Question about Sharp Microwave Ovens
Sharp Carousel Microwave Model R520-LK timer will run but carousel doesn't turn and food doesn't heat.
I also have the Sharp Carosoul oven, symptoms - fan runs, controls are fine but the turntable stopped turning and it did not heat. It was not the switches, fuse, but in fact a sagging door that misaligned with the door switches. The true cause was a warn top hinge. As a temporary fix, I adjusted the bottom hinge (3 screws underneath), straightened the door, and now it works again.
Posted on Jan 01, 2012
  • jamiemurdock
    jamiemurdock Jan 01, 2012
    Scholar:
  • 33 Answers
Dear customer,
please do the following checks...
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
hope this would sort out your problem...
Please rate this solution.Thank you....
Posted on Dec 16, 2008
We have a Sharp R-410 LK and it stopped working except for the clock and timer. The carousel doesn't work or anything else! Could a major part have gone out or could it be something simple?
I couldn't find the wiring diagram of this exact model, but looking at a similar model diagram, it appears that the main fuse in the oven has blown or a safety interlock has failed. The clock runs all of the time of course, and so it is powered by a branch circuit. The main fuse and interlocks protect the rest of the oven (and you!). The fuse could have failed because of temporary overload or because a critical component failed, in which case you would need some profession help. If the oven is fairly new, it may pay to enlist a service tech, because some critical failures involve relatively inexpensive parts. You may find it budget-worthy to take it to a shop you trust that does this service, rather than pay for a house call. Good service techs can usually track this problem down in a few minutes. Microwave circuitry is comparatively simple (but dangerous if you don't know what you are doing).
Nov 29, 2015 | Sharp Microwave Ovens
My sharp carousel II microwave no longer heats food. Do I need to buy a new one?
The problem maybe the magnetron, or the inverter board if 7 years old or less, and possibly the keypad control board, by the time you add parts and labour cheaper to replace the microwave oven in the long run.
May 07, 2012 | Sharp Carousel R530EST Microwave Oven
I have a sharp carousel microwave. I was heating food and in the middle of heating the microwave stopped and the timer continued to run. What could be the problem?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 05, 2010 | Sharp Microwave Ovens
I have a Sharp Carousel Microwave Model R-1511. There is power to the unit, but when I try to operate, the blower doesn't work, the carousel doesn't turn, and there's no heat (the timer does count down...
Can you remove the timer panel?? Do you see screws to do that?? Make sure the unit is unplugged first. Then once inside check the door switches and the wires to them. Look for a switch that doesn't click when you push the plunger on the top. Or a browned wire terminal to the switch. That is where your problem will be.
Oct 20, 2017 | Sharp R-1511 Microwave Oven
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
Sharp Carousel Model R-1440 won't shut off
Take it immediately to a local Microwave repair shop...looks like one of the circuits may have gone...otherwise switch off from mains
Sep 28, 2009 | Sharp R-1480 Microwave Oven
Sharp carousel r-508ak - does not heat up the food
You probably have a defective magnetron or blown fuse supply power to magnetron.
May 12, 2009 | Microwave Ovens
No heating, no clock, no timer, otherwise fine!
One of your door interlock switches is defective . I would suggest having it repaired by a qualified repair tech in your area.
Oct 04, 2007 | Sharp R-1500 Microwave Oven
Microwave Ovens Logo
643 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
