Question about Lexmark X2500 All-In-One Printer
Lexmark 4300 i have loaded a new print caridge (black) and a error is coming up which says error: 2200. What shall i do ?
    Scholar:
  • 124 Answers
You need to contact Lexmark, there is a issue with your Printer that needs to be fixed.
Thank you for using Fix Ya!
Have a great one!
Posted on Feb 23, 2009
Lexmark x5650
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Mar 06, 2012 | Lexmark Office Equipment & Supplies
A code 2200 is showing and my copier will not copy. How do I address code 2200?
The 2200 error code indicates that the scanner has stalled. It could be due to the cartridges or the encoder strip (transparent strip seated behind the cartridge carrier) has gotten loose from its position. Please follow the steps below to identify and fix the problem:
  1. Open the printer cover and remove the cartridges. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then slide the carrier to the center for the loading position.
  2. Check the encoder strip and make sure it is secured in its place.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply (black box where the power cord is plugged in at the back of the printer) and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  6. If no error appears, reinsert the other cartridge. Close the printer cover.
  7. Replace whichever cartridge is causing the error to appear with a new cartridge.
  8. If no error appears, try to print a document again to verify that the problem is fixed.
Feb 02, 2012 | Lexmark X7170 All-In-One InkJet Printer
Canon Image Class 2200 Error code 0322 Can you help me with this problem It will not print at all
this means that you have problem with fixing assy. Best solution would be to replace fixing unit.
And,... did you consider to buying new one,... try with Canon image runner 3225N. Its a NORMAL copier. :-)
Jul 06, 2010 | Canon imageCLASS 2200 Black and White...
Prints nonsense instead of print job
turn off ur printer disconnect it frm computer and check ur computer where there is pending printin left by you,if yes cancel all the pending printing and connect ur printer back to computer and turn it ON,u shall not face the problem.
Nov 29, 2009 | Office Equipment & Supplies
Which printer should I use
I don't know anything about screen printing, but is there a reason that you can't use a monochrome laser printer for your Black and white...The cost per page is at least 15-20 times less! Especially if you go with HP and get remanufactured cartridges from a reputable source.
Apr 23, 2009 | Epson Stylus 2200 InkJet Photo Printer
Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Printing paper choices
The paper types available in the driver are dependent on which type of black ink cartridge is loaded in the printer. If the Photo Black ink is loaded, you should have various glossy paper choices. If the Matte Black ink is loaded, you will have a choice of plain or Matte paper types. Once the cartridge is switched, you will get the corresponding paper choices.
Aug 19, 2008 | Epson Stylus 2200 InkJet Photo Printer
Error code E00003-0000
The film (plastic) film is probably torn from a piece of paper that got jammed between the upper and lower section causing an overtemp lockout condition.
1. Remove left paper door.
2. Remove conector rear plastic(black) and fuser shields(2) screws holding fuser cover shield and unplug (3)connectors,2on the rear and a small one on the front lower right of fuser unit
3. Remove (2) assemlbly mounting screws one at rear and one
on the front sides.
4. remove unit and purchase new complete unit from cannon
5.Installed new fuser by reversing above steps.
May 28, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Lexmark X2500 All-In-One Printer Logo
83 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
