Question about Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit
XpressRC Freezes This has happened several times! My RC will freeze up - can't power off, can't change stations, scroll at bottom of screen doesn't move. The only way to "recover" is to pull the power out of the cig lighter. Doing this also resets all my settings back to default (FM turned off, my stocks removed, my alerts cleared, etc). Does anyone have any idea what could be causing this? Is there a battery backup on these devices? I'm tired of reprogramming all my channels and settings every time this happens!
  • Anonymous Dec 22, 2008
    Had same problem. Sent mine back to Delphi for repair/replacement. Got the new unit about a week & a half ago & then it froze up on me yesterday... Exact same thing! Beginning to think these are garbage.
  • maschenck Mar 17, 2009
    I had the same problem. Delhi XpressRC began occasionally freezing up within a few weeks after buying. Had to unplug to get it unfroze, but that deleted all preset stations and settings. After a few months this got worse and worse and then it quit working. Called Delphi and they sent a replacement. Within a few minutes of using the replacement, it also locked up on me and powered off. This happened both in car and home system. I too think perhaps these are junk and Delphi is not admitting to it.
SOURCE: Roady XT Transmitter problem
Mine is doing the same as well. Been working for 1 year. Now it starts cutting out while listening. I noticed if it is broadcasting the fm frequency menu is there. The minute it cuts out I press Menu and that menu item is gone. It comes back once the radio starts working again. Mine is 1 year old. I got it Christmas of 2006. I do know that if you have it directly connected then this menu item will not appear and that is by design. I think my xm roady xt has gone bad.
Posted on Jan 11, 2008
SOURCE: My screen is blank...
I had this same problem. I took out the lithium battery rubbed off the contacts and inserted it. Scrren came up clear as a bell and works fine now. I was also having a problem with the battery charging. Think what I did solved both problems.
Posted on Jan 19, 2008
SOURCE: delphi skyfi 3 freezes up.
What you need to do is simultaneously hold the VOLUME UP button as well as the MODE button. This will reset the unit. From what I read of your problem, you were simply holding the VOLUME plus MODE buttons.
Posted on Feb 03, 2009
rmhurd605
SOURCE: No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
Posted on Apr 28, 2009
SOURCE: xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Posted on Jun 04, 2009
Power cuts out and starts again
Electrorama Electronics Trinidad will fix that problem on your Panasonic Strada deck system ,It will remain on all the time it will stop going off and on and freeze up...Ph.662-6387 David or Daniel.They also convert radio station to receive local FM stations..
Feb 24, 2014 | Panasonic HDD Navigation CN-HDS700D
Toshiba freezes battery power
hi
remove the dock station , if still freeze change battery
Oct 28, 2012 | Compaq Presario Notebook
I a 16 user L230. my problem is that the terminals freezes. At logon, they are fine but they start to freeze after about 20mins after i switch the system on. its not particular stations athat freezes but...
The terminals never actually freeze as they are getting desktop sessions from the host. What can happen is the desktop session can lock up and thus any corresponding user input doesn't happen due to the session being locked up. Next time this happens, see if the server/host is responsive. Assuming it is, launch Performance Monitor(Provided as part of the Windows OS) by going to Start ' Run ' Perfmon. Monitor your CPU performance. See what's taking all the CPU resources. It's not uncommon to see unncessary programs running, i.e. jusched.exe (Java Scheduler update), qttask.exe (Quick Time updater), etc. All these programs and other unnecessary programs run at startup and run for EVERY single user so in your case, the jusched.exe runs 16 times and can take valuable system resources. Disable these by going to Start ' Run ' msconfig, press enter, the farthest tab on the right labled STARTUP is where you can disable these programs. After deselecting the ones you don't need, reboot the host and tell the dialog box to NEVER tell you again so that it doesn't alarm you're users that you've messed with the startup config. Lastly, don't overlook that fact that you need 1GB NIC and backbone to the server, each device can take up to 15MB/s of network bandwidth.
Jul 05, 2011 | NComputing L230 Network Terminal
White Palm Centro freezes randomly. Doesn't respond to input
http://forums.palm.com/t5/Support-Downloads/Palm-Centro-ROM-Update-for-Freezing-Issue/td-p/165101
Mar 28, 2010 | AT&T Palm Centro Cell Phone - White
Mouse freezes up periodically (several times per day)
Have you tried changing batteries?
or check the current drivers.
Apr 24, 2009 | Innovera IVR62100 Mouse
My jensen mp7610 car cd player
I asked a friend of mine and he didn't charge me ANYTHING. What happened to free advice? What has happened to helping each other out? This is bogus!
Sep 28, 2008 | Jensen MP7610 CD Player
Archos 605 wifi freezes
Mine kept freezing alot, and now the on/off button wont work. I can only turn it on with the docking station.
Jun 14, 2008 | Archos 605 WiFi Digital Media Player
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba SD 5700 DVD
Hi RC hobby,
Sounds like you have a faulty power supply or logic board. The later is most likely. Once the unit get warmed up the component tolerance become critical to it's performance. If an ageing component is starting to fail then then normally happens once it fairly warm. The reverse can be true, it just depends on what type of part is failing.
I'd check the it's internal power supply for signs of faulty capacitors. However, you do so at your own risk. See this website for details on identifying bad capacitors. Please read the safety warning on the back of the unit before opening. Ensure the unit is unplugged from your mains supply.
Please don't forget to to leave feedback.
Hope this helps,
Spare head 2
Jan 05, 2008 | Televison & Video
Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit Logo
321 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
