Question about Yamaha CDC-845 5-Disc CD Changer
Door to load cd's wont open or close without help.
The 5 disc door and retractable turntabel wont' open or close without prying the door edge and pushing shut. I can hear the motor run but just won't open or close. Could it be a belt? If so where to get the correct replacement belt?
    Genius:
  • 1,175 Answers
Hi...
I use a place called
www.studiosoundelectronics.com
or
matelectronics.com
Studiosound will even tell you how to measure your belt if you need to
Godspeed,
Scott
Posted on Jan 08, 2009
  • 71 Answers
Have the loading belt changed this will sort it
Posted on Dec 17, 2008
2 Suggested Answers
  • 5 Answers
SOURCE: Door to load cd's wont open or close without help.
hello i have had the same problem with my 5 cd changer,i way i solved this was to turn the player top slide down then do this care fully ,shake it gently and see if a cd came out of it, groove sit in the player.if you hear a rattle than there is a stray cd in the device. you have got to shake the cd to the front of the cd dawer to take it out with a thin ruler or a butter knife but be care ful with the knife preess on the open button wale trying to slide the butter knife between the stuck cd and the inside of the cd sit cation be care.
Posted on Apr 25, 2009
Y can't open the door of my 5 cd system
Disc loading mechanism fault. Contact any service technician. The loading mechanism should be taken out for repair. It is a skilled work. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 03, 2014 | Venturer RCA 5-Disc CD Audio System w/...
My dics dor to its changer wont close
open it up
the tray has somthing stuck init
Mar 02, 2010 | Sony CDP-C445 5-Disc CD Changer
Disc door will not retract
push that mother back in there! my ps2 is exactly opposite, it ejects than quickly retracts back into the ps2, i dont even think there is a solution without cracking the ps2 open
Feb 07, 2010 | Sony PlayStation 2 (PS2) Console
The cd door hangs and won't open without assistance
the belt may be streched so you may need to get a new belt.
Jul 02, 2009 | Yamaha CDC-565 5-Disc CD Changer
MAYTAG NEPTUNE DOOR LOCKED WILL NOT OPEN!
The comment posted 14 may 2009 it what helped me. DO NOT PRY OPEN the door. Find the release cord inside the soap dispenser,,,you may have to remove the 4 screws and lift it from the washer like i did. I had to lean into the door and pull the cord to release the lock. It was not a system error. The washer was over loaded and although the door was closed and locked...the load pushed the door enough to indicate that it was open and would not wash. After opening the door, rearranging the load and removing some, the door closed and latched locked and was able to continue with the wash. DO NOT PRY OPEN,,,use the cord release first,,,this worked for me.
May 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Apr 25, 2009 | Audio Players & Recorders
The platter got stuck in the open position.
Drive belt for door and for platter need replacing
Jan 06, 2009 | Harman Kardon FL8385 5-Disc CD Changer
Replacement for the spring loaded door on my tower
No solution for this. All cd players are non repairable or at least not cost effective to repair. My advice is to just purchase another one. Cost for these is now in the $40.00 range - cheaper then getting this one fixed
Dec 30, 2008 | Compaq Presario SR1050NX (DW257A) PC...
CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Dec 21, 2007 | NAD L40 CD Player
Yamaha CDC-845 5-Disc CD Changer Logo
547 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
robert landry
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
