Question about Marantz PM7200 2-Channel Amplifier
How do I connect a Polkaudio powered subwoofer (psw 125)
I am usings a Hafler preamp with no subwoofer output connected to a 3 way B&K power amp. The power amp as a right, left and center inputs along with right, left and center outputs for speaker wire. Currently hooked up are speakers right and left not the center channel. From the preamp currently have two interconnets from the outputs to power amp.
The preamp has another set of outputs but I want to connect so that all three channels are playing at the same time. Help!!!!!!
    New Friend:
  • 59 Answers
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Posted on Dec 17, 2008
What type a fuse do I use for my Psw 125 power sub
Is this a Polk PSW 125? I'd contact Polk customer service.
Here is the manual
There is some discussion here
A blown fuse indicates something wrong. I'd contact Polk.
Nov 17, 2015 | Audio Players & Recorders
How to hook up psw350 polkaudio powered subwoofer
A powered subwoofer is fed the sw line output provided by the receiver. If lacking, then the woofer might have connections to it from the speaker outputs of your receiver.
Connect them in phase, make sure your sw is in phase with other speakers and balance the sw output.
Sep 20, 2015 | Audio Players & Recorders
Where is the fuse in Polk psw 10 subwoofer?
You will have to remove the plate amp and look on the pcb, it is generally located near where the main power lines come in.
If you still can' find it contact Polk tech support, Ive owned several Polk products and always found there tech support very helpful; very helpful;
Tech/Product Support
9AM-5:30PM EST Mon-Fri
1-800-377-POLK (7655) Option 1
FAX: (410) 764-5470
International: +1-410-358-3600
Nov 23, 2014 | Polk Audio PSW Series PSW10 Black 10-inch...
PSW 125 Diagram Schematic
download with model number suport e-manual pdf
Aug 28, 2014 | Polk Audio Psw 300-watt 12" Powered...
4-8 Ohm Output Overpowered?
You weren't by chance connecting a powered subwoofer to the standard speaker channels? Most powered subs require a dedicated output from the amp, otherwise you would be amplifying the signal twice over!
Mar 18, 2014 | TOA Electronics A912MK2 Amplifier
On my Technics SU-G90 where do I connect the subwoofer
Some amps have a single RCA socket for a powered sub. If it has not got one of these then the amp has no output for a powered sub. If so then you can only use a none powered subwoofer, which will connect via the speakers of the amp, see the subwoofer manual for how to do this.
Feb 18, 2014 | Audio Players & Recorders
COBOLT PSW-100 SUBWOOFER not playing very loud
What amp/receiver are you using? Have you plugged the sub woofer cable to LFE output on the amp? Are you using the right subwoofer cable? Have you enabled the amp to use the subwoofer?
Dec 09, 2013 | Audio Players & Recorders
First of all the KEF is a powered sub which means that it wants a line level signal NOT a speaker level. Send the signal from a tape output or pre-amp output to the sub input. The overload is because the impedence load for the speaker output is too low and looks like a short to the amp. Continued attempts to connect the system as described will result in damage to the output section of the amp.
Please let me know if you need more info.
Feb 03, 2010 | Technics SA-DX750 Receiver
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Connecting speaker cable
I have RT10 polkaudio speakers (complete 5.1) system with a onkyo amp XT-SR804E. What is the best way to connect the speakers,Bi-wiring or single cable and what is the best type or make of cable to use, to get the best out of the system.
Feb 23, 2008 | Audio Players & Recorders
Marantz PM7200 2-Channel Amplifier Logo
520 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
