Question about Motorola Walkie Talkie 2-Way Radio
Motorola Talkabout Basic
Hey! I Think I have the same radios as you (Motorola Talkabout Basic). I figured out how to change the sub-channels: Press & Hold the monitor button, then wait for It to give you the frequency. Without releasing the monitor button, press the Push To Talk Button. It'll change the sub-channels. Now I have another problem: Everytime I press the Push To Talk Button, It'll change the channels. Anybody has a solution for this problem? Thanks!!! H2O.
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
Posted on Dec 31, 2008
I have old motorola talkabouts..and don't remember to change the channel. can you help? They are Yellow and have no screen on them...I can't find any model number on them. the date is Dec 1998 it...
Hold the push to talk(PTT) button while turning the unit on, it will talk to you. press PTT to change channel, push monitor to switch to codes, press PTT to change codes. When you have the correct settings press monitor and it will confirm settings.
Jun 13, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
Have Talkabout 250 and want to turn off the beeping. any ideas
The following instructions are for the T289, which is very similar to the T250. It is possible they will work to turn off your beeps.
Alert Tones
The Alert Tones (beeps) on the Talkabout radios are set at a fixed volume
level and cannot be lowered. However, Alert Tones can be disabled. When
Alert Tones are disabled, the radio will receive messages at the volume
setting you've selected, but you will not hear beeps when you press control
buttons.
Disabling Alert Tones:
1. Hold down the Monitor button while you turn radio on.
2. To re-activate Alert Tones, turn the radio off, then on again while holding
the Monitor button down.
Here is a link to the user guide: http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
Oct 20, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
One radio will receive messages but will not send a message
It is possible you have your PL code set differently between the two radios.
Instructions: Hold the PTT in while turning the radio on, listen for the code to be announced, use the PTT if needed to change the setting, then press the monitor button to lock in the setting. It will then announce whether it is 12.5 or 25k channel spacing. Use the PTT to change the setting if needed. Then press the monitor again to lock it in.
If you need more assistance give us a call. (google our name)
Best regards.
Oct 18, 2010 | Motorola Talkabout Distance DPS (10...
Frequincy changing
press and hold the + button untill the frequency changes then move up and down to the one you want.
Apr 25, 2010 | Motorola Talkabout T5800 (22 Channels)...
Bearlyhere26 I bought a pair of Motorola
Commonly called the TalkAbout Basic. With the radio turned on hold in the monitor button. It should announce the current setting. Use the PTT button to change the setting. Press the monitor button to lock in your selection. When done shut the radio off and then turn it back on.
Jul 28, 2009 | Motorola Radio Communications
How do i change the channel?
Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies. Figure 16.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jun 25, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
Sub-Channels
Here is a link to a list of older TalkAbout user manuals. Use the pulldown menu to look at various models. In general, most of them program similarly by using the menu button to select the feature and the PTT button to lock in the change. http://www.giantintl.com/motorolafrsold.htm
May 26, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
What will i do to connect Motorola T5720 and T5728
Set both the frequency and the interference eliminator code to match one another. (The big number and the small number) Here is a link to the owners manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Basic instructions:
Press the Menu Button
The freq number will flash
Use the + or - button to select the frequency.
Press the PTT button to save the channel setting.
To set the code:
Press the menu button until the code starts to flash (the small number)
Press the + or - to select the code.
Press the PTT to save the code setting.
Once you have both radios matching on frequency and code, they should communicate together.
Aug 21, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout
Hello trailrunner,
Back when Family Radios first came out a number of manufacturers came out with both standard 14 channel radios and scaled-down single channel radios designed as entry level offerings. My guess is the radio you have is probably a single channel unit based on what you describe. It probably operates on FRS channel 1 (462.5625 MHz).
If you post the model number and FCC ID number (which should be located on a sticker on the back of the radio) I might be able to give you some more information.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 08, 2008 | Motorola Talkabout 2-Way Radios
Radio Communications Logo
347 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
