Question about Canon Rebel XT / EOS 350D Digital Camera
My 94 honda accord ex
Hey i got a 94 honda accord ex and i got 2 fill the clutch fluid every day and one day it went bone dry and now its stuck 2 the floor but i can move it with my hand up and down but if i slightly push on it it goes stright 2 the floor
thank for your help
    Problem Solver:
  • 10 Answers
Your clutch master cylinder just went out
Posted on Jul 15, 2009
1991 honda accord ex where does clutch fluid go
this is a 1991 honda EX engine bay
on the firewall
the smaller reservoir next to the brake master reservoir
Nov 03, 2016 | Honda Cars & Trucks
Why does the clutch petal stay stuck to the floor in my 94 honda accord?
They will usually have a bad slave cylinder or clutch master cylinder. See if you see any leaks at those parts. The clutch master cylinder may leak on the back side so you may have to look underneath the dash to see it. Fill with fluid and pump pedal, have someone look while pushing on pedal. It will be wet from the leaking fluid.
May 28, 2015 | 1994 Honda Accord
1996 honda accord 5 speed transmission stuck in gear
Let's look at your slave cylinder and your master cylinder.
Under the hood of your car are two master cylinders, and physically, they are close together.
They are found right in front of you as you drive the car, except they are under the hood and about chest high.
My 1990 has them right along side one another.
The brake master cylinder reservoir is about 4 inches in diameter, the clutch master cylinder reservoir is about 3 inches in diameter. Both of them take quality brake fluid.
Sounds like your clutch master cylinder is dry of brake fluid.
It would be nice if all you had to do was to add brake fluid to the "fill" line, but then you'd have air in that system, and it would need to be "bled" to work.
If you do find the brake fluid low, very likely the slave cylinder needs replacement, as your car is the right age to need this.
Be blessed.
Mar 18, 2013 | 1991 Honda Accord
97 honda Ex Accord Standard Transmission. Having problem shifting into 1st or reverse when starting up car. while going down road it shifts fine. week prior same problem, told son to check fluid level,...
problem is in the hydraulic clutch system
low fluid indicates a leak at the slave cylinder and not holding pressure indicates a leak at the slave cylinder or in the clutch master cylinder
If the master cylinder and slave cylinder have not been replace in side 5 years ago , the have them replace by a specialist brake and clutch shop
at this point there is nothing wrong with the clutch proper
Nov 27, 2017 | 1997 Honda Accord
Automatic transmission will not shift sometime and stay in D4 and sometime willwork 2or3 days just find. Honda Accord 1992 4 speed 2.2L EX
I would perform a drain and fill on the transmission fluid. This is supposed to be done more frequently, say every 30,000 miles. It should take somewhere around 3.5 quarts when refilling, start with 2.8 quarts, then check and add as necessary. Keep in mind, you are having issue with the shift quality, and it could go one of three ways ( stay the same, get worse, get better ). It depends what you are draining out, really. ( bad/worn fluid, clutch material ). Too, make sure to use Honda fluid. It is expensive, but when you are having issue, you don't want that as a variable ( wrong or after market fluid ). There is a drain plug ( sometimes two drain plugs - one lower than the other ) that takes a 3/8 drive wrench. The fill is a dipstick and you check while car is off and in park ( different than other cars ).
May 17, 2010 | 1992 Honda Accord
Is there a way to adjust the clutch on a 1992 honda accord 2 door EX
I am sure it is self adjusting,it is a fluid clutch,no adjustment,the clutch assembly needs replacing.
Jan 25, 2010 | 1992 Honda Accord
I have a 94 Civic...the last couple of days the clutch has been sticking and not goin into gear..this morning it stuck to the floor and i had to manually pull it back up and stomp it down to get into...
You could have a fluid reservoir for the clutch. This should be located somewhere under the hood. Make sure is has plenty of fluid in it. If not, fill it to the full line.
This is likely just a temporary fix. If you are losing fluid, something else is probably going wrong.
Oct 14, 2009 | 1994 Honda Civic
Will not go into gear(manual)
Pretty good chance it's the clutch but check the clutch master cylinder and slave cylinder for leaks (also line between). A drastic change often is caused by failure of either component...generally if clutch fails, it is a gradual process (similar to how a brake pad wears)
Apr 03, 2009 | 1991 Honda Accord
Canon Rebel XT / EOS 350D Digital Camera Logo
44 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
