Question about HP Pavilion dv6000z Notebook
The lights of my laptop monitor is off i can see that there is a dispaly but the screen is dark and i cant see anything unless i really gazed,,,,
  • allaa_nassar Dec 16, 2008
    it is an HP compaq 6710b
    i guess it is the back light
    what can i do if it is burnt out...???
  • Chase May 11, 2010
    Sounds like either the back light on the LCD is burnt out or the brightness on your LCD is set very low...more than likely it's the LCD if its really that dark. Who manufactured the laptop are you using?
  • 46 Answers
If it's under warranty you need to send it in. This is either a bad inverter or a bad backlight. If you can see windows and such, you can attempt to turn up the brightness, but it shouldn't be 'that' dark. I am absolutely positive it's your backlight. The only thing you may be able to do is to open up the laptop and unplug and replugin the inverter. I suggest you let a techie do that. However, if you really want to fix it yourself, just type your laptops model into ebay and search up inverter or backlight, and see what comes up. They shouldn't be more expensive than 40 bucks realistically. LCD's on the other hand are hella expensive. (Which, if you can see the display, like icons and such if you look closely, it is not the LCD which is the problem, just the backlight which typically rests on the bottom of the LCD bezel behind everything) The backlight is obviously important to see stuff that the LCD is producing. Also, one quick note, sometimes you can manually turn off and on your lcd inverter by pressing F1 or F2 while in the desktop while holding down the Fn key.
Hopefully this helps, remember to rate!
Stay spicy and happy lappying :)
Posted on Dec 17, 2008
  • heatherle551
    heatherle551 Dec 04, 2012
    i restarted the computer while pressing f1 and in this case the light came back on. it's so lovely when something actually works. thanks.
Hello Everyone,
I faced the same problem in HP Pavilion dv9350 model. I checked with one HP Partner (Sycom technologies, BSK, Bangalore, India) and it is of no use other than wasting Rs.500/- on just for checking the display with external monitor. They asked me to change the entire display which would cost around Rs.18,000/-
With some frustration, my friend simply removed the battery and put it back again. It surprised me lot.
Would suggest you people to remove the battery and put it back. Thank God if it works.
Posted on Mar 07, 2009
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
Monitor in "off mode" cant get it to be in "on mode"
did you go into dispaly properties and "extend my desktop"
Jul 26, 2009 | HP Vs17 17" LCD Flat Panel Monitor
No display on Philips Freevents X59
It the back light or its converter stop working. Do you have any dark dispaly which can been if yoy see carefully in light?
Apr 12, 2009 | Computers & Internet
Averatec N1000 dark screen
yes what u need to do is that connect the external monitor with the laptop and if works fine with the external monitor then what u can try is that uninstall and reinstall the video driver and ten restart ur comuter and still if that doesnt work then replace the lcd screen...
Jan 25, 2009 | Averatec 1000 Notebook
Monitor keeps going dark
It sounds like a LCD backlight problem. Bring it to an authorized repair shop.
Dec 02, 2008 | Dell Latitude D600 Notebook
Cannot display anything at all,sounds it is working but, cannot dispaly boot screen and rest???
Try connecting an external monitor to the Dell Latitude D820. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor has no display, then your problem is with either the video card or motherboard located inside your laptop.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 07, 2008 | Dell Latitude D820 Notebook
Dark screen but just replaced it
I have a compaq laptop Hp 5000 the screen was black and I took the batterie out for a few minutes pluged the unit in and shut it back down and put the batterie back in and now works
Jan 25, 2008 | Panasonic Toughbook 48 Notebook
Hi my IBM 2635-6AU, ThinkPad 380ED 26356AU screen is dark and i cant see
From what you are stating it seems like your backlight in your lcd needs to be replaced. Plug an external monitor up to your laptop. Press the fn & f key (the one with the picture of a monitor in it.) Your diplay should project to the monitor. Display is ok.....replace the backlight.
Hope this helps you
Oct 26, 2007 | IBM ThinkPad 380ED
HP Pavilion dv6000z Notebook Logo
721 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
