Question about Gateway GT5032 (827103078121) PC Desktop
ATX power on Motherboard not working
Please take a look at the attached picture. I couldn’t find a picture of the gateway motherboard, but it is a 4 pin just like in the picture and I’m assuming it’s the same thing. When I plug in both my ATX Power connector and the 12v ATX power connector, I hear no fan noise or anything. The blue light on the power button comes on, but nothing else. But when I just plug the main ATX Power connector, I hear fan noise but no hard drive noise when I press the power button. This just happened while the computer was sitting there; it shut off and when I tried to turn it back on this happened. Nothing displays on the screen at all. Any ideas? http://img.photobucket.com/albums/v292/Rob8oD/mobo.jpg
  • 5 more comments
  • Robert Hofland Dec 16, 2008
    Yes, I connected all 24 pins on the main atx power supply. 4 of those pins our fed out to my Nvidia Geforce 8600GTS video card. I tried it with a different power supply with 4 less pins and I heard the fan power up as well, but only if I didn’t connect the auxiliary 12V cable in.
  • Robert Hofland Dec 17, 2008
    If you look at this link, it has a better view of the actual motherboard in question. The two connectors I am referring to are labelled H for the main power connector and S for the Auxiliary 12v power connector. Why would the fan power up when I plug the main one in, but then not work when I plug both the Main and the Auxiliary connector in?
    http://support.gateway.com/s/MOTHERBD/FI...
    Another note, when I pulled out the power supply, it was VERY dirty, had a ton of dust in it which I vacuumed out. However, the other power supply I plugged in had the same issue so I'm thinking it's not a problem with the power supply, but the mother board.
    The power supply I had in the computer is 500W and the one I tested with (the original one that came with the PC) is a 300W power supply. I purchased and installed the 500W when I bought a new video card because the video card required a higher Wattage Power supply.
    I don't have a multimeter, and when I plugged in the 300W power supply, I had the same thing happen. If I get a mutimeter, what should I be looking for?
  • Robert Hofland Dec 18, 2008
    I tried with everything out including the video cards. I tried with another PSU and still there was no beeps or anything. I took it into a computer repair store and they checked it out and they suspect it is either the motherboard or the CPU that went dead. when they checked the voltage coming from my power supply they said it was running a little high, but not fluctuating. I'm just about to the point of buying a new motherboard.
  • Robert Hofland Dec 24, 2008
    Ok, I have one last question on this subject. I am trying to replace my motherboard without having to buy new RAM/processor, power supply, etc. Can somebody point me in the direction of a low-priced replacement motherboard? I lost an auction on ebay by $2.00 for the exact motherboard, and I just want to buy a replacement at a good price. I have also resigned to the fact that I will have to buy a new case, since Gateway is stupid and builds with BTX cases/motherboards.
  • zonkpc
    zonkpc May 11, 2010
    Do you have a multimeter? It would appear that you have everything plugged in correctly so there has to be a fault somewhere. Do you still have your 300w one? I would take out the graphics card and try it with the 300w. Also what fin is spinning up? the one in the PSU?
  • zonkpc
    zonkpc May 11, 2010
    have you connected all 24 pins to the main atx power supply? Some of the adaptors are 20+4 pins, all these need to be connected + the 4pin 12v connector
  • 68 Answers
Just to check the voltages coming from the psu. However if your old psu is doing the same it must be something else. Did you try it without the graphics card? and is it the fan in teh psu which is spinning up?
My next port of call would be any other expansion cards, followed by the memory modules. Take them all out apart from one memory module and try to boot.
Also check that the pins from the power button are connected correctly. you can also try starting the pc by touching the two pins together with a metal tipped screw driver.
Posted on Dec 17, 2008
Fan is working without 4 pin ATX pin but not with 4 pin ATx
Fans are Controlled by Temperature Control Setting of the Mother board. So the Fan controller is a function of the BIOS of the Mother Board...
Jul 17, 2014 | Intel Computers & Internet
DX4820 power supply
To my knowledge, the Power Supply used is just the common ATX form factor design.
Approximately 6 Inches Wide, 5-1/2 Inches Long, and 3-1/2 Inches Tall.
Needs these power cables;
A) 24-pin ATX main power cable
Newer power supply's come with a 20 + 4-pin ATX main power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
That is so the power supply can be used on a motherboard, that needs a 20-pin, OR a 24-pin ATX main power cable.
