Question about Kitchen Ranges
Neff T1323X0 Hello, I am trying to wire in this hob. I just want to connect the mains cable from the cooker socket but the instructions are very obscure. Can you help me with the right configuration as there are 3 types called "N1 N2 and N3" . Why cant it be simple like it used to be!!!!! Brian
5 Suggested Answers
  • 183 Answers
SOURCE: The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Posted on Jul 28, 2007
  • 833 Answers
SOURCE: smeg gas hob issues.
Ghazwan,
Relax. The problem is in the switch that is activated when you turn the gas on. It has either misaligned or broken. The gas itself is not involved. Generally, raising the top of the burner area will gain access to the switch and valve. Inspect and readjust or replace. Oh, and disconnect the electricity before touching the switch itself.
Posted on Mar 07, 2008
farfield
  • 462 Answers
SOURCE: wiring a indesit hob and oven
Minimum wire size is at least #8 and maybe #6 depending how far you are from breaker box. If close to 100' (75 or more) Go the #6. But Im not sure what a hob is.
Posted on Apr 23, 2009
  • 3077 Answers
SOURCE: Lofra cooker turns itself off
Hi looked on the wed could not find anyone only lofra try try them, hope this helps
Posted on Jan 16, 2010
Have a neff t1213xo, what does black grey and brown wires stand for?
You have an hob with European three phase at 220volt mains wire connected.
You need to to disconnect from mains connection box on hob and fit conventional British brown, blue and green/yellow.
Inside the connection box you will see three live terminals,(L1,L2 & L3) there are usually some brass links to join them all up and then attach brown core to one of them. If the links are not there then you will need to fit 2.5mm links from a piece of wire.
Nov 24, 2014 | Neff Ovens
We bought a discounted display model Neff single oven from Comet and have booked an electrician to wire it in however there don't appear to be any cables coming out of the back of the cooker so how is the...
He will probably hard wire it from the terminal block inside the back panel of the oven into the cooker switch or outlet plate on the wall.(providing there is one, if not he will have to wire it back to the main fusebox) .
Dec 17, 2010 | Neff Ovens
Do all neff oven & hobs have to wired in using 6mm cable or can they be wired into a13 amp system
If it is a single oven on it's own then it can be used from a 13 amp plug and socket, the same with the hob, if it is seperate from the oven it can be used from a 13 amp socket.
If it is a combined unit, then it will have to be hard wired to a seperate circuit using 6mm twin and earth cable, and fused on it's own circuit.
Nov 07, 2010 | Neff B1421 Electric Single Oven
Ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Feb 22, 2010 | Cooktops
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 | Cooktops
Wiring a indesit hob and oven
Apr 23, 2009 | Indesit Kitchen Ranges
Trying to get hold of a fitting instruction leaflet plus list of spare parts for a gas hob code no. E4NE T2484SOEU/01
Why do you need a fitting manual ? Any competent gas engineer should know the contents of BS6172 / BS6891 which both apply to the fitting of domestic gas cookers / hobs. What spares do you need. You can get a spares inventory from Neff. Ensure that it is the correct appliance for the fuel gas you are connecting to. The jet sizes for LPG & Natural Gas are very different.
Apr 16, 2009 | Neff T2346 Gas Cooktop
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Nov 28, 2008 | Neff T1323 Electric Cooktop
Neff Hob
Hold the power button for a few seconds
Feb 16, 2008 | Neff 23 in. T1443 Electric Cooktop
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
