Question about Sony XAV-7W 7 in. Car Monitor
Switching modes my unit keeps switching from video to xm to radio to cd all by itself??? Any help would be appreciated
    Genius:
  • 1,139 Answers
I have seen this caused by two things one is stray IR interference and the other is a bad controller chip. the srray IR happens more offten.
Posted on Sep 19, 2007
SOURCE:
MANUAL FOR XM SKYBOX
Unit is very straightforward to operate. Hold down O/1 button for power. Use the "mode" pusbutton to cycle thru AM/FM/CD/AUX/XM. Treble & Bass settings are made by turning the 'tuning' knob.
For radio and satellite presets, hold in the numbered pushbutton until it beeps, and then it's set. You should be able to hear previews on XM channel 1,and that will help you with antenna setup. I highly suggest using the remote XM antenna. The built-in XM antenna need to be put 'propped-up' outslde, otherwise you have to use the external antenna. Use AC power as it eats batteries, or use rechargeable D batteries. Let me know if you have any more quesions. okay?
Dec 02, 2010 | XM Radio Audio Players & Recorders
I believe the car radio is a Sony Xplod. I have sattelite radio as well. I don't know what button my nephew hit, but now I can't access sattelite radio. When I hit mode- it goes from Radio to CD to MD...
The "Changer Controls" are typically used for the XM controls. I would try turning off the unit and the car and pulling the Sony radio's 'memory' fuse for 10 minutes then restart. This is a tricky one.
Aug 12, 2010 | Sony Car Audio & Video
''No Receiver''
I have a 2008 Sonata with satellite radio issues also. Everytime it rains and I have to do any traveling in it, the storage box located in the trunk floods and shorts out the receiver,LIKE OVER THE WEEKEND!!. This will be the fourth replacement and they (Dealership)still cannot fix the problem.
Jan 12, 2010 | XM Radio Dual XMP7000 Auto In-Dash CD...
XM radio is not working. Tries to 'Load' but then says 'no signal'. XM says that I am receiving the signal but Honda says there is no problem. They want to try to replace the antenna for $500 but are...
You best bet - if you can get to the rear of the XM tuner unit, is to temporarily connect a magnetic-mount XM antenna and see if it works. A bad antenna usually says "check antenna" - not loading could be a good antenna with a bad location. I would try the little XM antenna by itself, then go from there. $20 is a lot cheaper than $500. Let me know how it works out.
Oct 30, 2009 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Changing channels with XM radio
Push the button just to the right of present number 1 and this switches the setting between scan and scroll while in XM mode.
Jul 02, 2008 | Alpine CDA-9883 CD Player
Alpine CDA-9856
Do you have to run in AUX to get XM Radio? Your receiver and unit sound like its ok. This could be a problem with your provider. Contact your provider and their tech dept can help you organise a solution. Is your radio, XM ready?
Mar 09, 2008 | Alpine CDA-9856 CD Player
Avic D2 Won't Complete Initialization
you can open up the unit if you are savey enough and clean the ribbon with an alcohol pad. it worked for me and ever since i did that the door hasnt frooze up on me.
Sep 27, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Source Keeps Switching To Standbye
There's nothing in the wiring that could cause this problem; sounds like a fault in the faceplate. I would say the unit needs to be serviced.
Mar 13, 2007 | Kenwood KVT-715DVD Car DVD Player
XM RADIO PROGRAMMING
For the Ilo CA3000v, all you need is an XM direct tuner box, Model XMD1000, the cable that came with the Ilo radio, and an RCA cable to connect the two. The RCA jacks and the 8-pin DIN jack on the back of the ILO CA3000v are exclusively used for XM signal translation. You will, of course, need a subscription to XM Satellite radio, but the items listed above cover the extent of the hardware you'll require. The XMD1000 comes with the antenna as well, so no need to worry about that, and all XM features are controlled from the head unit itself
Dec 11, 2006 | iLO CA3000V CD Player
Sony XAV-7W 7 in. Car Monitor Logo
65 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
