LG TROMM noise during spin cycle
Rattling occurs when spin cycle begins; water not draining out
    Scholar:
  • 33 Answers
Dear Customer,
for ur water not drainin out, please do the the followin checks
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
  • n for ur rattling during spin cycle please do the followin checks..
    Please read our safety information before attempting any testing or repairs
    Before working on the washer, unplug the appliance or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
    A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive noise. There can be several causes and the problem is worse with some machines more than others.
    The most common cause is an unbalanced wash load. Open the lid and when it comes to a stop, redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit.
    A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See our article on how to level your washing machine.
    The outer tub is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons may begin to wear out and not support as much weigh as needed.
    Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be called for.
    Another common cause for excessive movement is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.
    There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
    • General tips mentioned above
    • Balance the load
    • Level the machine
    • Inspect the water pump for a blockage
    • Inspect the coupling
    • Inspect the transmission
    • Adjust the drive belt tension
    • Check the motor bearings
    • Check the drum brakes
    Please rate this solution.Thank you..
    Posted on Dec 16, 2008
    I replaced the rotor at the back of the tub and that stopped the noise and vibration. Washer is now quieter than when it was new. Cost me $53 for a new rotor and I just had to remove the back panel to change. Try this before going at the bearing.
    Posted on Jan 06, 2013
    Why won't my LG model WM2688HNM front load washer not drain? It spins and makes noise
    sounds like a bad or clogged water pump but may also have to look the door switch which on some models wont allow it to spin or agitate? a bad motor coupler will not allow spinning or have bad weak spin cycle sorry cant be more specific by the way front loads tend to be a pain in the___ to work on good luck
    Jul 26, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    Replacing the pump in my LG tromm
    cheaper to check for a problem in the impeller first as the pump motor seldom fail but there are problems with items jamming the impeller
    Oct 29, 2017 | LG WM-2277HW Front Load Washer
    Rattling noise in spin, spin problems becoming more pronounced. control panel lights flash but 0 error codes. unplug 2 reset, probl repeats
    If this noise is happening while it's trying to drain water then you have something floating around in the lump. Coins are very common. If the noise is happening during a spin cycle and more pronounced during the final high spin cycle, you have bearing or spin tub issues. Time to go shopping.
    Nov 07, 2013 | Frigidaire ATF6000ES Front Load Washer
    Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
    if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
    Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
    LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
    LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
    Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    LG Tromm WM2277HW during high speed spin makes noise
    I had exactly the same symptom...grinding noise only during high speed spin cycle.
    I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
    Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
    Aug 16, 2009 | LG Washing Machines
    LG Intello wm-1460FHD stops spinning during the wash load.
    OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
    Jan 11, 2009 | LG WM-1480FHD Front Load Washer
    Vibration during spin cycle
    Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
    Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
    If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
    Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
    Rattling noise during spin cycle
    Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
    Nov 12, 2008 | Maytag MAH2400A Front Load Washer
    Washing Machines Logo
    1,111 people viewed this question
    Top Washing Machines Experts
