Question about Dryers
I have a creda t 601cw, drum intermttently not turning i have aquired new motor brushes and removed side panel but although i can see motor i cannot see the brushes in-order to change them any help/ ideas ?
  • 3,463 Answers
Tumble dryers do not normally have brushes in the motor.
I would look elsewhere for the problem.
Posted on Dec 16, 2008
How to replace belt on Creda T620 CW Tumble Dryer
Remove the back panel quite a few screws, once of the belt can be seen, mind your fingers (use hook on metal coat hanger or the like) and roll the drum slowly with the hook under the belt directing it off the drum, refit is much the same as removal although special care should be taken not to nip the belt, fit to small pulley first on motor then turn drum slowly gradually rolling onto the drum mind the fingers and obviously make sure machine is off.
Nov 28, 2013 | Washing Machines
It makes a noise as if its spinning but the drum doesnt go round
Hi,iI have just had the same fault, and as described elsewhere, the solution was to replace the motor brushes. I would say this took 1/2 - 3/4 hour to remove brushes and same to replace.
How:
1.DISCONNECTED ELECTRICITY SUPPLY
2. Disconnected water
3. Removed the 1 screw from back panel, removed panel to get access to remove belt.
4. Lay washer on it's side (2 people recommended)
5. From underneath machine, unscrewed 2 bolts on the motor (back of the machine)
6. Holding the motor so it did not fall and get damaged, carefully tapped end of motor to unmount it from holding pegs (slides towards back of machine)
7. Noted how the plastic cover fixed to motor, then snipped tie wrap holding it to motor.
8. Unplugged connector and earth connector.
9. Carefully removed connector on each brush.
10. AS THE BRUSH WAS SLOWLY WITHDRAWN, checked the orientation of the bevelled edge of the brush relative to the motor so the new one was fitted correctly (the end of the brush is angled so it sits flat against the motors commutator)
11. Replaced brushes and refitted in reverse order.
Take care
Jun 03, 2010 | Creda W120VW Front Load Washer
Washing machine drum doesn't turn or spin
Hi. I have just had the same fault, and as described elsewhere, the solution was to replace the motor brushes. I would say this took 1/2 - 3/4 hour to remove brushes and same to replace.
How:
Oct 19, 2009 | Bosch WFL 2062 Front Load Washer
Creda eco washing machine won't spin
It sounds like it needs new carbons fitting in the motor.
It is a fairly straightforward repair.
Remove the top cover, screws at rear, and slide top cover off towards the rear.
The motor is located at the top right right rear, you will see the drive belt.
Slacken the bolt that holds the motor, and push the motor down towards the top of the drum.
You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic`lug that holds the brushes in place, slide the brushes out of the motor.
fit new genuine Hotpoint carbons, and follow instructions on packaging. Push the leads back on to the carbon terminals.
Tighten up motor, and make sure the belt is reasonably tight.
Job done.
Test on final spin before you refit top cover.
Plz rate my solution.
Thanks.
Dec 23, 2008 | Washing Machines
How to fit a belt to a creda tumble dryer
open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Oct 30, 2008 | Dryers
Creda J1000 Front Loading Washer
Try to change the motor .....http://youtube.com/watch?v=TTSCs3kd74k
May 16, 2008 | Washing Machines
Drum not turning
Hello
If you look at the motor which of course is on the top right of the drum. you will see either white or black palstic parts inserted eiterh side and a wire connected to them
These are the brush holders for the carbon brushes.. These have worn out and need replacing easily done just get yourselfthe parts and remove the old one and replace with the new ones....
Jan 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Creda
remove the rear panel screws, remove side panels, pull drum backwards, slide belt down front of drum and under, refit rear panel screws refitting drum at the same time, place belt around motor spindle and reasemble, job done.
Dec 24, 2007 | Washing Machines
it is the carbon brushes in the motor. there cheap and easy to replace. go on give it a go
Dec 11, 2007 | Creda W100FW Front Load Washer
Dryers Logo
65 people viewed this question
Top Dryers Experts
