Question about Yamata FY2600
Bobbin on singer Quantum XL - 1000 does not fit right was working but now it just moves around and does not fit tight
  • 323 Answers
SOURCE: Singer-Inspiration 4220/4228
Send this machine back where it came from! machine. You have described a timing problem which you can not and should not need to do.
Change the needle first and test it to be sure the needle still hits on the hook. If it does,follow the above instructions. If it no longer hits then it's possible it is not as serious as I first thought.I'm not sure if the bobbin keeps coming out or the bobbin case(the plastic part the bobbin sits in) comes out.If it is just the bobbin, insert the bobbin in the case and pull on the thread. The bobbin should turn COUNTERCLOCKWISE. If it turns the other way, turn it upside down and try it again.
If it is the bobbincase,then Remove the needle plate and take the bobbin case completely out. On this machine there is a small lever which holds the bobbin case in position. Looking down on the bobbin case the lever is located at about 11 o'clock and has a small slot in it. It is also probably spring loaded which means it is not easy to turn without a small screwdriver. Insert the screwdriver in the slot and turn it to the left. Lift out the bobbin case and Carefully examine it for any nicks, scratches or rough spots. If you find any, they will need to be removed with an emery stick and or a sharpening stone. Buff with a very fine steel wool for total smoothness.
To replace the bobbin case use the screwdriver to open and hold the lever open while you insert the case back in. The straight part of the case will be on the right and you need to place the case so that the circular part rides on the slight grove in the hook.(The metal thing it sits on). Once you have it in place you can release the lever you've been holding open . It should fit over the edge of the bobbin case and not allow it to come out. Rethread the machine and turn it by hand a few times to see that it is working properly. Good luck!!!
sewman7
Posted on Jul 01, 2008
  • 980 Answers
SOURCE: I have singer sewing machine. The black casing the
The black bobbin case that the bobbin sites in is not supposed to move at all, on the right hand side of the bobbin case you will see two screws, if you slacken them off you can push the guide bar closer to the bobbin case leaving enough thread to pass through the gap.
Posted on May 13, 2009
mythman
  • 84 Answers
SOURCE: Hi I'm trying to get some new bobbins for my
The bobbins are generally interchangeable between singer models.
You have to watch out for the bobbin case though as this is the one specific to model families.
Hope this helps.
Posted on Jul 03, 2009
  • 139 Answers
SOURCE: serial number for an Singer XL-1000 part
The part number is 385042. You can order parts through the Singer parts centers listed on this page:
http://www.singerco.com/support/replacement_parts_ssc_list.html
Posted on Apr 16, 2010
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
My singer quantum xl 1000 is stitching in one place
Remove plate over feed dog, femove bobbin and bobbin casing. My guess is that you have debris, lint or a piece of fabric stuck in the works
Dec 17, 2016 | Singer Quantum XL-1000 Computerized Sewing...
How to unlock the handwheel of my signer quantum xl-1000
Check the bobbin area and make sure there's not a tangle of thread keeping the hook from turning.
Feb 14, 2015 | Singer Quantum XL-1000 Computerized Sewing...
How do you get the auto threading and wind in place to work on Singer XL6000 sewing machine
There are several FB and Yahoo groups dedicated to the Quantum XL-1000, XL-5000 and XL-6000 who can help you. It may be that your problem with the autothreading is the autothreader is out of adjustment, but I'm at a loss as to the bobbin winder problem.
Jul 15, 2014 | Singer Quantum XL-6000 Computerized Sewing...
Can I use the Metal Singer Class 15 bobbins in my Quantum XL1000 embroidery machine
Hi betroy,
I would suggest you stay with the plastic bobbins. but if your still
in doubt contact the singer website & ask them. me myself I would
stay with the plactic bobbins, & I've been sewing for over 30 years.
you have a very nice sewing machine.
Jun 01, 2012 | Singer Quantum XL-1000 Computerized Sewing...
Need a bobbin case for singer quantum xl 1000 sewing machine
try these sites
sewingpartsonline.com
sew4less.com
singerpartsdirect.com
May 21, 2012 | Singer Quantum XL-1000 Computerized Sewing...
My Singer Quantum XL 1000 is jammed and does not move. The light is on. Please help
Try to turn the hand wheel (on the right side of the machine) backwards ( if you are facing the right side of your machine, turn it clockwise) and try to remove the thread. Once its freed up, change the needle.
Hope that helps,
Chris
Jun 13, 2010 | Singer Quantum XL-1000 Computerized Sewing...
I had my quantum xl 1000 sewing machine repaired.
Go to the internet, type find manual for Singer Quantum XL-1000, you should get a lot of links of which you can download.
Apr 08, 2010 | Singer Quantum XL-1000 Computerized Sewing...
I just purchase a Singer 301 and cant get the bobbin case out
Raise the bed extension, revealing the bobbin area. Gently pull out on the bobbin case latch and it should pop right out in your hand. Congrats on your 301, they are wonderful machines!
Jun 08, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Yamata FY2600 Logo
74 people viewed this question
Top Yamata Sewing Machines Experts
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
