Question about Lexmark X6170 All-In-One InkJet Printer
Lexmark all in one X6150
My printer recently fed approx.20-30 pages(at once) and naturally jammed. I cleared the jam and managed to print one page, but now as soon as i switch on the printer it starts feeding paper and tells me to turn off power and press the clear button, sometimes it says error no communication with printer. I don't know what to do, I was told by lexmark support to trash it and get a new printer, do you have any other suggestions? Please help as i am a pensioner and try to get as much use of my appliances as i can, printer is only two years old, i had others that still worked alright after seven years. hope to hear from you soon. thanks zigy
  • 1 more comment
  • darroyo34 Nov 19, 2007
    The paper in the rear feeder gets yam
  • adri123 Dec 06, 2008
    I have the same problem. Printer says I have a paper jam but there is not jam anywhere. Once I turn it on, the same message appears "press power, then clear paper jam". What else can I do ? Also, where is the paper sensor? can I fix that myself ? please help !
  • X-MarK Apr 01, 2009
    I have the same problem with my lexmark X6150. 20 to 30 sheets of paper went thru at the same time and now all I get is, press power, and clear paper jam. Is it screwed or what? lol
    HELP!!
    Sergeant:
  • 390 Answers
You may have inadvertently damaged the paper sensor in which case it will need repairing, but sometimes it can just be a case of resetting the unit. Turn it off, unplug it, retry after all on again. Please post back i would love to beat thie cheeky printer xxx
Posted on Feb 10, 2008
SOURCE:
I have a Lexmark Platinum Pro905 all-in-one printer.
Dust and dirt are usually the main causes. Using compressed air, gently blow out along the underside and inside of your printer. Please be very careful not to hit the print head as they are very easily damaged and Lexmark isn't making any new ones any longer. Sometimes, little pieces of paper can get in there as well. If you use the 'Clean heads" option on your printer, you will use an exorbident amount of ink! I was amazed my first few times (I couldn't believe it so, naturally, I had to check it again!).
Apr 25, 2017 | Lexmark Office Equipment & Supplies
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Hi, My Lexmark E232 printer is on but will not print. The light second from the bottom is orange. Help!!
That second from the bottom orange light indicates a paper jam. Press Continue to resume printing once all the jammed pages are cleared from the paper path. Press Continue twice quickly to see the secondary error code. See "Secondary error codes" on page 69 of the user manual for more information.
Here's a link to the manual: http://www.lexmark.com/publications/pdfs/e230/eng/ug.pdf
Mar 21, 2011 | Lexmark E232 Laser Printer
Lexmark e238 jams every time i print prints about 2/3rds page
lex is junk ...stay away from this brand ..try others but i recomend epson.good luck
Sep 13, 2009 | Lexmark E238 Laser Printer
Lexmark E238 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 11, 2009 | Lexmark E238 Laser Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Extra pages after paper jam
that's from a problem with the print queue manager..empty it out, power down completely, start again..
Aug 08, 2008 | HP Inkjet 1200dn Printer
Lexmark X6170 All-In-One InkJet Printer Logo
109 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
