Question about White Sewing 1730 Mechanical Sewing Machine
The top thread keeps breaking on my White 1730, how can I fix?
I don't know if the machine is threaded properly because the manual has become misplaced.
    Problem Solver:
  • 5 Answers
Go to the white website & email them from the contact us section. they'll email you back w/ PDF version of manual. they did that for me. goodluck!
Posted on Dec 16, 2008
Thread keeps breaking don' know how to adjusT tension
Since we don't know what machine you have, we're really limited on suggestions. The owner's manual should have instructions for tension setting. If you don't have a manual, search for:
Make Model manual
Assuming it is the top thread that is breaking. Breaking thread usually indicates either the machine is misthreaded or the tension is set too high. However, there are other symptoms that indicate other issues, ie if the thread is shredding or fraying, possibly the incorrect needle is being used or there is a snag/burr somewhere in the thread path. If the machine sews for approximately 2 inches and then breaks, something is catching the thread causing it to stretch until it breaks. Frequently, my thread slips off the thread spool and wraps around the spool pin and breaks.
AVOID old or bargain bin thread.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point and retest the machine.
Mar 19, 2018 | Sewing Machines
Why does lower looper thread keep breaking?
Usually, thread breakage is due to incorrect threading. When a thread breaks or becomes unthreaded, the best policy is to remove all the thread and rethread from the beginning. Be sure to RAISE the presser foot before threading to allow the thread to seat properly in the tension disk. Also, be sure to thread each in the order specified in the manual or it is unlikely your machine will ever function properly.
Jan 28, 2016 | Sewing Machines
Thread keeps breaking when I sew.
one of three issues: top tension too tight, bottom tension too tight, needle timing off.
Oct 21, 2015 | Elna 2005 Mechanical Sewing Machine
Here are a few sites that may be helpful in diagnosing your problem:
NUMBER ONE SUGGESTION--install a brand new needle. Sewists are known to be very frugal about changing needles but it is usually the easiest and least expensive fix for a lot of problems.
Remove all the thread from your machine, clean the bobbin area of any lint, threads, etc. Be sure that you RAISE the presser foot BEFORE you thread the upper thread. This releases the tension disks so the thread will seat properly. Now, re-thread from the beginning verifying you are following the correct threading sequence (consult your manual).
The standard factory tension setting is the midpoint, ie of the range is 1-10, set the tension at 5 and then adjust from there.
Why is my thread breaking
Why Does My Top Thread Keep Breaking Sewing Machine
Why Does My Thread Keep Breaking While Sew
Sewing Machine Problem 1 Thread Breakage
My sewing machine keep sewing a little bit but breaks the thread everytime the bottom thread is at 0 and 1 my top thread is at 2 or 3 and the top thread breaks please tell me what wrong I am new too.
possibly the top thread is being restricted in movement
check that the thread is between the tension plates and not behind it or knotted up in the way it is threaded
pull on the needle thread and it should move with a steady pull not very hard
if it is not moving fairly easily the check how you have the thread installed
also old thread will break easily as the bonding used to keep the strands together breaks down and is difficult for the thread to slide though the needle
another point is the needle to hook timing and the clearance there as well .
if there is a problem there , the hook will split the thread from the needle and break it
if you still have problems , take it to a sewing machine service center ( any one ) and they will advise of the problem and show you how to fix it
Oct 20, 2015 | Sewing Machines
How do I fix top tread breakage on a white model 935
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Jul 27, 2013 | Sewing Machines
Find free manual for white japanese sewing machine model #1010
check this link & see if it's the manual you need
http://www.singerco.com/uploads/download/738_white-445,988,999,1010-x.pdf
The needle thread breaks
the feeder bar, do you mean the feeddogs, that are in the needle
plate?
for the feeddog part try sew4less.com
Aug 14, 2012 | White Sewing Sewing Machines
Your machine isn't threaded properly. Check to make sure #1, you have it threaded right and #2 the thread on all 4 spools is in between the tension dials. Good Luck and Hope this helps.
Aug 24, 2008 | White Sewing Speedylock 1600 Mechanical...
White Sewing 1730 Mechanical Sewing Machine Logo
173 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
