Question about Garden
Removing flywheel Is the flywheel on a model 36 Husqvarna saw threaded? How do I remove it?
  • 211 Answers
Hi
Remove the sparkplug.Into the cilinder through the sparkplug hole enter a starter rope with many nods on it to block the piston in the cilinder.Unlock the locknut counter clockwise and remove the flyweel.
best regards savumihai71
Posted on Dec 16, 2008
How do you remove the flywheel to get at the coil on a ts350 stihl saw
The official way to remove it is an M10x1 'Knock-off-tool' right hand threads. A 2 or 3 jawed puller will not remove the flywheel, and guaranteed damage will occur. Flywheels and crankshafts have a tapered design, so when installed with a nut, the taper tightens as the nut is tightened.
OK, you probably do not have one of those on your work bench, so lets make one or something like it.
1) remove spark plug,
2) insert a 12" piece of recoil rope (use about 6 or 8 inches) into the plug hole.
3) rotate the flywheel counter clockwise until the rope has bunched itself into the top of the cylinder, stopping the piston before 'top-dead-center'
*note: this would act as a replacement for a 'piston stop'. The rope is soft, so no damage to piston or cylinder will occur. If the rope gets caught on a cylinder port, you can back up the rotation, pull the rope out, and retry inserting the rope.
4) After removing the original flywheel nut (right hand threads, so righty-tighty, lefty-loosy)
purchase two M10 nuts, thread them onto the crankshaft (but not against the flywheel) so that the end of the crankshaft is not above the last nut.
5) turn the saw over to position the flywheel up, with a medium weight ball-pean hammer, strike the top nut with a good sharp wrap.
**note: Do NOT hit at an angle, use a square, straight down strike. Do NOT strike the end of the crankshaft. 2 strikes should do it, grasp the flywheel to check to see if it has loosened.
6) When reinstalling the flywheel and nut, tighten with the same force as when removing. 20 ft.lb. is the official torgue.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Jan 29, 2017 | Stihl Garden
Wont start replced spark plug cleaned carb
If you have good fuel and a good spark it may be a mechanical issue, remove the muffler and check the condition of the piston face through the open exhaust port, any signs of damage or scuffing and it will need to come aprt to assess the damage, if all looks good it may be a crank seal leaking, the 36 was prone to blowing the seal behind the flywheel, also check the flywheel key in the flywheel has not sheared knocking the ignition timing out.
Dec 06, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Have a 16" Model 36 - need to replace clutch? How is this done?
Remove the muffler so that you can observe the piston position and turn the engine slowly until the exhaust port is just starting to open on the down-stroke. Stop at that point and fill the combustion chamber with starter or other fine cord to prevent the piston from rising much further. The clutch should now be able to be removed by rotating the internals CCW (left-hand threads). Don't try to use an impact wrench for this as it will cause the flywheel key to shear. If you are having problems getting the chain to move and there is no obvious mechanical damage with the clutch, try washing the clutch interior out with spray carburetor cleaner, let dry, re-assemble and test. Hope some of this helps!
Jul 11, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My Husqvarna 232R brushcutter pull cord will not start
There should be several 'dogs' exposed after removing the starter assembly. These 'dogs' should rotate into the flywheel nut when the cord is pulled causing the engine to turn. Check with a Husky servicing dealer for parts. Good luck!
May 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a Husky 55 Rancher, was sawing a tree and
Yes. this checks both. Change the plug first <$5 plug >$50 coil.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
Ignition module gap
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Husqvarna Garden
I have a 338 xpt California Husqvarna chainsaw that the flywheel has been slipping; cast in key. I got another one, but it doesn't have the separate weight on the back. It's the same size and configuration...
I suspect the new flywheel is a little better balanced than the first (test it) and does not need the additional weight. Is it the same part number (537 23 39-01)?
I looked at the Husqvarna site and ALL 338XPT California models use the same part number flywheel. None show a separate key.
At $100 each for replacements I might take the original flywheel to a local machine shop and ask about machining a Woodruff key slot. Take your saw and the old flywheel once removed; he may need to "Mic" the crankshaft slot; take the new one too; it can also be "Mic"ed.
You ask a good question (separate key). Have you asked Husqvarna or your local dealer? There may be some unannounced help.
HusqvarnaUSA Contact Us
Manuals for your saw are here:
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification)
Lou
Mar 06, 2010 | Husqvarna Garden
Model 45 has two key ways on the flywheel. which
This?
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/532ebc94fa5b1fd588256b520015c198?OpenDocument
The age of your saw and the scope of your question exceed the level of help we provide.
This is an international group of chainsaw enthusiasts that will almost certainly welcome you and provide a solution to your problem. they are a GREAT bunch of folk, please treat them with as you like to be treated. There are often threads dedicated to specific manufacturers and occasionally a thread dedicated to your specific saw. Please try a search before posting. Joining an existing thread often bears fruit. Starting a new thread may not.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Good Luck. HTH
Lou
Feb 19, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a 55 rancher with no spark whats the deal and what is the gap for the plug and the coil?
Specifications for your saw can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/a752ecc0ff5478a688256b5200162a96?OpenDocument
Parts listing can be found here:
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
Dec 27, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Ineed to remove flywheel from 365XP Husqvarna to split crank case
The thread is RH, loosen the nut un till its just flush with the top of the crank threads, use an soft metal drift, copper, allly, brass etc.
hold the fly wheel and strike the top of the nut with the drift it will pop the fly wheel off. you may need a hand. if it wont come off use a screw driver under the fly wheel and pry it up when you strike the nut..Dont hit the nut /shaft without the soft drift...you will destroy the shaft.
the clutch thread is LH..
Jan 15, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna chain saw oiler
My Husky 36 did this. The oil pump drive gear was stripped and had to be replace. It's located under the flywheel/sprocket so you have to pull that. I couldn't find info on how to do that so had a local shop repair it for $70! Parts are cheap, labor is not.
Oct 22, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
94 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
