When printing paper continues to jam. - Office Equipment & Supplies
    Guru:
  • 829 Answers
  1. Take out paper tray 1.
  2. Remove any jammed sheets of paper you find there.
  3. Once you have done this, reinstall the paper tray and try printing again.
    Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
  4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
Posted on Dec 16, 2008
jackboy
  • 2985 Answers
SOURCE: Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Posted on Oct 02, 2007
  • 12 Answers
SOURCE: continuous paper jam when i try to print
Hi ,
Follow the steps below -
1. check the media / paper compatibility. It sould be as per hp :
Paper tray capacity Type Weight Capacity Input tray Capacity Output tray Plain paper 60 to 90 gsm (16 to 24 lb) 150 50 (20 lb paper) Legal paper 75 to 90 gsm (20 to 24 lb) 150 50 (20 lb paper) Cards 200 gsm (110 lb index max 30 30 Envelopes 75 to 90 gsm (20 to 24 lb) 20 10 Transparency film N/A 25 25 or fewer Labels N/A 30 30 4 x 6 inch (10 x 279 mm) Photo paper 236 gsm (145 lb) 30 30 8.5 x 11 inch (216 x 279 mm) Photo paper N/A 20 20 Paper sizes Type Size Paper Letter: 216 x 279 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm
A5 148 x 210 mm
Executive: 184.2 x 266.7 mm (7.25 x 10.5 inches) Envelopes U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches) Transparency films Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm Photo 102 x 279 mm (4 x 6 inches)
127 x 178 mm (5 by 7 inches)
Letter: 216 x279 mm (8.5 by 11 inches)
A4: 210 x 297 mm (8.27 by 11.7 inches) Labels Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm Custom 76 x 127 mm up to 216 x 356 mm (3 x 5 inches up to 8.5 x 14 inches) Print margin specifications Paper size Top Bottom US Letter
US Legal 1.8 mm (0.07 inch) 3 mm (0.12 inch) ISO A4
ISO A5
JIS B5 1.8 mm (0.07 inch) 6.0 mm (0.2 inch) Envelopes 1.8 mm (0.07 inches) 14.3 mm (0.5 inches) Cards 1.8 mm (0.07 inch) 6.7 mm (0.3 inches) 2. paper should be placed to the right of the tray and a little inside with a min distance within the papers of .1 mm
3. open the rear access door of the printer (with grids) on the back and reval the rollers. Take a slight moist cloth ( not cotton ) and clean the rollers with it by moving them 4 times upwards.
4.open the cartridge door ad observe the thin plastic strio on top of the steel rod on which the carriage moves. Take a small piece of paper and hold the strip with it ands swipe it once witout applying much pressure as it could come out in any direction and as much as you can
5. make sure you replace the cartridge if its refilled. It could provide obstruction.
move the carriage 4-5 times continuously with as much speed and make sure there is no obstruction in the carriage movement.
6. press set up button on the printer panel - go to print reports - ok / enter - self test report - see if the paper jams. If not good.. If yes take a look into the next step.
7. pull out the power cable directly from the printer. Press and hold # and 6 button on the printer and insert the power cable and do not release the buttons till you see te display glowing blank or some processing happening. Release the #6. If the printer turns off then press on the power button to turn it on. Continue with country and language settins as apprpriate. Choose your country during this reset. Complete the alignmet then. Take a printout to see if the paper jams again.If yes - the printer definitely needs servicing.
Posted on Apr 08, 2008
  • 300 Answers
SOURCE: After clearing a paper jam,
One of the paper flags is either stuck down or broken (from the area of the jam)
Posted on May 17, 2008
pagebor
  • 2785 Answers
SOURCE: Continual problem with paper jam
try with other manufacturer's paper, you can try by reinstalling the drivers
if the problem persist then your printer needs to be serviced
Posted on May 31, 2008
  • 39 Answers
SOURCE: Continual paper jams in rear of printer
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
Posted on Mar 03, 2009
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Help please, I've a paper jam. how do you open the printer ??
Clear the jam from the back of the All-in-One Follow these steps to clear the jam from the back of the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Press in the tab on the left side of the rear door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear doorc00652174.gif
  3. Gently pull the paper out of the rollers.
    CAUTION: If the paper tears, check the rollers and wheels for torn pieces of paper that might remain inside the product. Remove all the pieces of paper from the product to prevent more paper jams.
