Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker II
The microwave stops after a few seconds. it shows a sensor error. i have unplugged it, reset and the same situation occurs. it was manufactured in july 2002.
model number jem 31Ga002.
i have tried to unplg for a short time. if i enter a cook time, it still shows sensor error.
i will try a hard reset. is the sensor something that can be replaced??
  • GE Master
  • 9,149 Answers
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
Otherwise, yes, it may have a bad humidity sensor (gas sensor, as it's called) which needs to be replaced.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You should enter your model number as JEM31GA02.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or elsewhere inside, which is very helpful when troubleshooting, testing, and locating components.
Posted on Dec 17, 2008
Ge spacemaker II microwave started humming and nothing showing on monitor
My parents have had a couple of the spacemaker microwaves mounted over the range with the built-in vent. Over time, the seal on the control board gets a crack in it and the steam from cooking below it gets up into the control board and does it in.
Even if yours isn't mounted over the range, it sounds like a main control board failure.
Sep 10, 2016 | GE PEM31DMBB Black Profile Spacemaker II...
One day the microwave just showed PF on the screen, unplugged and plugged in tried to use it, worked for 30 seconds, stopped and showed PF again. Any ideas? It is only a few years old and used in our...
PF is Power Failure. Check and see if the Oven has a reset switch or power button. Try and hook up an extension cord, plug one end into a usable output (wall plate) and the other into the 110VA line plug attached to the Oven. Turn on....if it works then the problem is a circuit breaker or wall interface. If it fails with the extension, then it is an electrical problem with the microwave device itself. If there are no Reset features on the oven, an internal fuse may blow, or other shorts are occurring. The cost to fix is more than a new unit. Lowes has them as low as $150.00.
Dec 18, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
F4 or f5 on board if i unplug it and reset clock turnit on it runs for 2 or 3 sconds the display starts to blink it shuts off and you need to unplug and start over sometimes it will work
see this and fix it. read your section troubleshooting manual .God bless
you
  • F4--Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds.
  • F5--Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds.
Oct 15, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE microvave is not heating up and is very loud. Saying sensor error. We unplugged it for a few minutes and tried the hard reset. This did not work.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 =-=-][
Jul 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Error code -FS- on display with 3 long beeps
Hello :
Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds you need to replace humidity sensor .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not turn off.
it sounds like a mikro switch is misalined.
Dec 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave, runs only 2 seconds, then stops
The problem you describe on your JVM1650SH02 is a failing "noisy" magnetron which is emitting electrical interference that disrupts your microprocessor.
At my Web site, I have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
You will find a technical sheet hidden behind the grille or behind the controls. It's handy for locating parts and troubleshooting.
You can find an exploded view and parts list by entering your full model number from the tag here, and you can also order parts there.
On your model, you may need to remove the oven from the wall. The installation instructions here will be helpful.
Pro tip: In many GE models, dropping the floor plate that holds the high voltage transformer is necessary to get the magnetron in and out.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker II microwave. sensor error lite comes on
Sounds to me like you have a bad magnetron tube. Call GE Factory Service as there is either a 5 or 10 year parts warranty. Or schedule a service call online at www.geappliances.com
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
284 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
