I have a Konica 2223 copier - wont print on edges
Konica 2223 copier will not print on either edge of the paper. It was yesterday, not today. When the paper comes out horizontally, the left and right edges are not printed, but the rest is ok. Also error F28 continues about every 50 copies, but canned air solves that.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Check all edge settings .f28 is code for charger corona just clean corona assembly with cerosene oil and change corona wire with new one.
Posted on Dec 16, 2008
My printer has started printing a black line down the edge of the paper?
Remove the laser print cartridge, shake it lightly, and place it back into your printer. That should solve the problem.
Mar 15, 2013 | Kyocera FS-1030D Laser Printer
Can I print with no margins? I'd like to copy to go right to the edge of the paper.
NO!! no copier can do that. only print press can. you can print on 12x18 and cut edges if needed
Sep 21, 2011 | Konica Minolta Bizhub c203 Copier
The printer is printing dark along side the edges of the paper each time I print. I've changed the drum, but that didn't seem to help. What else can I do?
Print an empty word document, and if it still shows the dark lines on the edges the rollers are most likely caked with ink, and they will need to be cleaned.
Jun 09, 2011 | Konica Minolta Magicolor 2530 DL Laser...
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
May 20, 2010 | Konica Minolta Bizhub c203 Copier
Paper will stuck at the heater
HI i think you have a bad upper fuser roller thats why the paper rolled up with it or maybe there are finge clow are not good first of all just remove paper and just clean the upper fuser roller with fuser oil if yours fuser roller and finger clow are not damaged it will work fine enjoy
thanks
May 14, 2010 | Konica Minolta DiALTA Di200 Copier
How do i set up a konica 2223 copier to print using it as a network printer
the 2223 does not have that feature if you want a copier that is comparable to the same speed and features you would have to buy the konica minolta bizhub 222 new model or there are a lot of low mileage used bizhub 200 machines coming off lease for sale
Sep 28, 2009 | Konica Minolta Office Equipment & Supplies
Paper doesn't feed correctly
MAy be it needs to be away from dampness open window or something of the sort
Jul 29, 2009 | Office Equipment & Supplies
Frequent paper jams with my Konica 2223 photocopier
I wish I could help you, You need to call for service for your copier. An authorized dealer or Konica minolta branch service in your area. You might need a fuser unit that the upper separating claws disloge or broken, exit paper detect actuator is broken or disloged, or you need a new developer.
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
Printing Docs
This model does NOT support edge to edge printing.
You can have the document reduced to fit the sheet size in Excel.
Feb 19, 2008 | Konica Minolta bizhub C250 All-In-One...
246 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