  4. Replace the rear door. Gently push the door forward until it snaps into place.
  5. Connect the power cord to the back of the product.
  6. Press the OK button to continue the current print job.
    NOTE: The print job might cancel instead of print. If this happens, reprint the document.
  • If the issue is resolved , you do not need to continue troubleshooting.
  • If the issue is not resolved , continue with the steps in this procedure.
Clear the jam from the front of the All-in-One If you cannot remove the paper jam from the back of the product, follow these steps to remove the paper jam from the front.
CAUTION: Remove the paper jam carefully because it is possible to damage the product when removing paper from the front.
  2. If necessary, pull the input tray down to open it, and then lower the print cartridge door. Figure 2: Print cartridge doorc01491485.gif
    CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams might occur.
  4. Close the print cartridge door.
  6. On the control panel, press the Start Copy Black button (c01495311.gif ) to continue the current print job.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
For more info, you can click the link below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00651302&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=1141647
Feb 15, 2011 | HP Photosmart 4180 All-in-One Printer
HP Officejet 5610 All-in-One continuous paper jam,
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 04, 2010 | HP Officejet 5610 All-In-One InkJet...
My printer comes up with a clear paper jam and press checked key. I have cleared all paper from machine and yet the light flashes and will not allow me to print and the same error code comes up. What...
Solution one: Turn the All-in-One off and on again Follow these steps to turn the product on, and then off again, to reset the print mechanism.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn the product on again.
    NOTE: The product might go through a warm-up period of up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period is complete before proceeding.
  4. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again.
  • If the issue persists , continue with the next solution.
  • If the self-test report does not print , continue with the next solution.
Solution two: Clear any paper jam Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose paper from the input tray and output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear a paper jam from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the back of the All-in-One Use the following steps to check for and remove jammed paper from the back of the product.
  2. Disconnect the USB or Ethernet cable from the back of the product.
  3. Disconnect the power cord from the back of the product.
  4. Remove the rear door. Push the door latches toward each other, and then pull the door away from the product. Figure 1: Remove the rear door c00244379.gif Illustration of removing the rear door
  5. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. If you are printing labels, see if any are missing from the label sheet. If any labels are missing, find them inside the product, and then remove them carefully.
  7. Reattach the rear door. Gently push the door forward until it snaps into place.
Step three: Clear the paper jam from the front of the product Follow these steps to remove the paper jam from the front of the product.
  1. Open the cartridge access door. Figure 2: Open the cartridge access door c01913998.gif Illustration of opening the cartridge access door
  2. If you find paper jammed in the product that cannot be removed through the rear door, gently remove the paper through the front of the product.
    NOTE: Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.
  3. Close the cartridge access door. Figure 3: Close the cartridge access door c01913999.gif Illustration of closing the cartridge access door
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01602202.gif ) to turn on the product.
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Keep in this LINK.
Oct 26, 2010 | Dell 948 All-In-One InkJet Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Paper jam after 1 page prints
fuser paper out sensor faulty.req new fuser.
Jun 20, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
ON button on hp photosmart C5280 will not turn off. keep saying paperjam but there is no paper.
Open and clean your printer with some air compress can.
Check the cartridges, take out and put them on place again
Unplug the printer for a while and plug in again
Reset the printer to factory settings
If still not shut down, the printer need to be serviced
Solution one: Clear the jam from the back of the All-in-One
Follow these steps to clear a paper jam from the back of the product.
CAUTION: Trying to clear a paper jam from the front of the product can damage the print mechanism. Gain access to and clear paper jams through the rear door whenever possible.
Remove any loose paper from the input tray.
Step two: Clear the jam from the rear access door
Press the Power button ( ) to turn the product off.
Unplug the power cord from the back of the product.
Turn the product so that you can access the back of the product.
Press in the tab on the left side of the rear access door to release it. Pull the door away from the product to remove it.
Figure 1: Remove the rear access door
Gently pull the jammed paper out of the rollers.
Reinsert the rear door. Gently push the door forward until it snaps into place.
Plug the power cord into the product again.
Press the Power button ( ) to turn the product on.
Press OK to continue the current print job.
NOTE: Sometimes the print job cancels instead of continuing when you press OK . If this happens, restart the print job beginning with the page number when the jam occurred.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Solution two: Open the top cover and clear the jam
If you cannot remove the paper jam from the back of the product, follow these steps to remove the paper jam from the top.
CAUTION: Remove the paper jam carefully, because it is possible to damage the product when removing paper from the top.
With the product still turned on, unplug the power cord from the product.
