Question about Garden
Chain saw emitted sparks and now does not start.
Chain saw has only been used for about 10 hours before it died. chain saw worked on saturday...new unleaded gas was used and used the correct gas/oil mix. Sunday the saw took a while to start, used same gas/oil mix from saturday. Was able to start the saw a few times but the saw would only run for a few minutes and die. Eventually it did not start at all.
On saturday i used the saw several times until the gas ran out and refilled and restarted. Just talked to someone who said you cannot let the saw run until it ran out of gas or you'll destroy the engine. I did see sparks on either saturday or sunday (I don't recall which day). I kept the saw full of chain oil.
  • David Ford
    David Ford May 11, 2010
    You saw sparks coming from the exhaust? When you pull the rope is it real hard to pull now? Finally is this a newer saw, if so I would take it back for warranty replacement
  • 211 Answers
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Posted on Dec 19, 2008
Chain saw died in the middle of a cut
Is it still mechanically sound? whip the muffler off and take a look at the piston skirt through the open exhaust port, any sign of scuffing or damage and it will have to come apart.
Jan 11, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hitachi Chain Saw won't start hot
check for spark when it fails to start could be a bad coil
Aug 10, 2012 | Garden
Wild thing chainsaw won't stay running. I replaced all fuel lines, primer bulb, fuel filter, gaskets to the carb. and have cleaned the carb out very well and blew out all passages. I pulled the spark...
On the carburetor got two screws to adjust the carburetor. The first is to adjust the saw when working at high speeds. Another is when running at low revs. It is best to either put back for about 1.5 cycle of the maximum of the end of the rotation of the screws. If then the saw starts, then you can adjust it fine at higher revs (H), then at low (L). Have can be minimum screw that stops the chain.
Sep 01, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Has run fine. used for hour to hour and a half and all was good. quit for an hour. added fuel and ran again. but, within 10 minutes, it died and a little smoke came from area around the pull cord. ...
Do you have the correct Resistor plug in the saw? If the plug is correct and muffler is clear, air filter clean, my thoughts would be a clogged carburetor.
Jun 09, 2017 | Husqvarna Operator's Manual 365 372xp ...
Chainsaw will run for 10 minutes then dies,will
When it dies, try removing the fuel cap for a moment, then try restart. If successful, the tank vent is likely plugged (look under the left case cover). It should be a bronze plug set into the tank surface. If no help, remove the spark plug, and test for blue,snappy spark. If nothing happens, try a new plug first. If still nothing, remove the stop switch grounding wire at the ignition module and retest. If still nothing, the module is dying with heat--replace it using a thin business card for a gap gauge. Turn the flywheel magnets under the module poles and allow the new module to stick to the magnets, then tighten the screws. Rotate the flywheel to release the card, then turn the flywheel one complete revolution to make sure the module gap doesn't close up. Hope this helps!
May 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw will run for 10 minutes then dies,will not start again for about an hour. It is a 345
When it dies, remove the spark plug and make sure that it continues to make blue sparks. If nothing, try a new plug. If still nothing, then the ignition module is likely dying from the heat--replace it. If sparks continue, then try spraying starting fluid into the plug hole, replace the plug, and try to start. If it pops once or twice, then suspect a fuel delivery problem. Try loosening the fuel cap for a moment, then try to start. If it runs again, suspect a plugged fuel tank air vent. Try cleaning the engine area with compressed air, particularly behind the starter mechanism. Hope this helps!
Mar 19, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Saw starts but engine cuts out after less then one
i think you really need fresh fuel, clean out tank as much as poss with new oil also. will probably take a while to pump fuel through
Mar 06, 2010 | Husqvarna 450 e-series 18" Chain Saw
I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Oct 08, 2009 | McCulloch Garden
Husqvarna model 345 chainsaw
adjust the gas by turning the screw on the carburator
Dec 28, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
480 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