B) 4-pin ATX +12 Volt power cable.
Often referred to as an ATX12V power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
[Note color of power cable connectors does NOT matter ]
Note the Lock on the side of the power cable's connector, and matching Tab on the motherboard connector.
The 20 + 4-pin ATX main power cable, and matching motherboard connector; has this type of Lock/Tab also.
C) Needs at least 2 SATA power cables.
The Harddrive is a SATA unit, and I believe the optical drive (CD/DVD drive) is too.
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Often has a Lock on the connector. Press to release when installing, or removing.
D) Should have at least two 4-pin (Standard) Peripheral power cables.
Misnomered as 'Molex',
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
E) Needs one 4-pin (Small) Peripheral power cable, for the Card Reader.
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Also needs 300 Watts.
A Power Supply like this one would work,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899123&CatId=1079
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 02, 2013 | Gateway mb.u1909.002 - Dx4820-05h System...
Emachine W3653 motherboard manual
Intel 945GCT-M3 motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rmv.shtml
Above shows main view, and is labeled.
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rnv.shtml
Click on Product Views for Pinouts and connectors for;
1) 4-pin ATX +12 Volt power cable; B - Processor Core Power Connector
2) Processor fan cable connector on motherboard; D - CPU Fan Connector
3) 24-pin ATX main power cable; F - ATX Power Connector
4) Floppy Drive 34-pin connector on motherboard; G - Floppy Disk Drive Connector
5) CD/DVD drive that is IDE (PATA) type -> connector;
H - Parallel ATA IDE Connector. (Harddrive goes to SATA connector)
6) Computer case fan connector; I - System Fan Connector
7) Audio connector on motherboard for CD/DVD drive's small audio cable, (Main drive if there are two)
M - AUX-IN Connector
8) Front Panel is front of computer.
N - Front Panel Audio Connector is where the front panel audio ports connect.
9) R - USB 2.0 Connectors = Front Panel USB connectors on motherboard
10) Front of computer is the Front Panel. Area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
T - Front Panel Connector = Front Panel header
Motherboard manual from ECS Support,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=719&CategoryID=1&MenuID=16&LanID=0
(Note photo is distorted. Click on - More pictures for clearer view.
{More pictures / Where to buy / Print )
Click on the Download tab.
(Features / Specification / Download / Support / CPU / etc)
Click on Manual.
(Driver / BIOS / Manual)
Scroll down, click on the country NAME nearest yours.
A PDF file motherboard manual will come up.
Regards,
joecoolvette
Nov 16, 2012 | Computers & Internet
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
Had to get a new power supply for my GT4016. When I got ready to hook up the motherboard power connector I realized the power supply has a 20 pin connector and the motherboard connector has 24 pins. Did...
on the part of the power supply there is another connection with 4 pins the 20 pin and the 4 pins click together then slot into motherboard thats usually wat the problem is theres AT and ATX motherboards see if you have those extra 4 pins hanging loose on the wires they slide into each other then into motherboard
Oct 09, 2011 | Gateway GT4016 Desktop PC
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
What is the pin out for the power supply plug F- P! or J2 on Gateway motherboard 4000789?
Looks like standard ATX here is the pinout
http://pinouts.ru/Power/atxpower_pinout.shtml
What are you trying to do? If you are trying to use an older AT power supply it will not work you will notice that not only does ATX use a soft switch to tun on and off it has a 3.3v leg that is used for the CPU.
Hope this helps.
Sep 13, 2009 | Gateway (4000789) Motherboard
2 ATX POWER SUPPLY PLUGS
Some motherboard/cpu setups require an additional 4-pin connector for additional power on the motherboard. The motherboard will require either a 20-pin or a 24-pin power connector (main power), and might need the additional 4 pin as well. If the motherboard will accept the additional 4-pin, then connect it!
Sep 04, 2008 | Gateway GT4022 PC Desktop
Bad motherboard.gateway atx tower
whatever socket that is 454 soket mobo i think or befor ethat so old look on ebay for one that can take your chip how do u know mobos bad no power or im open for chat anytime also thx nick helpap
Jan 06, 2008 | Gateway (4000597) Motherboard
Gateway GT5032 (827103078121) PC Desktop Logo
363 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
