Question about Kenmore Elite HE4 Electric Dryer
Dryer stops after a few minutes of a full load.
It will run a load that doesn't hold a bunch of moisture. Run a load of towels or jeans and it stops after 10 - 15 minutes. It start again sometime after 30 minutes. Problem started after a small lint fire at the bottom of dryer due to lint screen delta pressure hose/box being disconnected. Fixed box and cleaned all lint out of dryer bottom.
    Problem Solver:
  • 10 Answers
You will have to replace the moisture sensor. The heat from the small fire may have damaged it. It's not that hard to do, but the part costs @$60.
Posted on Dec 19, 2008
Fixing a front load dryer
it sounds like the belt may be either hung up or broke and stuck in
the pulley
Feb 05, 2016 | Dryers
Why does it increase time to 3H when there are 8 minutes of drying time left?
From what you're describing, there could be a problem with the moisture sensor circuit. On the front of the lint screen holder(you have to stick your head in the dryer and look back, you will see 2 metal strips. These are the sensor bars. When wet clothes brush against them, it lets the computer know that the clothes still have moisture in them and about how much. As the moisture decreases, the electrical signal changes and the computer counts down. The time is JUST AN APPROXIMATION. However, if the sensor bars become shorted, or if there is a problem with the wiring of the sensor circuit, or if the main control board is defective, these will produce the problems you're having. One important thing to note: Samsung dryers, when using the sensor-dry settings, like to have large loads in order to work properly. And, try to have like items with like items(jeans with jeans, shirts with shirts, towels with towels, etc) If you have *small, mixed loads*, use the timed-dry settings for best results.
Also, check inside the lint screen holder with a flashlight(with the lint screen removed) for a large build-up of lint. If there is a significant amount of lint, you could have a partial blockage in the dryer vent tube or wall causing restricted airflow--this will cause longer drying times because the hot air, containing moisture, can't exit the dryer properly. THE RULE OF THUMB ON ALL DRYER VENT TUBES IS: **KEEP AS SHORT AS POSSIBLE, NO SHARP BENDS OR KINKS, STRETCHED OUT(if using the cheaper foil or plastic accordion type)**** Remember, gentle bend coming out the dryer, gentle bend going into the wall. The airflow coming out of the vent(outside the house) had better be close to what's coming out of the rear of the dryer, otherwise there is some type of restriction in the air path that must be removed.
Aug 20, 2015 | Samsung DV422EWHDWR 7.2 cu. ft....
I had a bunch of verywet towels because my sink was leaking, and I put them in the dryer and it worked for a few minutes them stopped. What might be wrong?
Good Morning Friend,
I understand that you had a bunch of wet towels, and put them in your Frigidaire dryer, model# FGQ332ES. I see that your dryer worked for a few minutes and then stopped. There could be a possibility that the wet towels were too heavy from all the water in them. I suggest that you spin the towels out in your washer first and then move them over to your dryer. If you are still noticing the dryer working for a couple of minutes and then stopping, I suggest giving your appliance a hard reset. You will do this by either unplugging your appliance or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored start it on any cycle. If your dryer is still shutting off after a few minutes, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off after a few minutes. Hope this is helpful.
-Best regards-
WP
May 14, 2014 | Frigidaire FGQ332ES Gas Dryer
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
Jan 31, 2011 | LG DLE5932W Electric Dryer
YKEHSO2RWHO starts o.k. but stop within a few minutes
that dryer has a moisture sensor probably is not sensing moisture
Jun 23, 2009 | KitchenAid KEHS02RMT Electric Dryer
My dryer takes much longer to dry loads now
Hi!
You need to check the following things to sort out the issue you are facing with--
Improper sorting •Separate heavy items from lightweight items (generally, to dry a well-sorted washer load is a well-sorted dryer load).
Large loads of heavy fabrics •Large, heavy fabrics contain more moisture and take (like beach towels) longer to dry. Separate large, heavy fabrics into smaller loads to speed drying time.
Controls improperly set •Match control settings to the load you are drying.
Lint filter is full •Clean lint filter before every load.
Improper or obstructed ducting •Check installation instructions for proper ducting/venting.
•Make sure ducting is clean, free of kinks and unobstructed.
•Check to see if outside wall damper operates easily.
•Check the Installation Instructions to make sure the dryer venting is correct.
Blown fuses or tripped •Replace fuses or reset circuit breakers. Since most dryers circuit breaker use 2 fuses/breakers, make sure both are operating.
Overloading/combining loads •Do not put more than one washer load in the dryer at a time.
Underloading •If you are drying only one or two items, add a few items to ensure proper tumbling.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Thanks
Rylee
Apr 03, 2009 | GE DVLR223 Dryers
Laundry stinks
I find that the dryer does not dry the clothes enough. The washer can take a lot of laundry at one time but the dryer is not able to handle the load. The stink usually comes from a bit of moisture left in the the clothes, especially the towels. Break down your dryer loads or dry them on a timed cycle for a longer time.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
Dishwasher
Dishwasher: I'm assuming you are talking about when the dishwasher is not running. Correct? If the dishwasher accumulates water while sitting idle, it could be a couple of things. The water inlet valve could be leaking by, or you may have an improperly installed drain line. If you do not have a high loop in the drain line, water can back feed into the dishwasher when you drain your sink. Some dishwashers have a check valve on the drain line to prevent this.
Dryer: Dryer times will vary depending on the load size and type of clothing. Properly sort laundry to make sure lighter materials are separated from denser clothing that holds moisture. For example, if you attempt to dry jeans or towels with light cottons or linens, the moisture from the denser material will transfer to the lighter material. This can cause longer dry times. Towels and/or jeans should be dried on a hotter temperature setting - usually takes 30 to 45 minutes. Cottons and linens will take about 30 minutes on a lower heat setting. Make sure the dryer exhaust vent is not clogged. If the dryer cannot exhaust properly, the dryer heating circuits will actually overheat and eventually fail. The result is a hot dryer with clothes that will not dry. If you suspect you have a dryer vent problem, remove the vent hose from the back of the dryer and try drying a load. If your drying results improve, you probably have a clog in the dryer vent EXTERNAL to the dryer. If the results are the same, inspect the dryer INTERIOR. NOTE: Rule of Thumb - The SHORTER and STRAIGHTER the dryer vent, the better. Dryer vents that are excessively long, have many bends, or run through an attic or crawl space are the worst for accumulating lint. Also DO NOT push the dryer all the way up against the wall. This tends to crush the exhaust vent hose. Leave about a one foot space between the back of the dryer and the wall and use the semi-rigid metal type dryer vent hose. It resists crushing and rodents from chewing through it.
If you would post brand name and model numbers of your appliances in the future, it would make it much easier to diagnose a cause and be able to tell how the appliance is configured. I hope you find this information helpful.
Jun 21, 2008 | Kenmore 15129 Built-in Dishwasher
Kenmore Elite HE4 Electric Dryer Logo
151 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