Raise the cartridge door.
Figure 2: Raise the cartridge door
Gently pull any jammed paper out of the rollers.
Close the cartridge door.
Figure 3: Close the cartridge door
Wait until the product is idle and silent, and then try the print job again.
Solution three: Clean the rollers
Follow these steps to clean the paper feed rollers and the pressure rollers to remove any debris, dirt, or paper scraps.
Figure 4: Remove the rear access door
Lightly moisten a lint-free cloth with distilled water, and then wipe the rollers inside the product with the cloth. Rotate the rollers upward with your fingers to clean the entire surface.
Wipe the pressure rollers on the inside the rear access door in the same manner as you did for the rollers inside the product.
Allow the rollers to dry completely.
Reinsert the rear access door. Gently push the door forward until it snaps into place.
Try the print job again.
Solution four: Reload paper and check the print settings
Follow the steps to reload paper and check the print settings. The print settings must match the type of paper in the product.
Step one: Reload paper
Raise the output tray.
Slide the paper-width guide to its outermost position.
Figure 5: Slide paper-width guide outward
Fan a stack of paper to make sure the pages are not stuck together. Then tap the stack on a flat surface to align the edges.
Load the stack of paper in the main paper tray with the short edge forward and the print side down. Slide the stack forward until it stops.
Figure 6: Load paper in main paper tray
Slide the paper-width guide inward until it stops at the edge of the paper. Do not overload the main paper tray. Make sure the stack of paper fits within the main paper tray and is no higher than the top of the paper-width guide.
Figure 7: Slide paper-width guide inward
Lower the output tray, and then pull the output-tray extension toward you as far as it goes.
Step two: Check the print settings
Open the program that you were using to print when the paper jam occurred.
Click File , and then click Print . The Print dialog box opens.
Click Properties . The Document Properties dialog box opens.
Click the Paper/Quality tab.
Make sure the Paper size and Paper type settings match the paper loaded in the product.
NOTE: A paper jam might occur if the Document Properties dialog box lists photo paper, but plain paper is loaded in the product.
Click OK , and then click OK again to print the document.
Solution five: Reset the All-in-One
Press the Power button ( ) to turn off the product.
NOTE: The product might not turn off after pressing the Power button. Continue to the next step regardless.
Disconnect the power cord from the electrical outlet, and then wait 30 seconds.
Connect the power cord to the electrical outlet.
Press the Power button ( ) to turn on the product.
Step six: Service the All-in-One
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Nov 06, 2008 | HP Office Equipment & Supplies
Paper curl
When a paper jam occurs, the printer will stop printing and the Continue (1) and Paper Jam (2) lights on the operator panel will come on. See the illustration below.
pattlnk_1052005_1635-enus20238_oppaneljamlights_e230_en_us.gif When you experience a paper jam, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following:
  1. If you are feeding paper from a paper tray, first remove the tray. Look for and remove any jammed or damaged paper you find.
  2. Open the front cover and remove the print cartridge assembly.
    IMPORTANT!
    Do not leave the print cartridge assembly exposed to direct light, especially sunlight, for an extended period of time. Extended exposure to light will damage the green photoconductor roller and cause print quality problems.
  3. Remove any paper you find jammed in the area behind the print cartridge assembly.
  4. Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap.
  5. Open the rear exit door/cover of the printer and remove any jammed paper you find there.
  6. Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed.
  7. Press the Continue button to resume printing. NOTE: The printer should reprint the page(s) that caused the paper jam.
  8. If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For more information, see the 'Secondary Error Codes' section on page 69 of the User's Guide.
Sep 04, 2008 | Lexmark E232 Laser Printer
Printer jam
There is an easy fix for Lexmark E232 paper jams at the beginning of the paper path. This fix only works when the problem is that the paper starts to feed, but does not quite make it out of the paper tray.
The problem is the pickup paper rollers. If you remove the paper tray and press down on the paper indicator (the red lever to the left of the paper tray) you can see the twin rollers attached to a spring loaded armature.
Chances are these rollers are worn and are very smooth to the touch. This slick smooth surface does not have enough friction to push the paper up to the next roller.
To fix this, remove both rollers, they slide off easily. Then simply turn both rollers inside out and replace them on the armature. Notice how much "stickier" they feel now? Chances are your paper jam problems are over, until the rollers wear out again.
At that point you will have to replace them.
Mar 30, 2007 | Lexmark E232 Laser Printer
910 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
