Question about Pioneer PDP-4270XD 42 in. HD-Ready Plasma Television
How do i adjust mr pioneer pdp427 television set to play xbox
I cannot get my tv set to recieve the xbox signal , the instructions seem so easy to follow , friends tell me it must need fine tuning on the menu but i dont have the original manual, have followed the xbox instructions but cannot get the game onto the screen, have done all the colour coded plug ins into the tv but cannot find the right av channel? please help !
  • Anonymous Mar 08, 2009
    I have had exactly the same problem. I followed all the instructions but cannot get it to work
  • Anonymous Mar 21, 2009
    yep same problem, i have a mikomi tv by the way
    Top Expert:
  • Pioneer Master
  • 12,962 Answers
Get the manual from the mfg web site or try to google it.
here it is Pioneer PDP 427XD Manuals
Posted on Sep 22, 2017
  • 41 Answers
SOURCE: Have a Pioneer PDP508XDA its asks for a password when tuning
Default password is always 0000
Posted on Mar 30, 2009
dsacco86
  • 1077 Answers
SOURCE: Pioneer PDP-4340HD TV Media Receiver installation
With the cable splitter problem, I believe they used that idea to use the Antenna/cable A & B ports to watch digital and anolog TV.
Port A for Anolog and port B for Digital.
Posted on May 25, 2009
SOURCE: I have a Pioneer Elite
First remove plug from Wall. This should Re-set the unit. Now the set should be back to normal.
If it is still no go. Then you need to bring up the "Channels Menu, and scroll down to an Input and select the One that gives you a Picture, you can scroll through the inputs until, you see your signal. If getting signal from a decoder box, then the Input, will be an EXTERNAL one. If the Antenna goes straight into the TV, then you will use the "TV Channels" settings.
I have given you a Manual link, below, this will give you all the Info to sort this out.
http://www.manualnguide.com/download/manual-guide/pioneer-pro-fhd1-elite-purevision-plasma-tv-owners-manual.html
Posted on Mar 28, 2010
  • 11800 Answers
SOURCE: My Pioneer PDP-4280HD Plasma -
Press the TV Guide button on the remote. Press Enter and a series of windows will  appear:
1 - press OK to begin the setup process.
2 - select country  - using up/down keys, press Enter, select Next using right key and press Enter (this selection procedure will  work for all the rest).
3 - for US you will need to select a ZIP code.
4 - select the source of the signal - cable or antenna (for all the rest)
5 - select the jack in which the source of the signal is plugged in
6 - select Yes and it's done.
Beware, it may take some time before the guide appears, it depend on how often it is broadcasted, on some channels it's only once in a day.
Posted on Apr 18, 2010
  • 418 Answers
SOURCE: i have no sound through my surround sound when playing ps3
The optical audio out from the TV only works for the TV's tuner, probably. Hook-up optical from Cable/SAT and from PS3 boxes to DVD/Receiver.
Posted on Apr 20, 2010
I have no sound through my surround sound when playing ps3
Apr 20, 2010 | Pioneer PDP-LX508A 50 in. Plasma TV
How it get sound through the optical cable through a pioneer tv?
Hi
You normally need to tell the system that it is receiving an optical signal, on mine, which is a different model you have to select the relevant button that corresponds with the area in which you plugged the optical cable (ie video 1, video 2, audio 1, audio 2) and then press the system button followed by the set-up button. You should then be able to scroll across the options with the arrow keys, watching the display until you see input analog, then use the up and down arrows until you see optical. Bingo you should have sound!
Lou
Apr 03, 2010 | Televison & Video
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Choppy and distorted sound during gameplay with an optical cable
Check your pioneer unit settings, the ps3 settings are correct, and make sure you unplugged the audio cables. It sounds like a bad signal somewhere, which would cause the speakers to clip and distort. Make sure all of your surround sound speakers have a good connection if they have single wire runs to them and not a audio plug in them and there are not broken wires, or wires touching.
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
No Sound when I play DVD's
The optical connection on the TV is most likely an input, not an output. You need to connect the Xbox to the receiver, then the TV. If the receiver does not have a HDMI input, use another audio or digital out from the Xbox to the receiver.
Sep 19, 2007 | Yamaha HTR-5940 Receiver
No picture using component on Toshiba 32HL66
It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
May 30, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Pioneer PDP-4270XD 42 in. HD-Ready Plasma Television Logo
43 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
