Question about Whirlpool LHW0050PQ Front Load Washer
Locked Door Hello, The model is a Whirlpool LHW0050PQ. Power and lights work, but the door remains locked. Thank you so much.
  • dfwhip Dec 31, 2008
    I have the same problem. Anyone have any ideas?
  • Anonymous Feb 23, 2009
    same
I got so made that i just ripped it open by pulling on the flimsy handle and it actually bent the spring thats under the decorative round door cover just enough that it now works perfect. The door cover feel off and i did break the underside of the handle but i was a ble to snap everything back on. The handle cover went back on too.
Posted on Feb 17, 2009
Whirlpool Electric Range Model # RF369LXPB. Self cleaning function does not work. A code displays after self cleaning function has been on for about 3 minutes. The code is F5EO. What does this mean?
Hello, Thank You for using FixYa. I will be helping you today.It means the door lock and door switch dont agree. Check the door switch does the oven light go on and off? does the door lock? It is either the door lock or oven door switch that controls the light.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Whirlpool RF369LXPQ Electric Kitchen Range
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Electrolux "Kelly Ripa" washer just completed a load, but did not unlock the door. How can I get the door open? The manual was no help.
check inside your pump filter first see if there is anything in there....this might be causeing your door to stay locked
May 08, 2010 | Whirlpool LHW0050PQ Front Load Washer
Door wont open
Managed to pull back casing on door to reveal the handle and pin holding it together. Once i had pulled pin up slightly the door opened to reveal the door handle catch had broken. Engineer has fitted a new handle and everything is fine.
Jul 22, 2009 | Whirlpool LHW0050PQ Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
DOOR IS LOCKED
remove bottom panel reach up to lock area pull down on small tab
Jul 12, 2008 | Whirlpool LHW0050PQ Front Load Washer
Locked washer door
try hitting it where the lock is but you may have to replace the lock.
Mar 14, 2008 | Whirlpool LHW0050PQ Front Load Washer
Door Lock
door lock blown this sometimes blows tracks off the main pcb behind the control panel. appliance doctor
Jan 29, 2007 | Hotpoint WMA44 Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
237 people viewed this question
Dan Webster
Dan Webster
Sal De
