer onto the top shelf and elsewhere in the lower fridge.
  • raschmidt Jan 05, 2009
    I've been using this method of clearing the drain tube for over five years; once a year like clockwork. But is there a BETTER solution than this? Why doesn;'t it just condense and drain like all good fridges? It's a Whirlpool Designer 21 fro 8/1996.
    Thanks, Rick
  • pwrrakr Jan 17, 2009
    show picture of where drainhole is inside whirlpool refrigerators freezer. mine is clogged.
  • Anonymous Jan 30, 2009
    I have a model ET1CHKXKQ01 manufactuered in 2002. I have that same problem with drainage of water. My question is access to the drainage tube from the bottom. After allowing this to thaw for 24 hours, do I have to remove a panel from the back?
  • mitch_kellyh Feb 09, 2009
    Please tell me where drain tubing is to unclog it
  • Anonymous Mar 26, 2014
    defrost water leaks into frig
  • Anonymous Mar 30, 2014
    only water seen at the wheels area in front. all dry in back
I had the same problem with a whirlpool refrigerator with freezer on top. TURN OFF & UN-PLUG IT. To access the freezer drain you must pull the refrig out from the wall and take off the bottom-back panel, it uses some (7) small nut headed screws. The drain is the white tube on the left going into the drain pan. You can push a long wire or plastic hose up the tube, however that will probably only hit something solid (ice) and blowing air may not clear it, until you let the freezer completely thaw out, which may take several days. The following may help experienced do-it-yourself nuts, it is not for the faint of heart! I took out all the freezer items and placed them in coolers to keep them frozen. Then removed the back panel in the freezer, two nut headed screws at the top center. The bottom of this panel was frozen to the bottom of the freezer compartment, so I used a hair-dryer to thaw it enough to loosen it. (Be careful: water and electricity do not mix well!) The left side of this panel has some electrical control wires attached, so the left side will not come out, just rotate the panel and lean it against the left side of the compartment. Now use the hair dryer (or pour hot water on it) to melt the ice along the bottom back of the compartment under the freezer coils. BE CAREFUL: The fins are sharp and will cut! Do not bend them. If they are all frozen up your heating element-defroster may be out. If there is only ice along the bottom, the hair-dryer or hot-water will help melt it to the point it can be removed. If the drain hole at the back-bottom-center-right is plugged with ice, poor hot water on it to speed up its melting. The hair drier will not do this very fast and you cannot chip it out without damaging the plug hole. Mine was solid ice about 2 inches into the tube and hot water finally thawed it. Then pour water through the hole to flush it out. Clean the bottom drain pan & re-assemble. Good luck.
Posted on Dec 30, 2008
Could someone show picture where drain hole is inside freezer
Posted on Jan 17, 2009
  • 943 Answers
HI thanks for the question The drain tube Is clogged up . You have to turn fridge off for 24 hrs . Because the drain hose goes down to the drain pan , it goes between the walls. So you cant access it to clean it out Get a small hose and push It up the drain tube from the bottom ,and blow Up the hose to clear the debris
Posted on Dec 16, 2008
Why does my refrigerator circulate on bottom but not on top
Is this is a bottom mount fridge? Hey if your fridge is a fairly a new one. Say less than 8 years old and a fancy one then this is how it works.
a) Fan in freezer circulates air. Mainly to the freezer compartment.
b) Then for the fridge compartment there is a Vent door operated by a vent motor.
Either this vent motor not working and opening, or it is frozen or the thermister that controls the temperature on Fridge compartment is not asking for cooling and thus not sending power to the vent motor to open.
Sep 09, 2014 | Sub-Zero Refrigerators
Celtic boiler parts diagram
Air will rise to the top. I would replace the vent on top of the pump.
Apr 10, 2014 | Water Heaters
Condensation water build up inside refrigerator
The tray underneath your fridge is probably clogged, and overflowing. There is an evap tray underneath, and if it does not get adequate airflow, it will overflow, and leak out.
Clean the bottom front vents, and underneath the fridge to ensure adequate airflow.
Mar 31, 2014 | Sub-Zero Refrigerators
Bad coolant w/ leaks from many places, overheated and shut off, heater doesnt blow heat anymore
After the engine has reached normal operating temperature, feel both heater hoses going into the firewall. Are both hot? If both are hot, it's probably the door or doors in the heater case not operating from the selector knob on the dash. If only one hose is hot, the coolant is not circulating through the heater core. Look for a water valve in the hoses that is shut. If no valve, crack open the cold line to see if you can start circulation through the core. If neither hose is hot, pull off the inlet to the heater core (it may come from the cylinder head area) and run the engine and check stream flow. It won't spurt out like a garden hose, it should flow out in a smooth even stream, maybe just enough pressure to push a steady stream. If no flow comes out, coolant is low, or there is a circulation problem in the engine, like a kinked hose, a weak water pump...
Does the radiator cap hold pressure in the cooling system?
Feb 08, 2014 | Cars & Trucks
Drain and refill of New Yorker forced hot water furnace
Draining is the easy part. Isolate the water feeder (shut off). Open hose bib @ boiler, & open the expansion tank valve to pull air in to allow more water out.
Refilling- let the water feeder fill -should be around 12 Psi, then go around the building to all the baseboards or radiators & open the bleeder key valves to let the air out until you get a steady stream of water. Most of the air should work its way to the expansion tank. Turn the boiler on & test your new pump.
Nov 12, 2013 | Heating & Cooling
GE not cooling properly
If you have changed temp and adjusted vents, then either your temp sensor may be faulty or thermostat itself may be faulty. Check compressor to make sure it is pumping and there is no freon leaks.
Jul 09, 2009 | GE Profile Arctica Stainless Steel Top...
I have a rm2611 refrigerator which has lights, no fan
There's a capacitor by or on the compressor that probalbly needs replacing. This is the cheapest route .
Jul 05, 2009 | Dometic RM2620 Refrigerator
Frdge not getting cold
Since your unit will have only one compressor, the cooled air must be circulated via a fan that distributes the air between the two compartments and this has probably died. This allows the cooled air to simply fall downward. When you can hear the compressor running, hold your fingers in front of the vents in the refrigerator compartment to see if you can feel any air stream.
Jun 07, 2009 | Maytag MFF2557KES 25 cu. ft. French Door...
Moisture
Are the air vents blocked in the refrigerator? Remove any
objects from in front of the air vents. See "Ensuring Proper Air
Circulation" for the location of air vents.
Are the door(s) opened often? To avoid humidity buildup,
try to get everything you need out of the refrigerator at once,
keep food organized so it is easy to find, and close the door
as soon as the food is removed. When the door is opened,
humidity from the room air enters the refrigerator. The more
often the door is opened, the faster humidity builds up,
especially when the room itself is very humid.
Feb 19, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
227 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
