Question about ATL Telecom Quantum Scalar 24 - Tape library - 9.6 TB / 19.2 TB - slots: 24 - LTO Ultrium ( 400 GB / 800 GB ) x ... (9-00710-02) LTO-3 Tape Drive
Windows 2000 can`t see the driver for quantum scalar 24
After install quantum scalar 24 on system running windows server 2000,its showing me IBM ultrium -td3 scsi seguential devices which the drivers is not installed and i don`t know where to find it to fix this problem
Tape drive is showing red light 5, what is the issue
Please. could you talk me about the tape drive vendor?, (HP, IBM, others). Then, I thing can help you.
thanks.
Oct 22, 2014 | Quantum Technology Quantum Scalar i500...
Windows xp installation
Insert xp cd, follow the setup procedure and that is it ... finish with installing needed drivers.
Apr 23, 2014 | IBM System x3500 M2 (783932U) Server
DHCP Server Conflict
Login into tape library console using web browser and disable DHCP and provide Static IP .
Mar 30, 2012 | Quantum Technology SCALAR I80 LIB 1XLTO-5...
I cant intall window 2003 in IBM server x3400 , wher to find the SCSI driver < took me 24 hours and i didnt find it yet anyhelp thx.....
You can install Windows 2003 using IBM Service Guide CD. Its an image file (.iso) . Burn it after download . Then boot from cd and follow the simple wizard . Find the link below
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5088993
Thanks
Nov 15, 2011 | IBM x3400 Server
How can i install windows xp?
This machine is built for Windows NT and Windows 2000 Server
i am not sure that IBM have XP for this machine if you have XP for any other IBM machine you can install but it will be very hard to find drivers for this machine you can check in IBM website or Lenovo website
Hope it will help
Aug 25, 2010 | IBM eserver xSeries 205 8480
About ibm server x3400 drivers
You can download the drivers from IBM's website:
http://www.ibm.com/support/us/en/
Aug 31, 2009 | IBM x3400 Server
I cannot install windows xp in ibm x3400,the system is currently raid5,it shows message hard disk not detected. thanks
I believe your HDD must be a SCSI disk whose drivers might have come along with the HDD.While installing XP it gives an option to install third party drivers for your HDD, Hopefully after that it would start detecting
Aug 26, 2009 | IBM x3400 Server
Installing windows xp on an IBM X-3200 machine
power off the server
connect the SATA HD direct to the sata connector on the motherboard.
turn on the server with XP CD and use the drivers on servers DVD companion
download LSI controller driver for XP and Intel chipset from the web and install, once the controller are set power off the server.
put the SATA HD back on the SATA Bays (Server front)
Turn on the server and DONE!!!
May 30, 2009 | IBM SYSTEM X3200 M2 E4600 2.4G 2GB 2MB...
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
Install windows xp on a IBM xseries 200 8479 computer
You have to download the scsi driver from the ibm site. You'll need a floppy and floppy drive. When you boot with your xp cd to setup press F6 to install driver.
Link to your IBM. Since IBM have different models you have to type it at the provided link.
http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/brandmain?brandind=5000008
good luck
Dec 20, 2007 | IBM eserver xSeries 200 8479
ATL Telecom Quantum Scalar 24 - Tape library - 9.6 TB / 19.2 TB - slots: 24 - LTO Ultrium ( 400 GB / 800 GB ) x ... (9-00710-02) LTO-3 Tape Drive Logo
77 people viewed this question
Top ATL Telecom Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an ATL Telecom Computer and Internet Expert? Answer questions, earn points and help others
