Question about Crane Cow Humidifier
Tank will not hold water
I was so excited when purchasing this Cow Humidifier for my newborn granddaughter. Then ... so disheartened when I tried filling the tank with water and the water went everywhere. There must be that part missing but I'm not sure what it is.
I truly hope you can help me on this matter as I think the Humidifiers are awesome for adults as well as these newborns.
Thanks in advance for your help.
Susan
  • 3,497 Answers
Hey Fly gal.. just return it.. ..??..is this a warn air humidifier??...if not, get a warm air model!!!!
Posted on Jul 17, 2017
4 Suggested Answers
SOURCE: cleaning
I also need some information on cleaning, specifically the base. Not sure if I should use soap or if that will affect the nebulizer?
For cleaning the reservoir, just add a capfull of bleach to some water, and swish it around intermittently for about 20 minutes -- rinse until you don't smell bleach anymore.
Posted on Apr 14, 2008
  • 50 Answers
SOURCE: I WAS GIVEN THE COW HUMIDIFIER AS A GIFT WHICH WAS
Hi, Looks like this should be easy to operate. These are the only directions I found for this humidifier: This Crane humidifier operates with cold tap water. Just fill the 1 gallon tank in the sink (fits most common sized sinks) and switch the unit on. The Cow Humidifier will produce cold mist instantanously. The mist output can be regulated with the control button located at the front.
Hope this helps! Hal
Posted on Jun 09, 2009
SOURCE: humidifier filled with water, but red light is on
If you overfill it, the red light goes on. just dump a little out and it should go green. Worked with my crane duck humidifier. Hope it helps
Posted on Jan 21, 2011
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
Why ismy Essick humidifier registering over 20 on the humidity level. I have changed the filters several times using high end filters?? I also have wet the filters
Sorry to ask, for clarification is this a dehumidifier or a humidifier? Do you want to add water to your air or take water out of your air. A reading of 20 for a humidifier sounds pretty good to me. I didn't know there were filters on a humidifier, I thought most of the time you just filled the tank with distilled water, it got heated and vapor came out. I guess a filter to keep airborne bacteria from floating into the water tank would make some sense, maybe a water filter to pre-filter the water going into your humidifier, but I don't think any filter is your problem. If you are trying to remove water from your air, then a dehumidifier is needed and you just have to empty the tank when it's full.
Feb 19, 2015 | Essick Air Humidifiers
My humidifier which is suppose to mist seems to only have the fan blowing. No mist. Lost the manuel and the machine was purchased in feb of 11. What is the solution?
It may have a scale and calcium build up. Particularly, if you use well water.
To clean it, unplug the unit and empty in water that is in the tank. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water (enough to fill the tank. Pour the solution in the tank and allow it to set for 2 hours. Then turn the humidifier ON and place you hand in front of the misting nozzle , to feel if it's working. If it is, allow it to run until the tank is 3/4's empty, Empty te tank of the remaining solution and refill the tank with more Bottled Distilled Water and run for an hour. This will flush the 50/50 solution out of the system. It it wasn't working when you first tested it, allow it to set over night and try again the next morning.
In the future, use Bottled Distilled Water rather than tap water.
95% of the time, this will solve the problem. I hope this helped you. Please let me know.
May 06, 2011 | Walgreens Cool Mist Humidifier Humidifier
How to clean
You can try using either vinegar and water OR baking soda and water.
Dec 24, 2010 | Crane Cow Humidifier
Water tank broken V745A Vicks Humidifier
I think you can find another one on amazon, take a look: Amazon com v745a tank. I hope this was helpful. Have a nice day
Jun 21, 2009 | Vicks Warm Mist V745A 1 Gallon Humidifier
I WAS GIVEN THE COW HUMIDIFIER AS A GIFT WHICH WAS A HAND ME DOWN AND I DONT KNOW HOW TO WORK IT.. PLEASE HELP
Jun 09, 2009 | Crane Cow Humidifier
Cow humidifier sparked and smoked.
Contact the manufacturer, and the retailer let them know about it and try for a refund.
Jan 26, 2009 | Crane Cow Humidifier
Cleaning
Feb 22, 2008 | Crane Cow Humidifier
Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Jan 28, 2008 | Crane Cow Humidifier
Crane Cow Humidifier Logo
393 people viewed this question
Top Crane Humidifiers Experts
Danny Kuhlmann
Andrew Taylor
Andrew Taylor
solver2010
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
