Question about HP Pavillion ZV6000 Notebook
Randomly shutting down
I have had a recent problem with my notebook randomly shutting down. When im on the battery it seems to shut down very easily and when i am plugged in and i play a game or watch a video it will shut down. if you could please tell me what the problem is and how i could solve it, it would be greatly appreciated. thanks. I have a zv6000, and I know its over heating. This seems to be a common problem. What is the cause for this? Mine also has a AMD Athlon 64 4000+. If anyone can help please email me at tuckablaze@gmail.com. Thanks -Dan
  • tuckablaze Dec 17, 2008
    I did install MobleMeter to check CPU temps.
    The program showed my CPU speed at 2.4gz and temp was 0.0C discharge was 0 and HDD showed something like 16.0C...
    What would cause it not to read my CPU temp?
    Problem Solver:
  • 13 Answers
The cause of the over heating is poor manufacturing and weak cooling designs. HP for years has had consistent issues with their cooling design which still baffles me to this day. If you were to open the HP you would notice immediately that the cooling design for the GPU (Graphical Processing Unit) and the CPU (Central Processing Unit) are minimal and even look way to weak to cool the system properly under heavy work loads. Most of the HP's are designed for a quiet experience, which means the fan doesn't move as much air at times as it needs to, not to mention the heat dissipate they tend to use actually burns off after a certain amount of time.
Think of the effects of driving a 4x4 truck through a desert with half your radiator fins missing - it's going to cool the engine but not nearly enough.
Happily sir there is something you can do to improve your overall experience with this issue, laptop coolers. They range from cheap to expensive and can help remove massive amounts of heat off the bottom of the laptop (which is where the heat needs to be removed). They help cool your CPU, GPU, memory, Chipset, and save you from burning your legs.
You can find an excellent selection of coolers from:
http://www.xoxide.com/noco.html
I personally use a nbcooler
-250mmfan-black.html">http://www.xoxide.com/enermax-aeolus-alum-nbcooler-250mmfan-black.html on my personal Laptop, an Asus G50V and experience fantastic results.
An alternative is to buy some heat dissipater and open the laptop to apply it to the trouble areas I mentioned above, however unless you are experience with this course of action I advise against it and suggest a cooler.
Posted on Dec 16, 2008
    Scholar:
  • 188 Answers
It sounds like your fan and cooling system may be malfunctioning. If the computer start and runs well for a little while it sounds like a heat problem. Laptops have safety features built in for excessive heat.
My Iphone4 Randomly keeps shutting down & will only come on when I plug the charger in.
You need to replace the battery, regardless of the indicator bars.
Jan 18, 2017 | Miscellaneous
My dv9000 keeps shutting down randomly, I have a cooling fan underneath and it is not hot.
probably a bad sector in the hard drive. hat will cause your problem Hard drives are good for a 5 to 10 year average if used everyday. If the computer is switched off without going through the normal proceedures of shutting it down will decrease the life span as well
Jan 08, 2011 | HP Hewlett Packard Pavilion DV9000Z 17"...
I have recently bought a sciphone i9 and I have two problems - the first is that it randomly seems to shut down or turn off. Normally will not turn on again until plugged into the mains for a couple of...
Avoid buying Sciphone - they ****. Battery lasts 1 week if you are lucky. Wifi doesn't work. You can't delete useless icons. Won't connect to internet. Don't waste your money on this junk
Aug 14, 2010 | Cell Phones
Power is erratic. Shuts off randomly.
it could be caused by a lot of things. isolate it first. since its randomly shutting down, try first in normal mode. does it heats up before it turns off, if yes its an overheating issue. you may need to replace fan or even motherboard of your pc. have you checked your battery? is it properly seated? or is the problem happening when your system is plugged with the ac adapter? try to check the power cable.
Apr 06, 2010 | Sony VAIO VGN-T350P/T Notebook
My acer aspire 5735 randomly shutting down
Try taking out your battery it might be shorting out just run your laptop from the adapter and see how long it lasts before it shuts down
Feb 22, 2010 | Acer Aspire 5735 Notebook
Cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
Hi katrina1331, From what you describe it could be a couple of things but the two the come to mind first are power and perhaps overheating. The fact that you can?t run on battery power very long would suggest it can?t hold a charge or much of one or the AC power adaptor or charging circuitry aren't working correctly. To proceed I need to get some more information from you: Are the A/C adaptor and the battery the original ones and how old is the laptop? There are several LEDs on your laptop, (we?re going to ignore the touchpad light and the wireless LED), a power/standby LED to the top left of the keyboard three just below the touchpad. The left LED is another power/standby LED, the hard drive LED in the center and the battery LED on the right. -What are they doing just before the shutdown and immediately after while running on A/C power? -What are they doing just before the shutdown and immediately after while running on battery power? Try running the laptop with the battery removed and the A/C adaptor plugged in. Do you notice any change in running time? With the battery and A/C power plugged in click on Start, Settings and then Control Panel. Find and double left click on power options. A box labeled Power Options Properties will open, click on the tab labeled Power Meter. It should indicate the battery is at 100% or that the battery is at some percentage and that it is charging and running off A/C power. Let us know what you find. When you first start up the computer run your hand along the bottom of the laptop, especially along the four screened vent areas, to roughly gauge the laptops temperature. Use the laptop in a way that causes it to turn off and then run your hand along the bottom surface again. If the laptop is hot, to the point where it is uncomfortable to touch, then overheating may be a factor. Let us know what you find out and we?ll continue.
Jan 06, 2007 | HP Pavillion ZV6000 Notebook
HP Pavillion ZV6000 Notebook Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
