Question about Dell XPS M1530 Notebook
Up, down, right arrow keys wont work
2 year old spilt juice on the keyboard,not enough to fry the Comp, but now the arrow keys dont work, they also make a crackling noise when pressed is there anything i can do?
  • rach652 Dec 13, 2009
    LOst arrow right key
I have a Dell xps m1530 . I lost the right arrow . how do i replaceit on my warranty
Posted on Dec 13, 2009
    Sergeant:
  • 324 Answers
2 year olds, a cup of juice and keyboards are not usually a good combination,as you have found out!
Well, the most obvious fix is to replace the keyboard, but I'm sure that you have already thought about that..
A work around is to attach an external keyboard, but that kind of defeats the purpose of a laptop, doesn't it?
Keyboards that have suffered this kind of damage can sometimes be recovered, however it is a somewhat delicate process. Not rocket science but some common sense needs to be applied. Were you to to decide to attempt this, the following might be of some help.
1) Remove the keyboard from the laptop.
2) Hold the keyboard over the sink with the affected corner down and keep it in this position during the entire process..
3) Allow fairly warm water to flow over the problem area for a few minutes.
4) If you have a soft bristle brush available, you might want to try to gently apply a soap & water mixture to the area. Work it under the affected keys and rinse well with warm water.
5) Blow as much water as possible from under the keys.
6) The judicious application of a hair drier will help get things dry a little quicker.
Will this really work? Probably 85-90% of the times that I've tried it, it has helped the situation.
What are the chances of my destroying the keyboard? Actually pretty low, if you don't get water all over everything and dry everything well. Keep the water limited to the affected area,only.
Do I recommend using this process? That's up to you. I have no idea what your abilities are or how mechanically inclined you are. You have to decide for yourself to assume any risk.
Hope this has helped and have an excellent day!
Ron
Posted on Dec 16, 2008
    Scholar:
  • 188 Answers
You need to replace the keyboard.
You're lucky that is the only problem.
You can go online to the Dell web site and forums, learn were youcan get a new keyboard and maybe even replace it yourself. If you feel uncomfortable and don't know a friendly computer geek, itl need a qualified computer techie.
    Problem Solver:
  • 13 Answers
Most Dell laptop keyboards can have their keys easily removed if pull up on the top of the key, only pull on the top of the key otherwise you risk breaking the base the key plugs into.
From there you can better view if there is possible damage to the keys in question. Its more likely that you will need to request a keyboard replacement from dell than it is you will be able to get these keys working again. Under the keys is a small plastic base that clips to the keyboard and a rubber button that helps the keys pop up and down.
I would guess that the juice has gotten under the rubber button which covers the circuit board of that particular key node and short circuited it. If you are going to try to clean it be very careful, remove the batter and the AC adapter and let the machine sit for a short while to make 100% sure that the power has dissipated.
You will need a light adhesive to put the rubber button back on to the board after you use a non-acidic compound to try to remove sticky juice off the board. Do not use water, do not use harsh cleaning chemicals and do not use goo be gone. My suggestion is to wet a paper towel with nearly anything deemed child safe (which as those kitchen disinfecting wipes) to try to remove it.
This is all just to try to save you a little bit of money so you might not have to purchase a new keyboard. It's important to be very careful and optimisitc, but don't get your hopes to high. Electronics are very subjectable to failure when introduced to liquids, though at times they can still be recovered.
Hope this helps.
Chase
    Problem Solver:
  • 17 Answers
Buy a keyboard, it will cost about $25-$75 and you can replace it yourself.
Otherwise, use an external.
Gateway NV59hu series laptop keys stop
have you spilt something onto the keyboard at all?
Sep 27, 2013 | Gateway Nv57h57u Laptop
Some of my keys on my laptop are not working.
Replace the keyboard with a new one. Laptop keyboards are not that expensive.
Make sure that the replacement is compatible with your computer. To know more about it, please visit the website of your computer's manufacturer.
You can also try a USB keyboard to check if the non-working keys work with the other keyboard.
I hope this helps!
David
Mar 29, 2013 | Compaq Presario Cq57 Notebook Pc
I spilled juice on my Toshiba L505 s5993 laptop, and now the keyboard will not work. Please help.
Wow, bad luck day. immediately flip the laptop upside down in an open position so the keyboard is flat on the table use some paper towel under the keyboard... more comments. to follow... do this immediately
Aug 30, 2010 | Computers & Internet
I spilt alcohol on my laptop and now the keys dont work
replaced ur keypad from the nearest hp service centre.
Apr 25, 2010 | HP CPQ175KB Keyboard
I spilt a glass of juice over my husbands keyboard and now it wont work properley! can i have this repaired for him or shall i just buy a new one?
Hi, Jenny.
If you are talking about an external keyboard, it's not worth repairing and easy to replace. A keyboard on a laptop is more difficult to replace, but also not worth repairing.
Since juice is acidic, the circuitry on the keyboard is probably destroyed.
Hope this helps.
Oct 04, 2009 | Microsoft Computers & Internet
Right arrow key permanently 'pressed' down
Only solution here is to unplug the keyboard from the mother board. Just take apart the case and look for the ribbon cable going from the keyboard to the motherboard, and take it out.
Please rate, thanks!
Apr 15, 2009 | Acer NSK8458AN Keyboard
Monitor is vertical display instead of horizontal display
the keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
Feb 25, 2009 | Dell Computers & Internet
Water Damage
Microsoft's keyboards are notoriously susceptible to this -- it seems like sneezing on them will damage them. I went through several of these keyboards, even attempting careful repair, before hanging it up. Not good news, I'm afraid -- I suggest Logitech products which my students can't even break.
May 28, 2008 | Microsoft Natural Ergonomic 4000
Viewsonic Tablet PC keyboard issue.
Try reseating the cable that connects the keyboard first.
If that doesnt help there may be liquid around the connector and it needs to be cleaned off to keep the circuit from shorting out. You will need to find someone with the appropriate chemicals and may have to take the laptop further apart to clean it all up.
This is why when anyone gets a liquid spill i recommend getting it torn down right away and cleaned up, as it can damage things you cant even see. If the liquid has been in there too long it may not be repairable.
Dec 21, 2007 | HP Pavilion dv4000 Notebook
Dell XPS M1530 Notebook Logo
2,058 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
