Question about LG RH1999H DVD Recorder/HDD Recorder
When i put a dvd or cd in the player it says no disk
  • coldsnap59 Dec 28, 2008
    I have the same recorder and after 2 years of un interupted use, I now have the same issue and some!!. Player will nor read DVD's, will not play DVD's and will not copy from HDD to DVD, It will copy to HDD on timer however, lucky me huh.
    My problem became apparent after I disconnected the unit to connect to new TV.
    Does anyone have any solution for this, or do I toss the unit and start again, with a Panasonic or anything other than an LG
  • 456 Answers
The problems you have mentioned have always been solved by replaceing the MPEG printed circuit board and the dvd loader. part numbers for these parts can be found on the parts inside the unit. all barnds are the same, they will all break down, get the longest warranty and if u are wishing to keep it for 5+ years take an extended warranty, so many times i have opened a sony tv with lg parts inside or a panasonic with samsung parts inside. hope this helps.
Posted on Jan 10, 2009
4 Suggested Answers
hockeyguyJC
  • 133 Answers
SOURCE: dvd player will not player dvd's or cd's
When you put the DVD in, you mean it will not launch the appropriate player to start playback of the video?
Maybe your autoplay settings are messed up.
Try launching your movie playback software and attempt to manually play the disc and see if this works.
Another thing, is your drive listed under my computer?
Posted on Aug 16, 2008
JULIANFIX
  • 975 Answers
SOURCE: cd/dvd cannot be read by the player
EITHER CLEAN or replace THE OPTICAL LENS , try first to clean it directly with a DRY Q-tip ,and test player again. if it doesnt read , then replace the optical lens, hope this helps , AJ
Posted on May 19, 2009
  • 103 Answers
SOURCE: apex AD-1100W dvd/cd/mp3 player quit playing movies
hi,
Does it happen for all dvd disc or some particular dvd disc. If it is with some particular disc then clean the dvd and try them. If the problem exist for all the dvd then try to clean the lens by dvd lens cleaner and try to play. dvd lens cleaner will be available in dvd stores.
Thanks,
Posted on May 23, 2009
Cd does not work. Will not show movie.Please replace
There is a difference between a CD "music usually or data" and "DVD". Some players/computers only play CD's. Some are DVD/CD players/writers. Which is yours. If you have a CD player, it will never play a movie. Put in #1.a CD and try. If it works good. Then put in #2. a DVD it might not be a DVD player. Past that it would be a defective player. Get a lense cleaner disk at y computer/variety store". Insert it in your computer and run the program.lay a movie. If it is scratched or dirty. Clean and try again. No luck, You have a bad player of software issue. The Disk player can be slid out and replaced at any computer store. $59? Good Luck. John
Feb 11, 2015 | Computers & Internet
My dvd combi is saying invalid disc and sounds like its spinning but then makes a clicking noise
Make sure the disk you put in the player is compatible with what is in the manual. Don't try to use disks you burned yourself when the manual does not say it is compatible with CD R or DVD R + or -
And when it is compatible with CD / DVD R, put the files on the disk in a format the player can read. Don't try to play MP4 disks, because almost no MP4 format is compatible with w DVD player.
Jan 14, 2015 | Televison & Video
Polaroid portable dvd player won't recognize disk
You have put a dirty CD in and now the laser lenses is dirty and cant read the finer details of a DVD.It needs a clean.
Dec 06, 2013 | Polaroid Televison & Video
I recently bought Sims 3 for PC. So, when I open my IBM disk tray and put the disk in, the computer doesn't recognize it and I cannot install the game. This game was a little expenisve, so I would
Hi Elizabeth,
Depending on the model of your IBM PC, it could be that it has a CD drive and not a DVD drive. The Sims 3 game is on a DVD. If this is the case you will have to upgrade your CD player to a DVD player.
To test if your drive is working insert an original music CD into the drive and see if it plays. If it does play you most likely have a CD player and not a DVD player, which means you will have to upgrade to a DVD player/writer drive anyway.
These are relatively inexpensive and retail for approximately $20 to $50.
Feel free to reply should you need any further assistance.
Best wishes,
Graemevm
Jan 08, 2012 | IBM ThinkCentre Computers & Internet
Won't reconize disk in player
Well here is your resolution for your problem.
As you saying that when you insert any CD or DVD in Player its shows NO DISK.
Well Sometime what happen is if a CD contains are not compatible with Player than it wont work with it.
Or if you had burn that CD or DVD from your personal computer or laptop but it is not burn in proper format than also it wont work in PLAYER.
Well even if CD or DVD is having any scratches on it or it is Used uncounted enumerable times than also sometimes this things happen and it wont work in PLAYER.
Well before Inserting any CD or DVD in Player Just check the above mentioned points.
If everything is ok with the CD or DVD but than also its shows the same problem than get the CD or DVD cleaner liquid spray or even you can use Spirit to clean the CD or DVD and than Insert it.
After doing all this but if its shows no result in it than go to the company dealer and ask him to change the head of the player and you wont face this problem afterward for sure.
if you still have nay quarries regarding the same or any other you may reply me.
Naiven
May 23, 2010 | RCA DRC233N DVD Player
When I install disk, ' No disk' shows on display.
IS the disc on a CD-R or CD-RW (burnt disc) some portable players will not support those types of disc's.
It could also be a different region dvd that doesnt match the region codes of the dvd player. There are no known region hacks for your make and model of dvd player.
Sorry and thank you for choosing Fixya! Post back with more info for further help.
May 18, 2009 | Durabrand 8.5'' Portable DVD Player
DVD player is unable to read any disk to initialize play
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
Apr 10, 2009 | Panasonic DVD-RV26 DVD Player
Mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Oct 02, 2007 | Philips DVD 622 DVD Player
LG RH1999H DVD Recorder/HDD Recorder Logo
140 people viewed this question
