Question about Fujitsu MHV2160BT 160 GB SATA Hard Drive
Where I should put back the little thing back
My 160G 4200rpm doesn't spin. I open the hdd, a little only metal thing falling down from the left bottom of the corner near to power pins. It seems that it belongs to head and support a orange plastic thing. anyone know where it belongs to and what's the trick. because even I put it back no click on it? thank you.
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: I have a Lifebook C1020 The power connection
No need for a hammer.
Remove the battery, CD drive etc. sometimes there are screws hidden in these areas. Some screws are hidden under plastic covers, remove these to reveal the screws.
On quite a few laptops I have dismantled the top half and bottom half of the case are held together by plastic catches. The best way to separate the case is to start at an opening eg, where the CD drive is located and gently pull apart until the catch releases, continue around this edge and then around the other edges to release/separate the case.
Posted on Jul 11, 2009
  • 1542 Answers
SOURCE: Hi I am trying to remove plastic facia to swap out
Hi
Click on this link and it should take you to the website to download the manual
you will need adobe reader installed to be able to read it
and click save then save it to your documents or desktop or a spare drive
for future reference
http://www.pc-ap.fujitsu.com/support/index.html
good luck
please let us know if this was helpful
Posted on Jan 24, 2011
Honda Civic 2003 back seat does not lock.
oil the lever it will be sticking .like WD 40
Dec 20, 2013 | Honda Cars & Trucks
I have aemachine w4620 with 80g hard drive and 1g memory, can i upgrade my hard driveand will it takemore memory?
Max memory is 2GB. The stock hard drive is an 80GB ATA/IDE type, 4200rpm - larger ones are available in 100G, 120G, 160G, 320G, and .. I believe 500G. So the answer is: both can be upgraded or, more precisely, replaced with higher capacities.
Sep 01, 2011 | eMachines Computers & Internet
I have what I think is an Inoi Sata multimedia hDD ( Square aluiminum case) .I have connected it to a Windows 7 computer and has failed to be recocognised. Where do I find suitable drivers thanks
you should not need drivers for that all, windows should be able to recognize it.
These things usually need an external power supply, first check if it is connected.
Try it with a different computer. If it works then I suggest a system restore on the other comp.
If it doesn't work (which is likely) then you should take apart the metal case, remove the HDD (which is a totally standard desktop HDD) and plug it inside the comp with the SATA port. Windows then will correct the disk errr upon turning on. If it doesn't work this way either then it's dead. If it works flawlessly, but when put back into the case it doesn't wok again then the housing is faulty.
Aug 11, 2011 | INOi HD370 300 GB USB 2.0 Hard Drive
Can't get the belt to engage for carpet cleaningwith my riccar
I will attempt to walk you through the belt change on your Riccar 8955 upright vacuum cleaner. I have taken pictures for you for each step to ensure that it's done properly. What you'll need to have handy for this repair;
- Phillips Head Screw Driver
- Riccar 4000 / 8000 Series Belt
- Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
Step 1: Make sure the vacuum2_bing.gif cleaner is unpluged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unsrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
Step 3: Remove the belt guard that sits to the left of the roller brush, and is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift staight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take one new belt and wrap it around the metal pin in the back of vacuum cleaners2_bing.gif agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), but the other end of the belt through your new roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continously having to replace belts2_bing.gif. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, posistion the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right. Here's a picture of the belt guard being put back into place;
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Change the the rug / floor switch from bare floors to the carpet setting, and the turn the vacuum upside again so the brush and belt are exposed:
Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
Thank you
Chris Jones
GoVacuum
Jan 17, 2010 | Riccar 8850 Vacuum
How to replace the rubber gasket around door and drum
open the door around the front of the door seal you will see a lip under the lip you will see a metal band will a spring. get a screw driver and push in on the spring and pop it out. this will remove the front of the seal next is the same thing exept the band looks a little different locate the part that you can unscrew sometimes they have a socket head and sometimes it will have a phillips screw. when you are putting it back on it may be time consuming and you may start to cuss a little. you have to make sure the rubber goes on the right way so that the band seals and doesn';t fall off or you will have a leaking issue. also when taking the seal off you have to take the part that the water comes in off. just peal the rubber away from that plastic shoot. let me know if you have any more questions
Apr 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My echo vue 805 DVR won't stay on and then it has hdd failer
If it says its got a HD failure, I would believe it. Since the OS loads from the Hard Drive, it is designed to shut itself down when drive faults are detected. I would suggest contacting DirecTV to discuss getting it replaced.
Mar 19, 2009 | Televison & Video
CMOS Battery dead, No Post, No System Beeps
bloody hell! All the ones I have used (IBM, Compaq and Dell) have clear access to the battery!
That sounds very frustrating!
My Solution, drop kick it out the window if you have to replace another!
Mar 18, 2009 | EliteGroup ECS DESKNOTE A929 Notebook
Disc not spinnin'
I had a similar problem but mine didn't fall out luckily...
You'll find a space for the metal clip (please say you kept it) at the back left of the console (you may need a torch to see as it is quite small. The metal acts as a connector to tell the ps2 when the lid is shut and to commence disk reading, otherwise as you experienced, disks won't spin
Sep 21, 2008 | Sony PlayStation 2 Slimline Console
Automatic threader mechanism keeps sticking and a part falls off
These machines are nothing but TROUBLE and always will be. Get rid of it. Save yourself much time and frustration.
Apr 22, 2007 | Brother SE-270D Computerized Sewing...
Fujitsu MHV2160BT 160 GB SATA Hard Drive Logo
171 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
