Question about Dell Inspiron 1100 Notebook
Wont stay on part 2
Wont stay on front 3 green lites blink twice then nothing,after pushing the button in frustration 50 times it might stay on 7 seconds before it shuts back off but 98% of the time the it does the frist thing.i am trying to charge the battery in the notebook,and i tried plugging it in without the battery installed it acts the same
    Problem Solver:
  • 19 Answers
I'm not sure if you are still having the problem with your system ore not, but if you are I'd like to help. Remove the hard drive, CD drive, battery and memory and try starting the system. What should happen is the caps lock and scroll lock lights shoud light up (num lock stays off) to indicate a memory problem (since the memory has been removed). If you get a different combination of lock lights when you try to power it on then either the processor or motherboard is the problem. If you get the memory error try lolita's suggestion: put in one piece of memory at a time to see if you still get the memory error (test each stick individually, once in each memory slot). If you still get the memory error with one stick, no matter which slot its in, that one needs to be replaced. If you get the error with both sticks on one slot, then it is the motherboard. If you are still in warranty, or are not sure if you are, I recommend contacting Dell support. Alternately, you can contact me and I will be more than happy to provide as much help as I can. I can be reached by email at customer_advocate@dell.com (with 'ATTN: Larry' in the subject to ensure it gets to me). Larry Dell Customer Advocate
Posted on Apr 10, 2007
  • 385 Answers
Try to change the RAM and see if that's the problem. If your memory is faulty it won't start or it might start and then freeze. If your laptop has two memory modules, try only one at a time. Switch the sockets on the board that you try the memory in as well
Posted on Mar 22, 2007
How do I set the clock on my sanyo microwave
Usually, if there is a Time/Clock button on the panel, pushing it once blanks the display for timer input while pushing it twice makes the colon blink (the two dots) meaning it's expecting the time input. So, for 12:37 you would push Time-Time-1-2-3-7-Time.
Apr 26, 2015 | Sanyo Microwave Ovens
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
How do I play regional dvd's that the player is not tuned to. I have been trying to find a code but I am struggling. Can you help me?
Hi
You need to follow these instructions.
To unlock the Region Code on a Panasonic DMR EZ48 using a One for All - URC 7040
1. Switch on the player (make sure the drive select is DVD).
2. Select DVD on the URC.
3. Hold the magic button on the URC until the DVD button on the URC blinks twice
4. Enter device code 0490 on the URC, (DVD button blinks twice), URC takes control of the Player.
Point the URC at the Player and program the URC buttons using the following procedure:
1. Hold magic button until the DVD button on the URC blinks twice
2. Press 994 (DVD button blinks twice)
3. Briefly press magic.
4. Enter 4 digit code 1911 (DVD button on URC blinks twice)
5. Repeat steps 1, 2 & 3
6. Enter 4 digit code 1202 (DVD button on URC blinks twice)
7. Repeat steps 1, 2 & 3
8. Enter 4 digit code 0653 (DVD button on URC blinks twice)
9. Repeat steps 1, 2 & 3
10. Enter 4 digit code 1804 (DVD button on URC blinks twice)
11. Repeat steps 1, 2 & 3
12. Enter 4 digit code 1435 (DVD button on URC blinks twice)
13. Repeat steps 1, 2 & 3
14. Enter 4 digit code 1556 (DVD button on URC blinks twice)
15. Repeat steps 1, 2 & 3
16. Enter 4 digit code 1227 (DVD button on URC blinks twice)
17. Repeat steps 1, 2 & 3
18. Enter 4 digit code 1178 (DVD button on URC blinks twice)
19. Repeat steps 1, 2 & 3
20. Enter 4 digit code 1299 (DVD button on URC blinks twice)
21. Repeat steps 1, 2 & 3
22. Enter 4 digit code 1230 (DVD button on URC blinks twice)
23. Press the One For All URC buttons in the following sequence
1, 2, 3, 4, 5, 6, 7, 8, 9, THEN hold down 0 until "HELLO" appears in the display;
After about 1 minute the Player comes back to life as Multi Region.
Please dont forget to vote if you liked my answer
thanks
Feb 13, 2011 | Panasonic DMR-EZ48 DVD Recorder
Canon i9900 printer. Yellow light remains on. Does not blink. Green light will not come on. Anyone know what part needs to be replaced?
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power
button. The indicator will blink in green and remain lit in green.
3) Press resume 4 times (Green) for Waste ink counter reset.
4) Press the power button. The printer will switch itself off after performing the function.
Or try
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 21, 2010 | Canon I990 InkJet Photo Printer
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
My printer is blinking orange lite
Hi there ok try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Jun 18, 2009 | Canon S400 InkJet Printer
S9000 canon printer ink tank full
Hi
Try this see if work for you.
may work
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
8. Your printer should respond as normal.
Nov 02, 2008 | Canon i950 InkJet Photo Printer
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Dell Inspiron 1100 Notebook Logo
73 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
