Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
Help :( i can't start up my laptop it wont let me :(
My HP pavillion zv6000 is completely broke :( everytime i try and turn it on, it shows the HP logo screen the flickers and goes to a page which says "we apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this. If your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders, choose last known good configuration to revert to the most recent settings that worked. If a previous startup attempt was interrupted due to a power failure or because the power or reset button was pressed, or if you aren't sure what caused the problem you can choose start widows normally."
It then gives me a list of 5 option's which are... "Safe mode  Safe mode with networking  Safe mode with command prompt  Last known good configuration (your most recent settings that worked)  Start up windows normally"
Under these options it says "use the up and down arrow keys to move the highlight to your choice." it then gives me 26 seconds to pick an option.
None of the options will work, they all bring up writing on the screen which comes on very fast, then it all flickers blue then white then goes blank. The laptop then loads the HP logo again but this time then loads the Windows XP screen, but after a few seconds flickers and goes off. The laptop then automatically comes back on and brings up the same option screen as before. I can't do anything with it and i need the laptop as i have very important exams coming up. Please help x
  • 3 more comments
  • gymchick Jan 02, 2009
    I have the same problem but when i go to highlight the options the up and down arrows wont work
  • Anonymous Jan 03, 2009
    i have the same problem, too. Need some advice on this please!!!! Thanks.s
  • moorelinda58 Jan 03, 2009
    i have the same problem too. Please help.
  • drew1677 May 04, 2009
    I HAVE THE SAME PROBLEM
  • Anonymous May 14, 2009
    Same Stupid problem!!!
    Scholar:
  • 157 Answers
What i can help this...
you select safe mode and remove video driver and reboot your laptop...if it inside the windows normally,try to remove some unused toolbar in add and remove programs..and check also for virus scan..and reboot computer..
Posted on Jan 03, 2009
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
HP Pavillion dv6700 won't load up - gets stuck on logo page
i afraid that cause by hardware, but try to remove battery and only use the power. or press F2. if prsseing f2 the new screen(bios) open try restart and press F8. tell me is it work or not
Jan 28, 2009 | HP Pavilion DV5234US Notebook Laptop
Screenlight on/off problem
Try turning up the brightness function key on the keyboard, I have had the same problem and this is certainly better.
Dec 16, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
HP Pavillion zv6000/ USB Problem
Go to the HP support for this PC at http://welcome.hp.com/country/us/en/support.html and search for your laptop.  Here you can download the USB drivers or any updated drivers that you may need.  If still no dice, then uninstall the USB driver, restart and try loading it again from the download.
Oct 29, 2008 | HP Pavillion ZV6000 Notebook
Screen dim to black
This will be a problem with either the screen inverter or screen backlight. You will need to take it to a shop for diagnosis, in order to find out which one it is. If it turns out to be the backlight, then the entire screen will have to be replaced. They are considered a sealed unit, and the backlight can't be changed out.
Jul 24, 2008 | HP Pavillion ZV6000 Notebook
Ac cord
And the problem is??
If nothing else, go to ebay. cheap prices, plenty to choose from.
If money doesn't matter and you're in a hurry, purchase a high quality "universal" power adapter, such as ICE. Make sure it carries 90 watts and can handle the appropriate amperage.
Good luck
Feb 08, 2008 | HP Pavillion ZV6000 Notebook
Hp pavillion zv6000 white screen on startup
bad video maby bad ram bad screen one of them or bad power chips on mobo worse case
Jan 29, 2008 | HP Pavillion ZV6000 Notebook
HP Pavillion ZV6000 AC Adapter
there is battery problem dear so replace your battery u will get result..
Jan 15, 2008 | HP Pavillion ZV6000 Notebook
Narrator,on screen keyboard,magnifier.
Open the Ease of Access Center in Control Panel by pressing the Windows Logo key + U.
Or, select:
  • Start
  • Control Panel
  • Ease of Access, and
  • Ease of Access Center Narrator,on screen keyboard,magnifier.
  • Got to each one and shut off.
Dec 24, 2007 | HP Pavillion ZV6000 Notebook
Screen Blackout
u must be having problem in output display driver,,,try replacing it
Oct 31, 2007 | HP Pavillion ZV6000 Notebook
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
1,239 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
