Question about Panasonic Panafax UF-9000 All-In-One Laser Printer
Communication code 404
I ried to send a fax, but get the message did not go comm 404. What does it mean. Where is the problem? On my end or on the receiver?Thank you
  • 284 Answers
It is on the receivers end, saying either the modem is defective or they diconnected the line during transmission
Posted on Dec 16, 2008
My fax can receive but is unable to send. Message is COMM ERROR 2
Your machine failed to communicate diring the initial protocol. This is the handshake that tells the receiving fax that you are what you are. IMPORTANT Check that your fax ID is entered in the fax, as some countries require that if it is not present to reject it. This can also be set on any receiving fax to reject junk fax. So Both the TTI and the CSI must be entered in your fax to work.
Oct 06, 2010 | Sharp FO 760 Plain Paper Thermal transfer...
Fax rec 2-3 pgs OK, then disconnects and gives Comm Error
These errors mean that the communications have failed, and can mean that the receiver at the other end has terminated the call prematurely.
If the problem occurs with the same destination, then the receiver fax may be the problem.
If the error persists try disabling ECM
Feb 04, 2010 | HP LaserJet 3055 All-In-One Printer
Comm error 634
Receiving fax never picked.
Aug 14, 2009 | Panasonic PanaFax UF-8000 Laser Fax
I am having trouble faxing documents. Whenever I
Hi, you can check that your phone connection from your 7420 to line works. Listen for a dial tone in a phone connected to your mfc7420. If not, your tel comm module could be at fault.
Jul 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Hp laserjet 3380
did it work before??
if it did, then your printer has been damaged due to a surge in your phone line
Feb 03, 2009 | HP LaserJet 3380 All-In-One Printer
Rx comm error 200082 on receiving fax Ricoh aficio 222SF
I have Dell Monolaser MFP1125, can not send and receive fax
Aug 04, 2008 | Office Equipment & Supplies
Comm error
could be down to the line, had a similar issue which I believed to be hardware related, so got supplier to send a new fax out, spoke to someone at canon who said is def hardware related, any yet it turned out to be rabbits outside chewed through a cable (was in scotland..) so was a BT issue.
May 27, 2008 | Canon FAX-L1000 Plain Paper Laser
Comm. Error
Try this website:
Jun 25, 2007 | Canon L120 Fax Laser Printer
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-9000 All-In-One Laser Printer Logo
626 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
