Question about GE ZV750SY Kitchen Hood
GE Monogram Overhead Hood is drippiong water
It is -30C outside and the overhead hood is dripping water when I turn it on. This is a brand new house and a new hood what can be causing it to drip.
  • nici
    nici Feb 11, 2015
    Well finally I decided to try to cut the extra pipe outside the roof and keep only the insulated part in the roof plus just the "reverse J" outside (the exhaust) . I works. No more condensation dripping. You should not have more than a few inches uninsulated in a vertical pipe
  • nici
    nici Feb 11, 2015
    it works should I have written
    New Friend:
    Problem Solver:
I have the same problems with my vertical hood duct. Condensation si causing the humidity of the room that slowly escapes to condensate and come back down. I insulated with rigid polystyrene foam to R-7 but it is not enough yet. I think I'll need to make it go horizontal as soon as it goes in the roof and the condensation should be on a down slope to the outside
Posted on Dec 05, 2014
  • nici
    nici Feb 11, 2015
    Well after insultain the pipe in the roof, I cut the extra pipe that was insulated outside the roof and the problem stoped.
  • 10,865 Answers
The hood pipe vents through the roof. Either the shingles around the pipe, or the rubber flange the pipe goes through is allowing water to enter and run down the pipe.
Someone will have to go on the roof with a tube of roof cement and look for a void in the flange or the shingles. For sure I would run a bead of roof cement around the pipe where it goes through the flange.
Posted on Feb 10, 2009
Dripping Water from Hood
The outside vent is not shielding water from entering
Sep 17, 2009 | Kitchen Ranges
Lights on overhead unit on garage door opener will not go off
This is not too uncommon. What tripped the breaker in your house also got to one of the relays on the logic board of your opener. The only cure I know of is a new logic board.
Jun 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
I think you have a basic design problem here. I wish I could see drawings and digital photos. I think I would have found a way to run horizontally then down to discharge. I would not go up through the roof. The duct run would be stainless snap together sealed duct with a ceramic firewrap around it. At the intake Id place a bimetalic safety to open on fire with manual panic switches. The blower would be at the final exit point. You could add a small director piece on discharge. Virtually every kitchen I see is woefully designed and no where near GREEN. Lets expand this conversation.
Mar 19, 2009 | Kitchen Ranges
Need a duel fuel range
We love ours have had it for two years. We have the 48" Dual fuel with the grill on top. Model ZDP48N6RH2SS.
The only issue we had to adjust to is the btu's (stove top flame) are so high and there is designated simmer burner or low btu burner.
The grill is excellent especially in the winter but you have to follow the instructions. First time use we didn't let it heat up long enough. Patience - it's worth it.
That's for our model from 2006.
YOu must be sure to get a strong enough range hood for the range you buy.
Dec 24, 2008 | GE Monogram ZDP48L4GHSS Dual Fuel...
ZV800SJSS GE Monogram
most normal hoods cost about $60.00 to $100.00
Jun 10, 2008 | GE Monogram ZV1050SFSS 42" Island Chimney...
ZV30SSF GE Monogram Hood Lighting
I found them at http://lightbulbsdirect.com look for
MR1650E26120
JDR Type Medium Base (E-26) / MR-16 2 Diameter Flood / Line Voltage / 50 Watt, they were only $5.99 each. apparently GE charges you $19.50 if you order through them.
Feb 17, 2008 | GE Monogram ZV30SSF Stainless Steel...
Fans are blowing instead of extracting!!!
just wondering what the problem you had was ? as i,ve just fitted a hood and have the exact same problem....
Cheers !
Aug 30, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Ge monogram hood has power but not working
Diana, the tech sheet I have states that if the unit has a power interruption, reset the house circuit breaker to the hood, if made before 2001. If after 2001, serial number beginning with DA press the start button to reset the hood. Let me know if it worked, Catriver..post back.
Mar 10, 2007 | GE ZV750SY Kitchen Hood
GE ZV750SY Kitchen Hood Logo
568 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
