Monitor Issue: 5 seconds of picture the monitor goes black.
I have a Samsung SyncMaster 173s as a second monitor, and one day I noticed the screen was black. So I restarted the PC and at started the screen showed a picture for about Five seconds then went black (no flashing green LED).
I tried reinstalling the driver, changing resolution, and Hertz, and each time a setting was changed the screen would light up with crystal clear picture, then go black after five seconds.
Please help, I don't want to buy a new Monitor, when this one seems to work perfectly for five seconds at a time :)
Thanks,
  • C-dub-917 Dec 17, 2008
    I have an old Dell monitor that I replaced the high-voltage power inverter with an external unit. Prior to this, however, the display would come on for about 5 seconds and then go blank. I also have a G-Naga VI 17'' dis\play that is now doing the same thing. the only thing thats different is that after a cold reboot of the PC the monitor works just fine. Does this sound like a driver issue?
  • Anonymous Jan 04, 2009
    This same problem exisits on my View Sonic 20" screen except that after 5 + tries it will eventually stay on. What is happening and can a novice repair the problem?
    Problem Solver:
  • 11 Answers
I had this similar problem. I found out that there was a bad 1000uf, 16V cap on the power supply board. The cap is too close to a heat sink and over heated. I bought the cap at radio shack for $2, installed it so that it is far away from the heat sink. Monitor now stays on when powered up.
These monitors are difficult to open.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated. Remove the cover plate and unscrew the push buttons. Unplug the monitor cords from the driver board. Unscrew the mounting screws from the power supply board and remove. You will need to pinch the plastic support in the middle of the board to remove. Unsolder the cap. It is located near a copper heat sink and the value will be on the cap. It will be buldged up on the top. You will see burn marks on the board surrounding the cap. Install the new cap and solder. Be careful not to solder across joints.
Reassemble and turn on. Should solve the problem
Posted on Dec 24, 2008
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
Samsung syncmaster 172v Screen goes black after about one second. Comes back to normal after turned off, but goes black again in about one second. Rebooting computer has not fixed this.
Sorry it is like your monitor needs service. Electrolytic condensators in power supply need to be changed. Give it to an electronic shop, it is a job for a specialist.
Oct 18, 2010 | Samsung SyncMaster...
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
My Samsung syncmaster 2220WM will not stay on. It
The picture board on your monitor has been malfunctioning for quite the period but you did not notice it, since the screen goes blank, it means the picture board of your monitor has developed fault and will need to be replaced.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Samsung SyncMaster 2220WM 22" LCD Monitor
Screen appears on for three seconds then goes black
Try the monitor on another computer that you know works, If it works on another computer then that means you have no video output on the original computer and you'll need to reseat the memory on that computer.
If you get the same response on another computer, then that means the monitor is bad and you'll need to replace it.
Apr 19, 2010 | Samsung Syncmaster 2033SW Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Aug 14, 2009 | Samsung SyncMaster 920NW Monitor
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Monitor goes black when cable attached
Looks like a "mechanical" problem (cold solder point possible or bad electrical contact)
Aug 04, 2017 | Samsung SyncMaster 173S (Black) 17 in....
Computers & Internet Logo
503 people viewed this question
Alun Cox
David Payne
David Payne
