Question about Canon PIXMA iP1500 InkJet Photo Printer
Waste ink absorber full - contact service center for replacement
Continual Flashing - Green/Yellow control Buttons & message above
No information on Service Center.
No diagrams/information on where or how to change waste ink absorber.
  • msb_51 Jan 19, 2009
    waste ink absorber is full. how do i clean this or fix this . can not buy a new printer.
STEP 1:
- Disconnect printer from AC power
STEP 2:
- Press and HOLD the POWER button, and
connect printer to AC power
This simple power off procedure worked on my IP1500!
Cleaning the absorber was also easy. Power up with the cover open until the head moves to the left side then disconnect the power cord so the head is now positioned away from the pads.
The two pads can be lifted up easily with a pair of sharp tweezers then rinsed in running water. They will become white again and can be blotted with paper napkins then air dried in a warm location (I used an industrial oven set to 40°C). The wells in the rubber holder can be cleaned with cotton swabs before returning the two pads (left side first, then press down the right side).
Posted on Dec 22, 2008
Wiring problem
You best to go to a trailer service center
for the answers or a wiring diagram, if such
a thing exists.
Jul 07, 2013 | KZ 2012 Sportsmen Classic 19BH
Tip
Ford-Lincoln service light 1988-01
LS
2000-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the STATUS control to access the System Check mode. Press the RESET button to display OIL LIFE _% RESET FOR NEW. Press and hold the RESET button until OIL LIFE IS 100% is displayed.
Mark VIII
1993-97
When "CHANGE OIL SOON" or "OIL CHANGE REQUIRED" is displayed on the Message Center, turn the ignition on. Press and hold "OIL CHANGE RESET' or the "RESET" button until "OIL LIFE RESET TO 100%" is displayed on the Message Center.
Continental
1989-94
When "SERVICE" is illuminated, on the Message Center, press the "SYSTEM CHECK" button on the right of the display. Then press the "RESET" button. The "SERVICE" symbol and mileage will start to flash. Next, press the "SYSTEM CHECK" and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
Continental
1988
When "SERVICE DUE" is illuminated on the Message Center, press the "CHECK OUT" button located below the display. Then press the "RESET" button. The display should now read "SERVICE DONE?" Next, press the "CHECK OUT" button and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
on Dec 07, 2009 | Ford Lincoln Continental Cars & Trucks
Tip
Ford service light procedure 1994-01
Windstar
1999-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the message center, press the SETUP control to access the System Check mode. Press and release the RESET button until IF NEW OIL HOLD RESET is displayed. Press and hold RESET button until OIL LIFE SET TO 100% is displayed.
Windstar
1997-98
To reset "CHANGE OIL SOON/OIL CHANGE REQUIRED" message on the Message Center, press "RESET" and "SETUP" controls at the same time. "OIL LIFE % HOLD RESET NEW" will be displayed. Press the "SETUP" control to access the System Check mode. Press "RESET" to start the system check. Press and hold the "RESET" control. Press "RESET" and "SETUP" to reset the system to 100%
Explorer,
Mercury
Mountaineer
1997-01
To reset the oil life feature on the Message Center, press and hold the "OIL CHANGE RESET" button until the system counts down (about 5 seconds). The Message Center will display "OIL LIFE RESET TO 100%"
Probe
with Analog Dash
1989-92
When "SERVICE" is illuminated on the Vehicle Maintenance Monitor on the overhead console, press the "SERVICE INTERVAL RESET" button located directly above the light.
Probe
with Digital Dash
1989-92
Probe
with Digital Dash
1989-92
When "SERVICE INTERVAL CHECK" is displayed is displayed on the far left side of the instrument panel, press the "SERV OFF" button, located on the speed alarm keyboard, until three tones sound.
Thunderbird,
Mercury Cougar
with System Scanner
1986-88
When "SERVICE" appears on the Diagnostic System Scanner, press the "ODO SEL" and "TRIP RESET" buttons simultaneously. The "SERVICE" message will go out and three short beeps will be heard when the system is reset.
Thunderbird,
Mercury Cougar
1989-94
If "CHANGE OIL SOON" or "NOW" is indicated on the Monitor, turn the ignition on, but do not start the engine. Within 16 seconds, insert a paper clip into the cavity to the left of the display and depress. The display will flash; when it stops, the system is reset.
on Dec 07, 2009 | Ford Windstar Cars & Trucks
TV dead other than green flashing light
The problem might be cause by lamp error, need to access the service mode to change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
* Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control)
Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control)
* While holding the above buttons, plug in the TV.
* The TV will turn on with the "K" or "K123" appears om screen.
* Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have a 2001 LS Lincoln. No owners manual. The dash has a couple of codes on an led type screen for "change AC filter" and "change oil" messages. I did the work but the messages still...
Look for the Information Center panel above the Audio controls.. There should be 4 buttons labeled Fuel, Setup, Reset, and Status. With the engine running, press the Status button until the change oil required message appears, then press and hold the reset button until the message appears that says oil life restored to 100%. Do the same for the a/c filter.
Feb 26, 2011 | 2001 Lincoln LS
Tip
Cadillac service light 1989-01
Eldorado
2000-01
Turn the ignition to ON. Press the TRIP button on the driver information center (DIC) switch to view various menu choices and stop on OIL LIFE REMAINING. A message will display the percentage of oil life remaining. Press and hold the RESET button on the DIC switch for at least 2 seconds. A message will display the percentage of oil life remaining as 99 percent. The engine oil life monitor is now reset. Turn the ignition OFF.
DeVille,
Eldorado
1999
To reset the service Oil Life Indicator, display the
"OIL LIFE LEFT" message by pressing the "INFORMATION SKIP" (skip info) button. Press and hold the "RESET NO" (no info reset) button until "100% OIL LIFE" is displayed.
Deville,
Seville
2000-01
Turn the ignition to ON, Press the INFO button on the driver information center (DIC) to display ENGINE OIL LIFE. Press and hold the INFO RESET button on the DIC until the display reads 100% ENGINE OIL LIFE. The engine oil life index is now reset. Turn the ignition OFF.
Deville,
Seville,
Eldorado
1997-98
Display "ENGINE OIL LIFE" by pressing the "INFO" button. Press and hold the "INFO RESET" button until the message shows 100.
All Models
except
Fleetwood
1994-97
Press the "INFORMATION" button until "OIL LIFE LEFT" is displayed. Press the "RESET" button until "100" or "0.0 OIL LIFE LEFT" is displayed.
Fleetwood
1994-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds.
All Models,
Seville,
Eldorado
1993,
1994-95,
1994-95
The automatic transaxle message can be reset through the following procedure. If "CHANGE TRANSAXLE FLUID" appears on the Information Center, press and hold the "OFF" and "REAR DEFROST" buttons until "TRANS FLUID RESET" appears.
DeVille,
Fleetwood
1991-93
When "CHANGE OIL SOON" light is illuminated, press and hold the "RESET" and "RANGE" buttons on the Fuel Data Center for 5 to 60 seconds. When the buttons are released, the light will flash four times if it has been reset. If the light comes back on for more than 5 seconds, repeat the procedure.
Allante
1989-93
When "CHANGE OIL SOON" appears on the Driver Information Center, press the "RANGE" button until "OIL LIFE INDEX" shows on display. Then press and hold "AVG SPEED" and "RESET" (or "RANGE" on late models) buttons until display shows "100".
Seville,
Eldorado
1992-93
Press "INFORMATION" button on the Driver Information Center until "OIL LIFE INDEX" is displayed. Press "STORE/RECALL" until "OIL LIFE INDEX" resets to 100.
Seville,
Eldorado
1989-91
When "CHANGE OIL SOON" or "CHANGE ENGINE OIL SOON" appears on the Driver Information Center, press "ENG-DATA" button until the "OIL LIFE INDEX" appears. Then press the "ENG-DATA" button and the "RANGE" buttons at the same time until 100 displays (about 5 seconds).
on Dec 07, 2009 | Cadillac Eldorado Cars & Trucks
What are the red green blue n yellow buttons on the remote for??
Hi!
With the controls on the machines themselves pared down to the barest minimum, and virtually every operational setting done through software, and more interactive content being developed, the remote control is an even more crucial tool. Sony’s remote has a logical, well-designed layout. Along with many of the common features from DVD-Video remote controls of Audio, Subtitle, Angle and Display, the S350’s remote adds special buttons for the Pop Up Menu, Options and Scene Search. It also includes a group of Red, Green, Blue and Yellow buttons just above the navigation wheel in the center, which can be programmed for special functions by title authors. They are also used like Shift and Control keys on a computer keyboard when using the remote to enter text and number information. Green has become the default for setting Book Marks, but this, Scene Search and many other features are authoring choices, not necessarily standard on all titles. Perform functions assigned to each button. Assigned functions vary depending on the content being played.
You may also refer to the following web site---
Sony PS3
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 12, 2009 | Sony BD Remote Control for Playstation 3
Flashing green light prevents printing.
hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Aug 08, 2008 | Canon S520 InkJet Photo Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
809 people viewed this question
old marine
old marine
