Question about Dell Dimension 4600 PC Desktop
Dell 4600c will not power up -- green power button lit -
Trying to start my dell 4600c and after pushing the power button the system attempts to boot but but stops.. the green power button is lit but none of the diagnostic lights are lit..
does this sound like a simple power supply problem?
thanks in advance!
  • 1 more comment
  • jbryt Dec 16, 2008
    nothing boots.. the monitor stays dark.. my external hard drive goes off but the green power button is lit but i can't hear the fan or anything inside runnind
    nothing starts.. the fan starts then stops.. no lights on the keyboard.. the monitor light goes green the back to amber
  • Chase May 11, 2010
    So the machine powers on and attempts to boot but can you clarify what exactly it does when it stops? Does the Dell boot screen never finish loading? Does Windows progression bar freeze? Does the system power off? Does the system restart?
  • 51 Answers
I think it may not power supply problem.it may be ram memory problem.try this,remove your ram and clean it with cloth and restore back.
Posted on Dec 17, 2008
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
My unit indicates a system error due to amber LED was lit whenever I press the power button. I tried to press the remind button in the operator panel but no LED will lit to indicate what maybe the problem....
Interesting, sound like a failure of the button because most system either work with a greeg lit up led or fail with an amber or orange lit or flashing.
In this instance the amber could mean something has gone bad but the fact you can hold the button and have it boot up is strange.
Does the led turn green after holding the button for a while to let the machine boot?
regards,
mike
Oct 19, 2012 | IBM System x3500 (7977F2U) Server
My dell 4600c monitor will only show a picture when i start or restart it with the monitor power button. it is only on for about 1.5 seconds each time.
If the tower power LED is a Steady Green and the Diagnostic LEDs on the Back are all Green then the monitor itself appears to be the failure point. See if issue occurs with a different monitor. If the tower LEDs are not all green, then reply with the indications
Sep 20, 2010 | Dell Dimension 4600 PC Desktop
Dell 4700 desktop, will not boot up. Light remains
A solid Amber power LED is an indication of a motherboard problem. Remove any external connections and see if LED indications change. If no change, remove all PCI expansion cards, try again. If still no go, disconnect all drives, try again. If still no change, ensure the CPU heatsink is firmly attached (If loose you need to replace the retention module) If nothing loose and no changes from other steps, replace motherboard
Mar 11, 2010 | Dell Dimension 4600C PC Desktop
Gateway 702GE desktop When i push the front botton to start it up,the fans start to turn and then stops with no operation. The small green led on the motherboard stays lit and green and the front start...
try removing all the cards from the expansion slots and remove the ram sticks. disconnect the drive cables from the board but dont touch the cpu or power connectors. Now hit the button. If nothing changes, probable board fault. If it now boots up and starts beeping ( which it will when no ram sticks installed) shut it down and reinstall each drive connector, ram stick and card one at a time booting between each item. when the faulty item is connected, the board will stop booting and you can replace that item. Many things can also cause this. Bad connections to ram sticks and video cards, damaged usb port connections, failed cpu's, failed psu's etc.. You may still have to take the machine to a professional repairer to have the problem diagnosed.
Nov 02, 2009 | Gateway 702GE PC Desktop
I have a dimension 4600c. installed a new power
The power supplies have extra connectors which are not used.
Try doing a system restore to an earlier date when your computer was working ok.
Restart your computer and hit F8 while it is booting. When the menu comes up, select "Last Known Configuration"
This will bring it back to a time when it was working.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 11, 2009 | Dell Dimension 4600C PC Desktop
Dell Dimension 4600C won't turn on
Unplug the unit. Re-seat the Memory and Daughter-boards. Plug in and try to start.
Nov 22, 2008 | Dell Dimension 4600 PC Desktop
Inspiron 9200 cannot power up.
Start by checking the power supply with an ohm meter for the correct output, however, this is generally a problem with the battery or a memory chip. Start by removing the battery and starting up on the power supply only. Dell batteries are notorious for causing a no start. Then try removing the memory and try one chip at a time in both slots. If none of these work, then I'm afraid you have a failed system board component, and you will probably want to take it in for a professional diagnostics. Also, you can find a diagnostics light codes list for your machine at Dell's support site.
Aug 06, 2008 | Dell Inspiron 9200 Notebook
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
Doesn't boot up
try it pluged in without the battery, does it turn on?
when it shuts down, does the power light stay on? or is it just no display?
Jan 04, 2008 | Dell Latitude D600 Notebook
Dell Dimension 4600 PC Desktop Logo
376 people viewed this question
Clive
Clive
Alun Cox
