Question about Sony PlayStation 2 (PS2) Console
DISC IS NOT SPINNING
I put the disc in and just the laser move forward and disc is not spinning
would you please help me
Thanks in advace
Regards
Alfred
  • 96 Answers
Sounds like your rubber band broke, or is loose(if in fact it has one). It's one of those things that will require you to open the console. That or your cd spin motor bit the dust. Sorry but there is much to do but hope it wasn't the motor.
Posted on Dec 16, 2008
When i put a disc ...the screen goes black and then it says error reading disc please press the eject button and turn the console off. what do i do?
The cause here is the Drive itself is ether dirty or showing signes of intermittency now the folks at www.videogamerepair.com can take this into consideration and have it repaired for you if its under warranty or not give them a try. Otherwise you might need to have nontendo get involved.
Thanks
Aug 03, 2010 | Nintendo Wii Console
Ps2 powers up, but disc is not spinning and
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
Nov 18, 2009 | Sony PlayStation 2 (PS2) Console
Unable to read disc error
Laser or motor to the laser is bad
Thanks, Frank Z.
3868607368
http://www.attechcomputers.co.cc
Jun 21, 2009 | Nintendo Wii Console
Ps3 not reading discs
Hello
When you put in a disc, listen for the disc to start spinning. If you do not hear that then the laser and/or the spindle have blown out. You will have to get your Blu-Ray player serviced by a pro or Sony. Sony may fix it for free. They know that the drives are failing. So call them first. If you know how to do it yourself, you will need part KEM-400AAA / KES-400A if it is not spinning. If it's spinning and not reading the laser may be dusty or need replacement. The laser by it's self is part number is KES-400AAA. If you need any more information, please do not hesitate to hit my "Ask Me" button.
I hope this helps! Good luck to you.
Aug 01, 2008 | Sony Playstation 3 (PS3) Console
Not reading my disc
Hello!
Help!
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
NO Cds spinning in ps2
try to stand it up on it's side or lay it down.
Apr 10, 2008 | Sony PlayStation 2 Slimline Console
Disc error
Assuming you've tried regular nonrecorded DVD discs, there are many things that can cause this:
Dirty or defective laser. (try a cleaning disc).
Disc not spinning.
Laser not moving on slide rail.
I would at least try cleaning the laser lens before giving up.
Hope that helps...
Geno
Mar 24, 2008 | Televison & Video
PS2 Slim Will Not Read Games
HI Pepper,
You need to try clenaing the Laser Lens. This is done by Using Q-tip and a window cleaner like Windex. Lightly Dampen one end of the Q-Tip and swab the lens with a slight bit of aggression. Use the Dry end of the swab to dry the lens. Try it out. Also you could have your laser gear popped out. look at the long worm gear to be sure it is stuck in the black holder. This should help you. In the unfortunate event it does not, you probably need a new laser. I do think you will get it working becasue you hear the Disc spinning. If the Laser was really dead, the disc would not spin as in it cannot tell the computer the laser sees a disc. Does the same thing as though no disc is in the drive bay. Contact me at Repairtech@PlaystationClinic.com if you need service.
Nov 02, 2007 | Sony PlayStation 2 (PS2) Console
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
