Question about Frigidaire GLGR341AS Gas Dryer
Fridgidaire Gas Dryer - Mod.#FDG 546 RBS 0 Press start button just a humming noise, drum doesn't turn. Tried rotating the drum manually and it turns only with great effort so I don't think is't a belt. 12+ years old so I think the motor might have seized. Your thoughts?
  • Frigidaire Master
  • 8,220 Answers
Your glides are brobably broken and missing. This will make the drum hard to turn and bind the motor. Get the front off the dryer:
Fridgidaire Gas Dryer - Mod.#FDG - 7411f19.jpgStart by popping the top with a putty knife.
Get the screws out that hold the front on and take a look:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 16, 2008
My fridgidaire gas dryer wont Start
The belt could be stretched. The motor runs but can't overcome the inertia of the drum to achieve rotation.
Dec 16, 2013 | managemylife.com
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
How to get to dryer drum. GE mod#dbvh520ej2ww
Hello there and welcome to fixya
The most common problem with these are the motor or the motor bearings or rollers
and next is clothes getting caught between the drumb and the shell of the unit
Here is some troubleshooting help for you listed below
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor
Dec 15, 2011 | Whirlpool Dryers
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Oct 02, 2011 | Kenmore 63942 Dryer
The dyrer will not turn on. The dryer makes a humming noise but will not turn on.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Also, check the blower on the dryer to see if a article of clothing may have gotten stuck there and preventing the motor from running.
Jan 22, 2011 | Whirlpool Dryers
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 18, 2011 | Kenmore Dryers
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
Jan 17, 2011 | Maytag Dryers
Have a Kenmore 90 series gas dryer. When I press the button to turn it on, it makes a noise but won't start
Assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Check the blower fan and motor for any obstructions.
Jan 09, 2011 | Kenmore Dryers
Maytag dryer mod #mde600ayw only makes a humming noise when start switch pushed will not turn.
a hum with a burning smell means the motor winding has failed.
you can try this: open the door and hold in the door switch, have another person hold the start button. You manually roate the drum by grabbing a fin and moveit while the unit is humming.IF the dryer starts, you need a motor.
Good Luck!
Feb 28, 2009 | Dryers
I have a Kenmore Elite Gas Dryer in which the drum does not turn. After selecting the mode switch and depressing the start button, the dryer only hums with no turning of the drum.
Disconnect the dryer from its power source before servicing!
Inspect for a brokren drum belt. The humming noise is probably the motor running with no belt. You can easliy identify this by opening the dryer door, rotate the drum by hand by using a baffle as a gripping point. If the drum rotates freely, the belt is gone. If you feel a slight degree of resistance or drag, then you will have to go internal to inspect for the belt and associated rollers and idler pulley to make sure they are free rolling.
Jun 07, 2008 | Dryers
Frigidaire GLGR341AS Gas Dryer Logo
287 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
