I can't hook up the way it says to
It tells me to hook up wall jack to DSL to fax to modem. the DSL line won't hook up to all in one
    Genius:
  • 2,120 Answers
Fax machines need an RJ-11 phone cord and are ANALOG
DSL uses RJ-45 and is DIGITAL.
Don't waste your money on a DSL filter, they won't work reliably.
Posted on Dec 16, 2008
HI, I CAN SEND MY FAX TO THE OPPSIT PARTY BUT I DONT RECEIVE ANY FAX, WHEN THE PARTY SEND ME, AS THE PARTY GET THE REPORT AS WE HAVE RECEIVED THE FAX,,,,,,
Please be sure that you have the fax line in the correct jack on the back. Some of the HP modems will actually send a fax if you plug the telephone cord from the wall into jack that is supposed to have a telephonep plugged into it. On the back of the 1522 there are two phone jacks, the upper one is where the cord from the wall plugs in. Also ensure that if you have DSL service that you have a filter in the line for the modem.
Mar 03, 2011 | HP LaserJet M1522nf Multifunction Printer...
What to do if dsl light is blinking
This likely means that your DSL modem is not trained up with the DSLAM. - Geek talk for your modem is not connected to the phone company's equipment properly.
1.) Remove power from the modem
2.) Remove all devices (including the DSL modem) from all phone jacks in the house.
3.) Add the DSL line back to the wall jack, taking care to plug the wall jack into the correct jack on the DSL line. (Do not use a DSL filter on your modem!)
4.) Power up the modem/
Still not working? Continue...
5.) Try a different phone jack
6.) Try a new phone cable between the wall jack and modem
7.) Call the phone company for further assistance.
Dec 18, 2010 | Siemens SpeedStream 4200 (13A4200001)...
I have a Arris Modem from time warner cable, no i
do you have dsl filter where the phone line comes out of the wall and goes into the Router.
https://en.wikipedia.org/wiki/DSL_filter
Mar 26, 2017 | 2wire (1000-000057-000) Modem
I am trying to use the fax facility on my epson600fw.my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
How to connect the telephone lines
Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
i.e is fax line ) or the usb port in the computer ...
Good luck...
Feb 02, 2009 | RCA 25201RE1 Corded Phone
I can only fax my header
Make sure that you are not running on a digital line, on a digital phone system, or using the same line as a DSL modem. This is essentially any phone that uses the same number, not just the jack in the wall. Newer modems use similar frequencies to DSL and digital phone systems even when you are running equipment to scrub the line so they are not compatible and will often interfere with one another.
Nov 29, 2008 | Dell 962 Photo All-In-One InkJet Printer
I have a MCF LC-51 series fax, and scanner I cannot fax or recieve.
check for a dial tone using a regular phone plugged into the wall jack.
make sure the phone cord is hooked into the LINE jack on the machine
make you do NOT have a DSL line.
Sep 02, 2008 | Brother Office Equipment & Supplies
No filter
There you go. Stop by Radio Shack and pick up a DSL filter and hook it up to the wall outlet of your fax machine. If the DSL modem is next to your fax machine, plug the fax machine into the outlet marked as phone.
I just got done doing this to both of my offices. Typically the phone company will use your fax line to piggyback the DSL. All you have to do is make sure your DSL modem output goes to the fax line either through the wiring block in your office or directly to the back of the modem itself.
That way you won't need the filter.
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Ethernet cords
The cord that plugs into the DSL filter is a phone line and the other end plugs into your DSL modem. Also, every other jack that has a phone or fax or answering machine or caller id box has a DSL filter as well, in between the jack and the device.
May 01, 2008 | Kensington Portable Ethernet Cord (33052)
Brother mcf-440cn
Jacki
 Must have DSL filter attached before fax, not sure how you are saying you have it setup, but phone line should come from wall then to filter then to fax socket marked line, phone should be hooked to socket on fax marked EXT, if you dont have dedicated fax line then fax number will be same as phone no.
If you have Adsl then there will be a lead from wall that splits into two, one goes to your modem (ADSL) and the other marke phone or line needs to go to fax socket marked LINE
Oct 21, 2007 | Office Equipment & Supplies
49 people viewed this question
jasbo
jasbo
